DickiePhitt
Rpi3B+ & SSD - Is regular yellow LED pulsing normal?
Tue Jun 30, 2020 8:25 am
I recently moved Home Assistant from SD to SSD. Everything works fine but I notice the yellow LED on the Rpi3B+ is pulsing constantly at an interval of about 1 second.
I read somewhere that this might be the Pi looking for the SD card but as I understand it the Rpi3B+ can recognise there is no SD card installed. It certainly started up OK without one.
Is this pulsing normal, and if not what should/can I do about it?
Thanks for reading
drgeoff
Re: Rpi3B+ & SSD - Is regular yellow LED pulsing normal?
Tue Jun 30, 2020 8:51 am
The only yellow LED on a 3B+ is in the ethernet jack. Nothing to do with SD card access. That's the green one nearer the red power LED.
DickiePhitt
Tue Jun 30, 2020 8:59 am
Its the LED near power LED I'm referring to - its definitely yellow!!
RPi LED.jpg (180.23 KiB) Viewed 177 times
rpdom
Tue Jun 30, 2020 9:38 am
No, it is green. The red from the other LED bleeds over inside the case and makes it look yellow.
Unreadable squiggle
DickiePhitt
Tue Jun 30, 2020 9:59 am
Haha, whatever the colour it flashes continuously, which the SD card install never did.
Should I be concerned? What to do if anything to prevent it?
rpdom
Tue Jun 30, 2020 11:55 am
It's nothing to worry about. It's just the Pi checking about once a second to see if an SD card has been inserted. There's an option you can put in /boot/config.txt that will stop it.
I think it was
dtparam=sd_poll_once=on
Unreadable squiggle
DickiePhitt
Tue Jun 30, 2020 1:57 pm
Thanks, I'll try that.
