Muchieman7
Can't read gpio input via gpio or pigs
Sat May 23, 2020 4:19 am
I'm trying to set up an input on a gpio pin in php, but I can't get either the gpio or pigs commands to output "1" when it should. Commands I'm using:
gpio -g read 27
or
pigs r 27
(outputs 0 no matter what, mode is set to in)
I'm using a 4B.
rpiMike
Re: Can't read gpio input via gpio or pigs
Sat May 23, 2020 5:33 am
What have you connected to GPIO 27?
https://pinout.xyz/pinout/pin13_gpio27
Muchieman7
Sat May 23, 2020 5:39 am
I currently have a button for testing
rpiMike
Sat May 23, 2020 5:41 am
Is the button connected between 3.3V and GPIO 27?
Muchieman7
Yessir
rpiMike
Sat May 23, 2020 5:48 am
Post a photo of your wiring.
Muchieman7
Sat May 23, 2020 5:55 am
https://imgur.com/a/1xn3X4A
rpiMike
Sat May 23, 2020 6:00 am
Try temporarily bypassing the switch with a wire between breadboard lines 4 and 6.
Muchieman7
Sat May 23, 2020 6:01 am
I've done that, still nothing.
rpiMike
Sat May 23, 2020 6:05 am
Muchieman7
Sat May 23, 2020 6:12 am
[email protected]:~/Downloads $ ./gpiotest
This program checks the Pi's (user) gpios.
The program reads and writes all the gpios.  Make sure NOTHING
is connected to the gpios during this test.
The program uses the pigpio daemon which must be running.
To start the daemon use the command sudo pigpiod.
Press the ENTER key to continue or ctrl-C to abort...
Testing...
Skipped non-user gpios: 0 1 28 29 30 31
Tested user gpios: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
Failed user gpios: None
rpiMike
Sat May 23, 2020 6:31 am
Have you got a multimeter? If so test you have 3.3V between ground and line 6 of the breadboard.
Muchieman7
Sat May 23, 2020 7:03 am
pin 27 is outputting 3.3v
rpiMike
Sat May 23, 2020 7:08 am
Do you mean 3.3v is being fed into pin 27?
Did you test with a multimeter? Are you running ‘pigs r 27’ from command line?
Muchieman7
Sat May 23, 2020 7:12 am
I was using the gpio one, for some reason the pigs one works now. I don't know what changed, other than a second reboot. Thanks for your help
