xfarre
USB bus died?
Wed Mar 25, 2020 4:18 pm
Dear PI community.
I received a week ago my new Raspberry PI 4 and I started to play with it.
Due to I don't have mini-hdmi adapter I installled Raspbian following headless guide without troubles, I am able to connect it via ssh and there's no problem.
I have long experience with Raspberries, I started from RPi 1 and I' m prodly owner of RPi2, RPi Zero, 3, etc... I explain this because I have some habits as install system in a pendrive (finally I was ready to use full speed USB 3.0!!). I did that with some troubles but finally I get.
My next step was install Nextcloud and connect a powered USB hub 3.0 with two USB 1Tb disks. This is what I have installed in a RPi 3 so I didn't expect any trouble. But...
When I connected USB hub, RPi shutdowns itself. No leds, ping lost. Ok, reboot. But it doesn't boot.
I finally installed deployed another SD card and tested. It boots!!! But... this is what I get when I launch lsusb:
NOTHING.
lspci
NOTHING.
Of course, if I plug an usb device (usb disk, usb mouse...) nothing happens. No new lines in /var/log/messages, nothing in dmesg...
I tested several sd cards, different raspbian releases... same behaviour. It looks like USB ports have died.
And here my question. How can I test it? There's any way to confirm this theory?
Thanks in advance.
Best regards, Xavi.-
Re: USB bus died?
Wed Mar 25, 2020 4:44 pm
1. Unplug everything including power, don't disconnect the HDMI to your monitor/TV
2. Write a new SDCard with plain Raspbian 2020-02-13
3. Create a /boot/ssh file in the first primary partition (the one Windows can see that's 256MB in size)
4. Create a wpa_supplicant.conf with your country code, SSID and password in /boot/wpa_supplicant.conf (also on the first primary partition)
5. Try booting that - it should connect to your WiFi and enable ssh (even though the pi userid has a weak password)
6. ssh in and change the password for user pi to a stronger known value
7. shutdown so that everything is safe on the SDcard (and you won't have to re-run steps 1 to 6)
8. Insert the keyboard
9. Power up again
10. ssh in and see what's in dmesg and /var/log/messages, /var/log/syslog and /var/log/kern.log from the boot up at step 9
11. If it works run sudo apt update; sudo apt dist-upgrade -y (to catch up with a bucket load of changes since February)
12. Reboot again
Then report back what you've found. If nothing works after step 10 you may need to RMA your RPi to your vendor for replacement.
xfarre
Re: USB bus died?
Wed Mar 25, 2020 6:17 pm
Thanks Dougie for your quick answer.
I follow your guide but I get same results. I' ve also tested with 64 bit kernel and default one... same result.
Let me show you my kernel.log:
9253] uart-pl011 fe201000.serial: cts_event_workaround enabled
Mar 25 16:52:10 raspberrypi kernel: [    0.579360] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
Mar 25 16:52:10 raspberrypi kernel: [    0.586991] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
Mar 25 16:52:10 raspberrypi kernel: [    0.587600] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
Mar 25 16:52:10 raspberrypi kernel: [    0.588251] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
Mar 25 16:52:10 raspberrypi kernel: [    0.588278] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
Mar 25 16:52:10 raspberrypi kernel: [    0.614435] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
Mar 25 16:52:10 raspberrypi kernel: [    0.614535] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
Mar 25 16:52:10 raspberrypi kernel: [    0.632225] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Mar 25 16:52:10 raspberrypi kernel: [    0.633862] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 25 16:52:10 raspberrypi kernel: [    0.635503] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 25 16:52:10 raspberrypi kernel: [    0.638420] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Mar 25 16:52:10 raspberrypi kernel: [    0.640050] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 25 16:52:10 raspberrypi kernel: [    0.647561] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
Mar 25 16:52:10 raspberrypi kernel: [    0.649904] of_cfs_init
Mar 25 16:52:10 raspberrypi kernel: [    0.650029] of_cfs_init: OK
Mar 25 16:52:10 raspberrypi kernel: [    0.650658] Waiting for root device PARTUUID=738a4d67-02...
Mar 25 16:52:10 raspberrypi kernel: [    0.685586] mmc0: new SD card at address ef92
Mar 25 16:52:10 raspberrypi kernel: [    0.688496] random: fast init done
Mar 25 16:52:10 raspberrypi kernel: [    0.691127] mmcblk0: mmc0:ef92 SU02G 1.84 GiB
Mar 25 16:52:10 raspberrypi kernel: [    0.693236]  mmcblk0: p1 p2
Mar 25 16:52:10 raspberrypi kernel: [    0.707084] mmc1: new high speed SDIO card at address 0001
Mar 25 16:52:10 raspberrypi kernel: [    0.714912] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Mar 25 16:52:10 raspberrypi kernel: [    0.714988] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Mar 25 16:52:10 raspberrypi kernel: [    0.728940] devtmpfs: mounted
Mar 25 16:52:10 raspberrypi kernel: [    0.732032] Freeing unused kernel memory: 1024K
Mar 25 16:52:10 raspberrypi kernel: [    0.732256] Run /sbin/init as init process
Mar 25 16:52:10 raspberrypi kernel: [    2.013930] NET: Registered protocol family 10
Mar 25 16:52:10 raspberrypi kernel: [    2.015222] Segment Routing with IPv6
Mar 25 16:52:10 raspberrypi kernel: [   11.034932] random: systemd: uninitialized urandom read (16 bytes read)
Mar 25 16:52:10 raspberrypi kernel: [   11.042903] random: systemd: uninitialized urandom read (16 bytes read)
Mar 25 16:52:10 raspberrypi kernel: [   11.044145] random: systemd: uninitialized urandom read (16 bytes read)
Mar 25 16:52:10 raspberrypi kernel: [   20.050946] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Mar 25 16:52:10 raspberrypi kernel: [   20.734622] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
Mar 25 16:52:10 raspberrypi kernel: [   20.737085] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
Mar 25 16:52:10 raspberrypi kernel: [   20.744352] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
Mar 25 16:52:10 raspberrypi kernel: [   20.744969] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
Mar 25 16:52:10 raspberrypi kernel: [   20.795261] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
Mar 25 16:52:10 raspberrypi kernel: [   20.799515] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
Mar 25 16:52:10 raspberrypi kernel: [   20.799537] [vc_sm_connected_init]: start
Mar 25 16:52:10 raspberrypi kernel: [   20.800707] [vc_sm_connected_init]: installed successfully
Mar 25 16:52:10 raspberrypi kernel: [   20.816243] media: Linux media interface: v0.10
Mar 25 16:52:10 raspberrypi kernel: [   20.906819] videodev: Linux video capture interface: v2.00
Mar 25 16:52:10 raspberrypi kernel: [   21.125479] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Mar 25 16:52:10 raspberrypi kernel: [   21.134942] bcm2835_audio soc:audio: card created with 8 channels
Mar 25 16:52:10 raspberrypi kernel: [   21.135802] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Mar 25 16:52:10 raspberrypi kernel: [   21.135829] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Mar 25 16:52:10 raspberrypi kernel: [   21.192452] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
Mar 25 16:52:10 raspberrypi kernel: [   21.199619] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
Mar 25 16:52:10 raspberrypi kernel: [   21.204087] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
Mar 25 16:52:10 raspberrypi kernel: [   21.219824] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
Mar 25 16:52:10 raspberrypi kernel: [   21.219891] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
Mar 25 16:52:10 raspberrypi kernel: [   21.229976] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
Mar 25 16:52:10 raspberrypi kernel: [   21.230013] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
Mar 25 16:52:10 raspberrypi kernel: [   21.237172] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
Mar 25 16:52:10 raspberrypi kernel: [   21.237208] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
Mar 25 16:52:10 raspberrypi kernel: [   21.431839] cfg80211: Loading compiled-in X.509 certificates for regulatory database
Mar 25 16:52:10 raspberrypi kernel: [   21.512823] [drm] No displays found. Consider forcing hotplug if HDMI is attached
Mar 25 16:52:10 raspberrypi kernel: [   21.512900] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
Mar 25 16:52:10 raspberrypi kernel: [   21.513450] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
Mar 25 16:52:10 raspberrypi kernel: [   21.513462] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Mar 25 16:52:10 raspberrypi kernel: [   21.513471] [drm] No driver support for vblank timestamp query.
Mar 25 16:52:10 raspberrypi kernel: [   21.513480] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
Mar 25 16:52:10 raspberrypi kernel: [   21.546808] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Mar 25 16:52:10 raspberrypi kernel: [   21.663333] brcmfmac: F1 signature read @0x18000000=0x15264345
Mar 25 16:52:10 raspberrypi kernel: [   21.670884] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
Mar 25 16:52:10 raspberrypi kernel: [   21.671580] usbcore: registered new interface driver brcmfmac
Mar 25 16:52:10 raspberrypi kernel: [   21.939860] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
Mar 25 16:52:10 raspberrypi kernel: [   21.960324] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
Mar 25 16:52:10 raspberrypi kernel: [   23.330986] random: crng init done
Mar 25 16:52:10 raspberrypi kernel: [   23.331003] random: 7 urandom warning(s) missed due to ratelimiting
Mar 25 16:52:10 raspberrypi kernel: [   23.603283] uart-pl011 fe201000.serial: no DMA platform data
Mar 25 16:52:10 raspberrypi kernel: [   23.953489] 8021q: 802.1Q VLAN Support v1.8
Mar 25 16:52:11 raspberrypi kernel: [   24.380817] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
Mar 25 16:52:11 raspberrypi kernel: [   24.609604] bcmgenet: Skipping UMAC reset
Mar 25 16:52:11 raspberrypi kernel: [   24.681866] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
Mar 25 16:52:11 raspberrypi kernel: [   24.682264] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Mar 25 16:52:12 raspberrypi kernel: [   25.693629] bcmgenet fd580000.genet eth0: Link is Down
Mar 25 16:52:16 raspberrypi kernel: [   29.789808] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Mar 25 16:52:16 raspberrypi kernel: [   29.789854] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Mar 25 16:52:20 raspberrypi kernel: [   34.076197] Bluetooth: Core ver 2.22
Mar 25 16:52:20 raspberrypi kernel: [   34.077820] NET: Registered protocol family 31
Mar 25 16:52:20 raspberrypi kernel: [   34.077835] Bluetooth: HCI device and connection manager initialized
Mar 25 16:52:20 raspberrypi kernel: [   34.078327] Bluetooth: HCI socket layer initialized
Mar 25 16:52:20 raspberrypi kernel: [   34.078345] Bluetooth: L2CAP socket layer initialized
Mar 25 16:52:20 raspberrypi kernel: [   34.078399] Bluetooth: SCO socket layer initialized
Mar 25 16:52:20 raspberrypi kernel: [   34.101833] Bluetooth: HCI UART driver ver 2.3
Mar 25 16:52:20 raspberrypi kernel: [   34.101850] Bluetooth: HCI UART protocol H4 registered
Mar 25 16:52:20 raspberrypi kernel: [   34.101930] Bluetooth: HCI UART protocol Three-wire (H5) registered
Mar 25 16:52:20 raspberrypi kernel: [   34.102172] Bluetooth: HCI UART protocol Broadcom registered
Mar 25 16:52:21 raspberrypi kernel: [   34.419243] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Mar 25 16:52:21 raspberrypi kernel: [   34.419251] Bluetooth: BNEP filters: protocol multicast
Mar 25 16:52:21 raspberrypi kernel: [   34.419262] Bluetooth: BNEP socket layer initialized
Mar 25 17:09:13 raspberrypi kernel: [ 1020.947040] systemd: 34 output lines suppressed due to ratelimiting
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] Linux version 4.19.97-v8+ ([email protected]) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9)) #1294 SMP PREEMPT Thu Jan 30 13:27:08 GMT 2020
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.1
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] efi: Getting EFI parameters from FDT:
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] efi: UEFI not found.
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] On node 0 totalpages: 504832
Mar 25 18:10:26 raspberrypi kernel: [    0.000000]   DMA32 zone: 3792 pages used for memmap
Mar 25 18:10:26 raspberrypi kernel: [    0.000000]   DMA32 zone: 0 pages reserved
Mar 25 18:10:26 raspberrypi kernel: [    0.000000]   DMA32 zone: 242688 pages, LIFO batch:63
Mar 25 18:10:26 raspberrypi kernel: [    0.000000]   Normal zone: 4096 pages used for memmap
Mar 25 18:10:26 raspberrypi kernel: [    0.000000]   Normal zone: 262144 pages, LIFO batch:63
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] random: get_random_bytes called from start_kernel+0xb8/0x47c with crng_init=0
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] percpu: Embedded 23 pages/cpu s56728 r8192 d29288 u94208
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] pcpu-alloc: s56728 r8192 d29288 u94208 alloc=23*4096
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] Detected PIPT I-cache on CPU0
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] CPU features: enabling workaround for EL2 vector hardening
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 496944
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M  smsc95xx.macaddr=DC:A6:32:57:1B:8A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] software IO TLB: mapped [mem 0x373ff000-0x3b3ff000] (64MB)
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] Memory: 1640136K/2019328K available (8444K kernel code, 1044K rwdata, 2672K rodata, 1024K init, 1113K bss, 117048K reserved, 262144K cma-reserved)
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] ftrace: allocating 29428 entries in 115 pages
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] rcu: Preemptible hierarchical RCU implementation.
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] rcu:         RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
Mar 25 18:10:26 raspberrypi kernel: [    0.000000]      Tasks RCU enabled.
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] GIC: Using split EOI/Deactivate mode
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
Mar 25 18:10:26 raspberrypi kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
Mar 25 18:10:26 raspberrypi kernel: [    0.000006] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
Mar 25 18:10:26 raspberrypi kernel: [    0.000221] Console: colour dummy device 80x25
Mar 25 18:10:26 raspberrypi kernel: [    0.000593] console [tty1] enabled
Mar 25 18:10:26 raspberrypi kernel: [    0.000645] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
Mar 25 18:10:26 raspberrypi kernel: [    0.000678] pid_max: default: 32768 minimum: 301
Mar 25 18:10:26 raspberrypi kernel: [    0.000968] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.001014] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.024038] ASID allocator initialised with 32768 entries
Mar 25 18:10:26 raspberrypi kernel: [    0.032036] rcu: Hierarchical SRCU implementation.
Mar 25 18:10:26 raspberrypi kernel: [    0.040535] EFI services will not be available.
Mar 25 18:10:26 raspberrypi kernel: [    0.048093] smp: Bringing up secondary CPUs ...
Mar 25 18:10:26 raspberrypi kernel: [    0.080291] Detected PIPT I-cache on CPU1
Mar 25 18:10:26 raspberrypi kernel: [    0.080352] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
Mar 25 18:10:26 raspberrypi kernel: [    0.112376] Detected PIPT I-cache on CPU2
Mar 25 18:10:26 raspberrypi kernel: [    0.112419] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
Mar 25 18:10:26 raspberrypi kernel: [    0.144494] Detected PIPT I-cache on CPU3
Mar 25 18:10:26 raspberrypi kernel: [    0.144535] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
Mar 25 18:10:26 raspberrypi kernel: [    0.144676] smp: Brought up 1 node, 4 CPUs
Mar 25 18:10:26 raspberrypi kernel: [    0.144766] SMP: Total of 4 processors activated.
Mar 25 18:10:26 raspberrypi kernel: [    0.144789] CPU features: detected: 32-bit EL0 Support
Mar 25 18:10:26 raspberrypi kernel: [    0.145402] CPU: All CPU(s) started at EL2
Mar 25 18:10:26 raspberrypi kernel: [    0.145455] alternatives: patching kernel code
Mar 25 18:10:26 raspberrypi kernel: [    0.146620] devtmpfs: initialized
Mar 25 18:10:26 raspberrypi kernel: [    0.154698] Enabled cp15_barrier support
Mar 25 18:10:26 raspberrypi kernel: [    0.154746] Enabled setend support
Mar 25 18:10:26 raspberrypi kernel: [    0.155124] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Mar 25 18:10:26 raspberrypi kernel: [    0.155166] futex hash table entries: 1024 (order: 4, 65536 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.161751] pinctrl core: initialized pinctrl subsystem
Mar 25 18:10:26 raspberrypi kernel: [    0.162423] DMI not present or invalid.
Mar 25 18:10:26 raspberrypi kernel: [    0.162843] NET: Registered protocol family 16
Mar 25 18:10:26 raspberrypi kernel: [    0.164135] cpuidle: using governor menu
Mar 25 18:10:26 raspberrypi kernel: [    0.164452] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
Mar 25 18:10:26 raspberrypi kernel: [    0.164482] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Mar 25 18:10:26 raspberrypi kernel: [    0.167068] DMA: preallocated 1024 KiB pool for atomic allocations
Mar 25 18:10:26 raspberrypi kernel: [    0.167177] Serial: AMBA PL011 UART driver
Mar 25 18:10:26 raspberrypi kernel: [    0.170526] bcm2835-mbox fe00b880.mailbox: mailbox enabled
Mar 25 18:10:26 raspberrypi kernel: [    0.180656] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-02-12 12:36, variant start
Mar 25 18:10:26 raspberrypi kernel: [    0.184668] raspberrypi-firmware soc:firmware: Firmware hash is c3c8dbdf147686fb0c3f32aece709d0653368810
Mar 25 18:10:26 raspberrypi kernel: [    0.216183] bcm2835-dma fe007000.dma: DMA legacy API manager at (____ptrval____), dmachans=0x1
Mar 25 18:10:26 raspberrypi kernel: [    0.219321] vgaarb: loaded
Mar 25 18:10:26 raspberrypi kernel: [    0.219644] SCSI subsystem initialized
Mar 25 18:10:26 raspberrypi kernel: [    0.219845] usbcore: registered new interface driver usbfs
Mar 25 18:10:26 raspberrypi kernel: [    0.219908] usbcore: registered new interface driver hub
Mar 25 18:10:26 raspberrypi kernel: [    0.220023] usbcore: registered new device driver usb
Mar 25 18:10:26 raspberrypi kernel: [    0.220134] pps_core: LinuxPPS API ver. 1 registered
Mar 25 18:10:26 raspberrypi kernel: [    0.220155] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
Mar 25 18:10:26 raspberrypi kernel: [    0.220192] PTP clock support registered
Mar 25 18:10:26 raspberrypi kernel: [    0.221492] clocksource: Switched to clocksource arch_sys_counter
Mar 25 18:10:26 raspberrypi kernel: [    0.295420] VFS: Disk quotas dquot_6.6.0
Mar 25 18:10:26 raspberrypi kernel: [    0.295527] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.295722] FS-Cache: Loaded
Mar 25 18:10:26 raspberrypi kernel: [    0.295922] CacheFiles: Loaded
Mar 25 18:10:26 raspberrypi kernel: [    0.296510] simple-framebuffer: probe of 0.framebuffer failed with error -12
Mar 25 18:10:26 raspberrypi kernel: [    0.304285] NET: Registered protocol family 2
Mar 25 18:10:26 raspberrypi kernel: [    0.304979] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.305030] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.305165] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.305448] TCP: Hash tables configured (established 16384 bind 16384)
Mar 25 18:10:26 raspberrypi kernel: [    0.305700] UDP hash table entries: 1024 (order: 3, 32768 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.305751] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.305991] NET: Registered protocol family 1
Mar 25 18:10:26 raspberrypi kernel: [    0.310675] RPC: Registered named UNIX socket transport module.
Mar 25 18:10:26 raspberrypi kernel: [    0.310700] RPC: Registered udp transport module.
Mar 25 18:10:26 raspberrypi kernel: [    0.310719] RPC: Registered tcp transport module.
Mar 25 18:10:26 raspberrypi kernel: [    0.310738] RPC: Registered tcp NFSv4.1 backchannel transport module.
Mar 25 18:10:26 raspberrypi kernel: [    0.310766] PCI: CLS 0 bytes, default 64
Mar 25 18:10:26 raspberrypi kernel: [    0.312929] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
Mar 25 18:10:26 raspberrypi kernel: [    0.314899] Initialise system trusted keyrings
Mar 25 18:10:26 raspberrypi kernel: [    0.315153] workingset: timestamp_bits=46 max_order=19 bucket_order=0
Mar 25 18:10:26 raspberrypi kernel: [    0.322529] FS-Cache: Netfs 'nfs' registered for caching
Mar 25 18:10:26 raspberrypi kernel: [    0.323198] NFS: Registering the id_resolver key type
Mar 25 18:10:26 raspberrypi kernel: [    0.323239] Key type id_resolver registered
Mar 25 18:10:26 raspberrypi kernel: [    0.323259] Key type id_legacy registered
Mar 25 18:10:26 raspberrypi kernel: [    0.323289] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Mar 25 18:10:26 raspberrypi kernel: [    0.325960] Key type asymmetric registered
Mar 25 18:10:26 raspberrypi kernel: [    0.325989] Asymmetric key parser 'x509' registered
Mar 25 18:10:26 raspberrypi kernel: [    0.326051] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
Mar 25 18:10:26 raspberrypi kernel: [    0.326265] io scheduler noop registered
Mar 25 18:10:26 raspberrypi kernel: [    0.326288] io scheduler deadline registered (default)
Mar 25 18:10:26 raspberrypi kernel: [    0.326453] io scheduler cfq registered
Mar 25 18:10:26 raspberrypi kernel: [    0.326474] io scheduler mq-deadline registered (default)
Mar 25 18:10:26 raspberrypi kernel: [    0.326495] io scheduler kyber registered
Mar 25 18:10:26 raspberrypi kernel: [    0.329553] brcm-pcie fd500000.pcie: could not get clock
Mar 25 18:10:26 raspberrypi kernel: [    0.329637] brcm-pcie fd500000.pcie: host bridge /scb/[email protected] ranges:
Mar 25 18:10:26 raspberrypi kernel: [    0.329691] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
Mar 25 18:10:26 raspberrypi kernel: [    0.493518] brcm-pcie fd500000.pcie: link down
Mar 25 18:10:26 raspberrypi kernel: [    0.497245] iproc-rng200 fe104000.rng: hwrng registered
Mar 25 18:10:26 raspberrypi kernel: [    0.497592] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
Mar 25 18:10:26 raspberrypi kernel: [    0.498214] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
Mar 25 18:10:26 raspberrypi kernel: [    0.498490] cacheinfo: Unable to detect cache hierarchy for CPU 0
Mar 25 18:10:26 raspberrypi kernel: [    0.507966] brd: module loaded
Mar 25 18:10:26 raspberrypi kernel: [    0.517810] loop: module loaded
Mar 25 18:10:26 raspberrypi kernel: [    0.518657] Loading iSCSI transport class v2.0-870.
Mar 25 18:10:26 raspberrypi kernel: [    0.520420] libphy: Fixed MDIO Bus: probed
Mar 25 18:10:26 raspberrypi kernel: [    0.520885] bcmgenet fd580000.genet: failed to get enet clock
Mar 25 18:10:26 raspberrypi kernel: [    0.520916] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
Mar 25 18:10:26 raspberrypi kernel: [    0.520945] bcmgenet fd580000.genet: failed to get enet-wol clock
Mar 25 18:10:26 raspberrypi kernel: [    0.520974] bcmgenet fd580000.genet: failed to get enet-eee clock
Mar 25 18:10:26 raspberrypi kernel: [    0.521009] bcmgenet: Skipping UMAC reset
Mar 25 18:10:26 raspberrypi kernel: [    0.521259] unimac-mdio unimac-mdio.-19: DMA mask not set
Mar 25 18:10:26 raspberrypi kernel: [    0.529525] libphy: bcmgenet MII bus: probed
Mar 25 18:10:26 raspberrypi kernel: [    0.554106] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(____ptrval____)
Mar 25 18:10:26 raspberrypi kernel: [    0.554992] usbcore: registered new interface driver r8152
Mar 25 18:10:26 raspberrypi kernel: [    0.555064] usbcore: registered new interface driver lan78xx
Mar 25 18:10:26 raspberrypi kernel: [    0.555135] usbcore: registered new interface driver smsc95xx
Mar 25 18:10:26 raspberrypi kernel: [    0.555520] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Mar 25 18:10:26 raspberrypi kernel: [    0.555729] dwc_otg: FIQ enabled
Mar 25 18:10:26 raspberrypi kernel: [    0.555737] dwc_otg: NAK holdoff enabled
Mar 25 18:10:26 raspberrypi kernel: [    0.555745] dwc_otg: FIQ split-transaction FSM enabled
Mar 25 18:10:26 raspberrypi kernel: [    0.555757] Module dwc_common_port init
Mar 25 18:10:26 raspberrypi kernel: [    0.556000] usbcore: registered new interface driver uas
Mar 25 18:10:26 raspberrypi kernel: [    0.556065] usbcore: registered new interface driver usb-storage
Mar 25 18:10:26 raspberrypi kernel: [    0.556265] mousedev: PS/2 mouse device common for all mice
Mar 25 18:10:26 raspberrypi kernel: [    0.557450] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
Mar 25 18:10:26 raspberrypi kernel: [    0.558984] sdhci: Secure Digital Host Controller Interface driver
Mar 25 18:10:26 raspberrypi kernel: [    0.559008] sdhci: Copyright(c) Pierre Ossman
Mar 25 18:10:26 raspberrypi kernel: [    0.559430] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
Mar 25 18:10:26 raspberrypi kernel: [    0.559847] sdhci-pltfm: SDHCI platform and OF driver helper
Mar 25 18:10:26 raspberrypi kernel: [    0.562921] ledtrig-cpu: registered to indicate activity on CPUs
Mar 25 18:10:26 raspberrypi kernel: [    0.563082] hidraw: raw HID events driver (C) Jiri Kosina
Mar 25 18:10:26 raspberrypi kernel: [    0.563215] usbcore: registered new interface driver usbhid
Mar 25 18:10:26 raspberrypi kernel: [    0.563237] usbhid: USB HID core driver
Mar 25 18:10:26 raspberrypi kernel: [    0.564096] vchiq: vchiq_init_state: slot_zero = (____ptrval____), is_master = 0
Mar 25 18:10:26 raspberrypi kernel: [    0.567220] Initializing XFRM netlink socket
Mar 25 18:10:26 raspberrypi kernel: [    0.567267] NET: Registered protocol family 17
Mar 25 18:10:26 raspberrypi kernel: [    0.567387] Key type dns_resolver registered
Mar 25 18:10:26 raspberrypi kernel: [    0.568165] registered taskstats version 1
Mar 25 18:10:26 raspberrypi kernel: [    0.568198] Loading compiled-in X.509 certificates
Mar 25 18:10:26 raspberrypi kernel: [    0.575196] uart-pl011 fe201000.serial: cts_event_workaround enabled
Mar 25 18:10:26 raspberrypi kernel: [    0.575303] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
Mar 25 18:10:26 raspberrypi kernel: [    0.580418] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
Mar 25 18:10:26 raspberrypi kernel: [    0.581060] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
Mar 25 18:10:26 raspberrypi kernel: [    0.581755] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
Mar 25 18:10:26 raspberrypi kernel: [    0.581782] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
Mar 25 18:10:26 raspberrypi kernel: [    0.606709] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
Mar 25 18:10:26 raspberrypi kernel: [    0.606809] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
Mar 25 18:10:26 raspberrypi kernel: [    0.624523] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.626161] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.627794] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.630711] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.632338] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Mar 25 18:10:26 raspberrypi kernel: [    0.639861] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
Mar 25 18:10:26 raspberrypi kernel: [    0.646545] of_cfs_init
Mar 25 18:10:26 raspberrypi kernel: [    0.646673] of_cfs_init: OK
Mar 25 18:10:26 raspberrypi kernel: [    0.647299] Waiting for root device PARTUUID=738a4d67-02...
Mar 25 18:10:26 raspberrypi kernel: [    0.677697] mmc0: new SD card at address ef92
Mar 25 18:10:26 raspberrypi kernel: [    0.681268] random: fast init done
Mar 25 18:10:26 raspberrypi kernel: [    0.683249] mmcblk0: mmc0:ef92 SU02G 1.84 GiB
Mar 25 18:10:26 raspberrypi kernel: [    0.685373]  mmcblk0: p1 p2
Mar 25 18:10:26 raspberrypi kernel: [    0.698557] mmc1: new high speed SDIO card at address 0001
Mar 25 18:10:26 raspberrypi kernel: [    0.716110] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Mar 25 18:10:26 raspberrypi kernel: [    0.716188] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Mar 25 18:10:26 raspberrypi kernel: [    0.730152] devtmpfs: mounted
Mar 25 18:10:26 raspberrypi kernel: [    0.733143] Freeing unused kernel memory: 1024K
Mar 25 18:10:26 raspberrypi kernel: [    0.733365] Run /sbin/init as init process
Mar 25 18:10:26 raspberrypi kernel: [    2.040426] NET: Registered protocol family 10
Mar 25 18:10:26 raspberrypi kernel: [    2.041789] Segment Routing with IPv6
Mar 25 18:10:26 raspberrypi kernel: [   11.069401] random: systemd: uninitialized urandom read (16 bytes read)
Mar 25 18:10:26 raspberrypi kernel: [   11.077553] random: systemd: uninitialized urandom read (16 bytes read)
Mar 25 18:10:26 raspberrypi kernel: [   11.079030] random: systemd: uninitialized urandom read (16 bytes read)
Mar 25 18:10:26 raspberrypi kernel: [   11.882710] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Mar 25 18:10:26 raspberrypi kernel: [   12.547641] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
Mar 25 18:10:26 raspberrypi kernel: [   12.548105] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
Mar 25 18:10:26 raspberrypi kernel: [   12.548553] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
Mar 25 18:10:26 raspberrypi kernel: [   12.549451] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
Mar 25 18:10:26 raspberrypi kernel: [   12.573269] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
Mar 25 18:10:26 raspberrypi kernel: [   12.576190] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
Mar 25 18:10:26 raspberrypi kernel: [   12.576209] [vc_sm_connected_init]: start
Mar 25 18:10:26 raspberrypi kernel: [   12.581912] [vc_sm_connected_init]: installed successfully
Mar 25 18:10:26 raspberrypi kernel: [   12.607799] media: Linux media interface: v0.10
Mar 25 18:10:26 raspberrypi kernel: [   12.688275] videodev: Linux video capture interface: v2.00
Mar 25 18:10:26 raspberrypi kernel: [   12.921015] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
Mar 25 18:10:26 raspberrypi kernel: [   12.964421] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Mar 25 18:10:26 raspberrypi kernel: [   12.974626] bcm2835_audio soc:audio: card created with 8 channels
Mar 25 18:10:26 raspberrypi kernel: [   12.976021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
Mar 25 18:10:26 raspberrypi kernel: [   12.985236] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
Mar 25 18:10:26 raspberrypi kernel: [   13.000069] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
Mar 25 18:10:26 raspberrypi kernel: [   13.000116] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
Mar 25 18:10:26 raspberrypi kernel: [   13.009031] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
Mar 25 18:10:26 raspberrypi kernel: [   13.009067] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
Mar 25 18:10:26 raspberrypi kernel: [   13.016963] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
Mar 25 18:10:26 raspberrypi kernel: [   13.017001] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
Mar 25 18:10:26 raspberrypi kernel: [   13.049650] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
Mar 25 18:10:26 raspberrypi kernel: [   13.264040] cfg80211: Loading compiled-in X.509 certificates for regulatory database
Mar 25 18:10:26 raspberrypi kernel: [   13.369426] [drm] No displays found. Consider forcing hotplug if HDMI is attached
Mar 25 18:10:26 raspberrypi kernel: [   13.369511] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
Mar 25 18:10:26 raspberrypi kernel: [   13.371507] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
Mar 25 18:10:26 raspberrypi kernel: [   13.371522] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Mar 25 18:10:26 raspberrypi kernel: [   13.371530] [drm] No driver support for vblank timestamp query.
Mar 25 18:10:26 raspberrypi kernel: [   13.371538] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
Mar 25 18:10:26 raspberrypi kernel: [   13.398866] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Mar 25 18:10:26 raspberrypi kernel: [   13.508230] brcmfmac: F1 signature read @0x18000000=0x15264345
Mar 25 18:10:26 raspberrypi kernel: [   13.516264] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
Mar 25 18:10:26 raspberrypi kernel: [   13.520459] usbcore: registered new interface driver brcmfmac
Mar 25 18:10:26 raspberrypi kernel: [   13.799130] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
Mar 25 18:10:26 raspberrypi kernel: [   13.889290] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar  2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
Mar 25 18:10:26 raspberrypi kernel: [   15.345880] uart-pl011 fe201000.serial: no DMA platform data
Mar 25 18:10:26 raspberrypi kernel: [   15.396631] random: crng init done
Mar 25 18:10:26 raspberrypi kernel: [   15.396649] random: 7 urandom warning(s) missed due to ratelimiting
Mar 25 18:10:26 raspberrypi kernel: [   15.743125] 8021q: 802.1Q VLAN Support v1.8
Mar 25 18:10:26 raspberrypi kernel: [   16.146847] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
Mar 25 18:10:26 raspberrypi kernel: [   16.385120] bcmgenet: Skipping UMAC reset
Mar 25 18:10:27 raspberrypi kernel: [   16.457813] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
Mar 25 18:10:27 raspberrypi kernel: [   16.458095] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Mar 25 18:10:28 raspberrypi kernel: [   17.469590] bcmgenet fd580000.genet eth0: Link is Down
Mar 25 18:10:32 raspberrypi kernel: [   21.565692] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Mar 25 18:10:32 raspberrypi kernel: [   21.565729] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Mar 25 18:10:33 raspberrypi kernel: [   22.572298] Bluetooth: Core ver 2.22
Mar 25 18:10:33 raspberrypi kernel: [   22.572373] NET: Registered protocol family 31
Mar 25 18:10:33 raspberrypi kernel: [   22.572381] Bluetooth: HCI device and connection manager initialized
Mar 25 18:10:33 raspberrypi kernel: [   22.572401] Bluetooth: HCI socket layer initialized
Mar 25 18:10:33 raspberrypi kernel: [   22.572413] Bluetooth: L2CAP socket layer initialized
Mar 25 18:10:33 raspberrypi kernel: [   22.572450] Bluetooth: SCO socket layer initialized
Mar 25 18:10:33 raspberrypi kernel: [   22.594043] Bluetooth: HCI UART driver ver 2.3
Mar 25 18:10:33 raspberrypi kernel: [   22.594058] Bluetooth: HCI UART protocol H4 registered
Mar 25 18:10:33 raspberrypi kernel: [   22.594150] Bluetooth: HCI UART protocol Three-wire (H5) registered
Mar 25 18:10:33 raspberrypi kernel: [   22.594372] Bluetooth: HCI UART protocol Broadcom registered
Mar 25 18:10:33 raspberrypi kernel: [   22.910979] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Mar 25 18:10:33 raspberrypi kernel: [   22.910986] Bluetooth: BNEP filters: protocol multicast
Mar 25 18:10:33 raspberrypi kernel: [   22.911000] Bluetooth: BNEP socket layer initialized
dmesg
[    1.810822] systemd[1]: System time before build time, advancing clock.
[    2.122288] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    2.122956] systemd[1]: Detected architecture arm64.
[    2.130303] systemd[1]: Set hostname to <raspberrypi>.
[   11.078234] systemd[1]: Listening on udev Control Socket.
[   11.083269] systemd[1]: Created slice system-getty.slice.
[   11.084074] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.085288] systemd[1]: Listening on Journal Socket.
[   11.086385] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   11.090739] systemd[1]: Mounting RPC Pipe File System...
[   11.096638] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   11.098220] systemd[1]: Listening on udev Kernel Socket.
[   11.104043] systemd[1]: Starting udev Coldplug all Devices...
[   11.118979] systemd[1]: Starting Load Kernel Modules...
[   11.958439] systemd-journald[104]: Received request to flush runtime journal from PID 1
xfarre
Re: USB bus died?
/var/log/messages
Mar 25 17:57:39 raspberrypi systemd[1]: Started Authorization Manager.
Mar 25 18:10:18 raspberrypi systemd[1]: Stopped target Graphical Interface.
Mar 25 18:10:18 raspberrypi systemd[1]: Stopped target Sound Card.
Mar 25 18:10:18 raspberrypi systemd[1]: Unmounting RPC Pipe File System...
Mar 25 18:10:18 raspberrypi systemd[1]: Condition check resulted in Turns off Raspberry Pi display backlight on shutdown/reboot being skipped.
Mar 25 18:10:18 raspberrypi systemd[1]: Stopped target Bluetooth.
Mar 25 18:10:18 raspberrypi bluetoothd[445]: Terminating
Mar 25 18:10:18 raspberrypi bluetoothd[445]: Stopping SDP server
Mar 25 18:10:18 raspberrypi bluetoothd[445]: Exit
Mar 25 18:10:26 raspberrypi fake-hwclock[106]: Wed 25 Mar 18:10:22 UTC 2020
Mar 25 18:10:26 raspberrypi systemd[1]: Started File System Check Daemon to report status.
Mar 25 18:10:26 raspberrypi systemd[1]: Started udev Coldplug all Devices.
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Helper to synchronize boot up for ifupdown...
Mar 25 18:10:26 raspberrypi systemd[1]: Started Helper to synchronize boot up for ifupdown.
Mar 25 18:10:26 raspberrypi systemd-fsck[127]: e2fsck 1.44.5 (15-Dec-2018)
Mar 25 18:10:26 raspberrypi systemd-fsck[127]: rootfs: clean, 44452/104416 files, 333678/416256 blocks
Mar 25 18:10:26 raspberrypi systemd[1]: Started File System Check on Root Device.
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Remount Root and Kernel File Systems...
Mar 25 18:10:26 raspberrypi systemd[1]: Started Set the console keyboard layout.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Remount Root and Kernel File Systems.
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Flush Journal to Persistent Storage...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Load/Save Random Seed...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Create System Users...
Mar 25 18:10:26 raspberrypi systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Flush Journal to Persistent Storage.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Load/Save Random Seed.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Create System Users.
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Create Static Device Nodes in /dev...
Mar 25 18:10:26 raspberrypi systemd[1]: Started Create Static Device Nodes in /dev.
Mar 25 18:10:26 raspberrypi systemd[1]: Reached target Local File Systems (Pre).
Mar 25 18:10:26 raspberrypi systemd[1]: Starting udev Kernel Device Manager...
Mar 25 18:10:26 raspberrypi systemd[1]: Started udev Kernel Device Manager.
Mar 25 18:10:26 raspberrypi systemd-udevd[151]: Using default interface naming scheme 'v240'.
Mar 25 18:10:26 raspberrypi systemd[1]: Found device /dev/serial1.
Mar 25 18:10:26 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/738a4d67-01.
Mar 25 18:10:26 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Mar 25 18:10:26 raspberrypi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Mar 25 18:10:26 raspberrypi systemd[1]: Condition check resulted in Huge Pages File System being skipped.
Mar 25 18:10:26 raspberrypi systemd[1]: Condition check resulted in FUSE Control File System being skipped.
Mar 25 18:10:26 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/738a4d67-01...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Mar 25 18:10:26 raspberrypi systemd-udevd[157]: Using default interface naming scheme 'v240'.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Mar 25 18:10:26 raspberrypi systemd-fsck[231]: fsck.fat 4.1 (2017-01-24)
Mar 25 18:10:26 raspberrypi systemd-fsck[231]: /dev/mmcblk0p1: 232 files, 106929/516190 clusters
Mar 25 18:10:26 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/738a4d67-01.
Mar 25 18:10:26 raspberrypi systemd[1]: Mounting /boot...
Mar 25 18:10:26 raspberrypi systemd[1]: Mounted /boot.
Mar 25 18:10:26 raspberrypi systemd[1]: Reached target Local File Systems.
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Create Volatile Files and Directories...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Set console font and keymap...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Raise network interfaces...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Preprocess NFS configuration...
Mar 25 18:10:26 raspberrypi systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Set console font and keymap.
Mar 25 18:10:26 raspberrypi systemd[1]: nfs-config.service: Succeeded.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Mar 25 18:10:26 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
Mar 25 18:10:26 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
Mar 25 18:10:26 raspberrypi systemd[1]: Reached target NFS client services.
Mar 25 18:10:26 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Mar 25 18:10:26 raspberrypi systemd[1]: Reached target Remote File Systems.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Network Time Synchronization...
Mar 25 18:10:26 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Raise network interfaces.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Network Time Synchronization.
Mar 25 18:10:26 raspberrypi systemd[1]: Reached target System Initialization.
Mar 25 18:10:26 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Mar 25 18:10:26 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Daily Cleanup of Temporary Directories.
Mar 25 18:10:26 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Mar 25 18:10:26 raspberrypi systemd[1]: Reached target Sockets.
Mar 25 18:10:26 raspberrypi systemd[1]: Reached target Basic System.
Mar 25 18:10:26 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting System Logging Service...
Mar 25 18:10:26 raspberrypi systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
Mar 25 18:10:26 raspberrypi systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Regular background program processing daemon.
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Check for Raspberry Pi EEPROM updates...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Mar 25 18:10:26 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Mar 25 18:10:26 raspberrypi cron[304]: (CRON) INFO (pidfile fd = 3)
Mar 25 18:10:26 raspberrypi systemd[1]: Starting WPA supplicant...
Mar 25 18:10:26 raspberrypi systemd[1]: Started Manage Sound Card State (restore and store).
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Save/Restore Sound Card State...
Mar 25 18:10:26 raspberrypi alsactl[316]: alsactl 1.1.8 daemon started
Mar 25 18:10:26 raspberrypi systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
Mar 25 18:10:26 raspberrypi systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
Mar 25 18:10:26 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting rng-tools.service...
Mar 25 18:10:26 raspberrypi systemd[1]: Starting Login Service...
Mar 25 18:10:26 raspberrypi systemd[1]: Reached target System Time Synchronized.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Daily man-db regeneration.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Daily rotation of log files.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Daily apt download activities.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Mar 25 18:10:26 raspberrypi systemd[1]: Reached target Timers.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Save/Restore Sound Card State.
Mar 25 18:10:26 raspberrypi systemd[1]: Reached target Sound Card.
Mar 25 18:10:26 raspberrypi rpi-eeprom-update[305]: BCM2711 detected
Mar 25 18:10:26 raspberrypi rng-tools[321]: Starting Hardware RNG entropy gatherer daemon: rngd.
Mar 25 18:10:26 raspberrypi rngd[335]: rngd 2-unofficial-mt.14 starting up...
Mar 25 18:10:26 raspberrypi cron[304]: (CRON) INFO (Running @reboot jobs)
Mar 25 18:10:26 raspberrypi rngd[335]: entropy feed to the kernel ready
Mar 25 18:10:26 raspberrypi thd[307]: Found socket passed from systemd
Mar 25 18:10:26 raspberrypi dhcpcd[320]: dev: loaded udev
Mar 25 18:10:26 raspberrypi avahi-daemon[301]: Found user 'avahi' (UID 108) and group 'avahi' (GID 113).
Mar 25 18:10:26 raspberrypi avahi-daemon[301]: Successfully dropped root privileges.
Mar 25 18:10:26 raspberrypi avahi-daemon[301]: avahi-daemon 0.7 starting up.
Mar 25 18:10:26 raspberrypi rsyslogd: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.1901.0]
Mar 25 18:10:26 raspberrypi rsyslogd:  [origin software="rsyslogd" swVersion="8.1901.0" x-pid="302" x-info="https://www.rsyslog.com"] start
Mar 25 18:10:26 raspberrypi dphys-swapfile[319]: want /var/swap=100MByte, checking existing: keeping it
Mar 25 18:10:26 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Mar 25 18:10:26 raspberrypi systemd[1]: Started System Logging Service.
Mar 25 18:10:26 raspberrypi systemd[1]: Started rng-tools.service.
Mar 25 18:10:26 raspberrypi avahi-daemon[301]: Successfully called chroot().
Mar 25 18:10:26 raspberrypi wpa_supplicant[314]: Successfully initialized wpa_supplicant
Mar 25 18:10:26 raspberrypi avahi-daemon[301]: Successfully dropped remaining capabilities.
Mar 25 18:10:26 raspberrypi avahi-daemon[301]: No service file found in /etc/avahi/services.
Mar 25 18:10:26 raspberrypi avahi-daemon[301]: Network interface enumeration completed.
Mar 25 18:10:26 raspberrypi avahi-daemon[301]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 779640132.
Mar 25 18:10:26 raspberrypi dhcpcd[320]: wlan0: starting wpa_supplicant
Mar 25 18:10:26 raspberrypi dhcpcd-run-hooks[404]: wlan0: starting wpa_supplicant
Mar 25 18:10:26 raspberrypi systemd[1]: Started Login Service.
Mar 25 18:10:26 raspberrypi systemd[1]: Started WPA supplicant.
Mar 25 18:10:26 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Mar 25 18:10:26 raspberrypi raspi-config[300]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Mar 25 18:10:26 raspberrypi raspi-config[300]:  No. Switching to ondemand scaling governor.
Mar 25 18:10:26 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Mar 25 18:10:26 raspberrypi systemd[1]: Started dphys-swapfile - set up, mount/unmount, and delete a swap file.
Mar 25 18:10:26 raspberrypi rpi-eeprom-update[305]: BOOTLOADER: up-to-date
Mar 25 18:10:26 raspberrypi rpi-eeprom-update[305]: CURRENT: Tue 10 Sep 10:41:50 UTC 2019 (1568112110)
Mar 25 18:10:26 raspberrypi rpi-eeprom-update[305]:  LATEST: Tue 10 Sep 10:41:50 UTC 2019 (1568112110)
Mar 25 18:10:26 raspberrypi rpi-eeprom-update[305]:  FW DIR: /lib/firmware/raspberrypi/bootloader/critical
Mar 25 18:10:26 raspberrypi rpi-eeprom-update[305]: VL805: up-to-date
Mar 25 18:10:26 raspberrypi rpi-eeprom-update[305]:  LATEST: 000137ad
Mar 25 18:10:26 raspberrypi systemd[1]: Started Check for Raspberry Pi EEPROM updates.
Mar 25 18:10:26 raspberrypi dhcpcd[320]: wlan0: connected to Access Point `'
Mar 25 18:10:27 raspberrypi dhcpcd[320]: eth0: waiting for carrier
Mar 25 18:10:27 raspberrypi dhcpcd[320]: dhcpcd_prestartinterface: wlan0: Operation not possible due to RF-kill
Mar 25 18:10:27 raspberrypi dhcpcd[320]: wlan0: waiting for carrier
Mar 25 18:10:32 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
Mar 25 18:10:32 raspberrypi dhcpcd[320]: eth0: carrier acquired
Mar 25 18:10:32 raspberrypi dhcpcd[320]: DUID 00:01:00:01:25:d8:31:6d:dc:a6:32:57:1b:8a
Mar 25 18:10:32 raspberrypi dhcpcd[320]: eth0: IAID 32:57:1b:8a
Mar 25 18:10:32 raspberrypi dhcpcd[320]: eth0: adding address fe80::cd74:2672:697e:7414
Mar 25 18:10:32 raspberrypi avahi-daemon[301]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::cd74:2672:697e:7414.
Mar 25 18:10:32 raspberrypi avahi-daemon[301]: New relevant interface eth0.IPv6 for mDNS.
Mar 25 18:10:32 raspberrypi avahi-daemon[301]: Registering new address record for fe80::cd74:2672:697e:7414 on eth0.*.
Mar 25 18:10:32 raspberrypi dhcpcd[320]: eth0: rebinding lease of 172.16.1.125
Mar 25 18:10:32 raspberrypi dhcpcd[320]: eth0: probing address 172.16.1.125/24
Mar 25 18:10:33 raspberrypi btuart[306]: bcm43xx_init
Mar 25 18:10:33 raspberrypi btuart[306]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
Mar 25 18:10:33 raspberrypi btuart[306]: Set Controller UART speed to 3000000 bit/s
Mar 25 18:10:33 raspberrypi btuart[306]: Device setup complete
Mar 25 18:10:33 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Mar 25 18:10:33 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Mar 25 18:10:33 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Mar 25 18:10:33 raspberrypi systemd[1]: Starting Bluetooth service...
Mar 25 18:10:33 raspberrypi systemd[1]: Created slice system-bthelper.slice.
Mar 25 18:10:33 raspberrypi bluetoothd[447]: Bluetooth daemon 5.50
Mar 25 18:10:33 raspberrypi dhcpcd[320]: eth0: soliciting an IPv6 router
Mar 25 18:10:33 raspberrypi systemd[1]: Started Bluetooth service.
Mar 25 18:10:33 raspberrypi systemd[1]: Reached target Bluetooth.
Mar 25 18:10:33 raspberrypi systemd[1]: Started Raspberry Pi bluetooth helper.
Mar 25 18:10:33 raspberrypi bluetoothd[447]: Starting SDP server
Mar 25 18:10:33 raspberrypi bluetoothd[447]: Bluetooth management interface 1.14 initialized
Mar 25 18:10:33 raspberrypi dbus-daemon[308]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.5' (uid=0 pid=447 comm="/usr/lib/bluetooth/bluetoothd ")
Mar 25 18:10:33 raspberrypi bluetoothd[447]: Sap driver initialization failed.
Mar 25 18:10:33 raspberrypi bluetoothd[447]: sap-server: Operation not permitted (1)
Mar 25 18:10:33 raspberrypi systemd[1]: [email protected]: Succeeded.
Mar 25 18:10:33 raspberrypi systemd[1]: Starting Hostname Service...
Mar 25 18:10:33 raspberrypi bluetoothd[447]: Failed to set privacy: Rejected (0x0b)
Mar 25 18:10:33 raspberrypi dbus-daemon[308]: [system] Successfully activated service 'org.freedesktop.hostname1'
Mar 25 18:10:33 raspberrypi systemd[1]: Started Hostname Service.
Mar 25 18:10:37 raspberrypi dhcpcd[320]: eth0: leased 172.16.1.125 for 86400 seconds
Mar 25 18:10:37 raspberrypi avahi-daemon[301]: Joining mDNS multicast group on interface eth0.IPv4 with address 172.16.1.125.
Mar 25 18:10:37 raspberrypi avahi-daemon[301]: New relevant interface eth0.IPv4 for mDNS.
Mar 25 18:10:37 raspberrypi avahi-daemon[301]: Registering new address record for 172.16.1.125 on eth0.IPv4.
Mar 25 18:10:37 raspberrypi dhcpcd[320]: eth0: adding route to 172.16.1.0/24
Mar 25 18:10:37 raspberrypi dhcpcd[320]: eth0: adding default route via 172.16.1.1
Mar 25 18:10:37 raspberrypi dhcpcd[320]: forked to background, child pid 502
Mar 25 18:10:37 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Mar 25 18:10:37 raspberrypi systemd[1]: Reached target Network.
Mar 25 18:10:37 raspberrypi systemd[1]: Starting Permit User Sessions...
Mar 25 18:10:37 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Mar 25 18:10:37 raspberrypi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Mar 25 18:10:37 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Mar 25 18:10:37 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Mar 25 18:10:37 raspberrypi systemd[1]: Started Permit User Sessions.
Mar 25 18:10:37 raspberrypi systemd[1]: Started Getty on tty1.
Mar 25 18:10:37 raspberrypi systemd[1]: Reached target Login Prompts.
Mar 25 18:10:38 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Mar 25 18:10:38 raspberrypi systemd[1]: Reached target Multi-User System.
Mar 25 18:10:38 raspberrypi systemd[1]: Reached target Graphical Interface.
Mar 25 18:10:38 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Mar 25 18:10:38 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Mar 25 18:10:38 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Mar 25 18:10:38 raspberrypi systemd[1]: Startup finished in 1.711s (kernel) + 25.827s (userspace) = 27.538s.
Mar 25 18:10:38 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
Mar 25 18:10:46 raspberrypi dhcpcd[502]: eth0: no IPv6 Routers available
Mar 25 18:10:54 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
Mar 25 18:10:54 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000...
Mar 25 18:10:54 raspberrypi systemd[1]: Started User Runtime Directory /run/user/1000.
Mar 25 18:10:54 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Mar 25 18:10:54 raspberrypi systemd[517]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Mar 25 18:10:54 raspberrypi systemd[517]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Mar 25 18:10:54 raspberrypi systemd[517]: Reached target Paths.
Mar 25 18:10:54 raspberrypi systemd[517]: Listening on GnuPG cryptographic agent and passphrase cache.
Mar 25 18:10:54 raspberrypi systemd[517]: Listening on GnuPG network certificate management daemon.
Mar 25 18:10:54 raspberrypi systemd[517]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Mar 25 18:10:54 raspberrypi systemd[517]: Reached target Timers.
Mar 25 18:10:54 raspberrypi systemd[517]: Reached target Sockets.
Mar 25 18:10:54 raspberrypi systemd[517]: Reached target Basic System.
Mar 25 18:10:54 raspberrypi systemd[517]: Reached target Default.
Mar 25 18:10:54 raspberrypi systemd[517]: Startup finished in 255ms.
Mar 25 18:10:54 raspberrypi systemd[1]: Started User Manager for UID 1000.
Mar 25 18:10:54 raspberrypi systemd[1]: Started Session c1 of user pi.
Mar 25 18:10:54 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
Mar 25 18:11:20 raspberrypi systemd-timesyncd[259]: Synchronized to time server for the first time 178.32.88.247:123 (2.debian.pool.ntp.org).
Mar 25 18:11:28 raspberrypi systemd[1]: systemd-hostnamed.service: Succeeded.
Thanks for your support!!!
Re: USB bus died?
Wed Mar 25, 2020 10:31 pm
I can see the kernel loading some USB drivers but I can't see any USB device getting enumerated.
Does anything change if you switch back to the Pi4 V7L kernel from the 64-bit one?
xfarre
Re: USB bus died?
Thu Mar 26, 2020 8:16 pm
I did it. Same result:
[email protected]:~ $ dmesg
[    0.000000] Linux version 4.19.97-v7l+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1294 SMP Thu Jan 30 13:21:14 GMT 2020
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[    0.000000] Memory policy: Data cache writealloc
[    0.000000]   DMA zone: 1728 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 308224 pages, LIFO batch:63
[    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[    0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
[    0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 503104
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1721804K/2019328K available (8192K kernel code, 687K rwdata, 2408K rodata, 2048K init, 850K bss, 35380K reserved, 262144K cma-reserved, 1232896K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                     .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                     .data : 0x(ptrval) - 0x(ptrval)   ( 688 kB)
                      .bss : 0x(ptrval) - 0x(ptrval)   ( 851 kB)
[    0.000000] ftrace: allocating 28692 entries in 85 pages
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000021] Switching to timer-based delay loop, resolution 18ns
[    0.000248] Console: colour dummy device 80x30
[    0.000700] console [tty1] enabled
[    0.000755] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.000792] pid_max: default: 32768 minimum: 301
[    0.001075] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001108] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001884] CPU: Testing write buffer coherency: ok
[    0.002310] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002970] Setting up static identity map for 0x200000 - 0x20003c
[    0.003145] rcu: Hierarchical SRCU implementation.
[    0.004025] smp: Bringing up secondary CPUs ...
[    0.004850] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.005792] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.006694] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.006829] smp: Brought up 1 node, 4 CPUs
[    0.006893] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.006915] CPU: All CPU(s) started in HYP mode.
[    0.006936] CPU: Virtualization extensions available.
[    0.007741] devtmpfs: initialized
[    0.017958] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.018190] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.018232] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.025743] pinctrl core: initialized pinctrl subsystem
[    0.026613] NET: Registered protocol family 16
[    0.029530] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.030971] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.031003] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.031212] Serial: AMBA PL011 UART driver
[    0.034296] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.050027] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-02-12 12:36, variant start
[    0.060043] raspberrypi-firmware soc:firmware: Firmware hash is c3c8dbdf147686fb0c3f32aece709d0653368810
[    0.102968] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[    0.106197] vgaarb: loaded
[    0.106570] SCSI subsystem initialized
[    0.106786] usbcore: registered new interface driver usbfs
[    0.106852] usbcore: registered new interface driver hub
[    0.106935] usbcore: registered new device driver usb
[    0.108161] clocksource: Switched to clocksource arch_sys_counter
[    0.186690] VFS: Disk quotas dquot_6.6.0
[    0.186797] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.186955] FS-Cache: Loaded
[    0.187148] CacheFiles: Loaded
[    0.187677] simple-framebuffer: probe of 0.framebuffer failed with error -12
[    0.196577] NET: Registered protocol family 2
[    0.197260] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.197306] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.197387] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.197471] TCP: Hash tables configured (established 8192 bind 8192)
[    0.197607] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.197650] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.197888] NET: Registered protocol family 1
[    0.198522] RPC: Registered named UNIX socket transport module.
[    0.198549] RPC: Registered udp transport module.
[    0.198571] RPC: Registered tcp transport module.
[    0.198592] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.198621] PCI: CLS 0 bytes, default 64
[    0.201603] Initialise system trusted keyrings
[    0.201796] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.210862] FS-Cache: Netfs 'nfs' registered for caching
[    0.211400] NFS: Registering the id_resolver key type
[    0.211436] Key type id_resolver registered
[    0.211458] Key type id_legacy registered
[    0.211489] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.213766] Key type asymmetric registered
[    0.213793] Asymmetric key parser 'x509' registered
[    0.213915] bounce: pool size: 64 pages
[    0.213970] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.214157] io scheduler noop registered
[    0.214181] io scheduler deadline registered (default)
[    0.214353] io scheduler cfq registered
[    0.214376] io scheduler mq-deadline registered (default)
[    0.214399] io scheduler kyber registered
[    0.217510] brcm-pcie fd500000.pcie: could not get clock
[    0.217585] brcm-pcie fd500000.pcie: host bridge /scb/[email protected] ranges:
[    0.217636] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
[    0.488193] brcm-pcie fd500000.pcie: link down
[    0.492040] iproc-rng200 fe104000.rng: hwrng registered
[    0.492277] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    0.492819] vc-sm: Videocore shared memory driver
[    0.493233] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    0.503487] brd: module loaded
[    0.513114] loop: module loaded
[    0.513881] Loading iSCSI transport class v2.0-870.
[    0.515570] libphy: Fixed MDIO Bus: probed
[    0.516002] bcmgenet fd580000.genet: failed to get enet clock
[    0.516035] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[    0.516065] bcmgenet fd580000.genet: failed to get enet-wol clock
[    0.516093] bcmgenet fd580000.genet: failed to get enet-eee clock
[    0.516129] bcmgenet: Skipping UMAC reset
[    0.516380] unimac-mdio unimac-mdio.-19: DMA mask not set
[    0.528198] libphy: bcmgenet MII bus: probed
[    0.568738] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[    0.569663] usbcore: registered new interface driver r8152
[    0.569738] usbcore: registered new interface driver lan78xx
[    0.569807] usbcore: registered new interface driver smsc95xx
[    0.570217] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.570420] dwc_otg: FIQ enabled
[    0.570429] dwc_otg: NAK holdoff enabled
[    0.570438] dwc_otg: FIQ split-transaction FSM enabled
[    0.570450] Module dwc_common_port init
[    0.570637] usbcore: registered new interface driver uas
[    0.570708] usbcore: registered new interface driver usb-storage
[    0.570906] mousedev: PS/2 mouse device common for all mice
[    0.572120] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    0.573566] sdhci: Secure Digital Host Controller Interface driver
[    0.573591] sdhci: Copyright(c) Pierre Ossman
[    0.573993] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[    0.574424] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.577461] ledtrig-cpu: registered to indicate activity on CPUs
[    0.577622] hidraw: raw HID events driver (C) Jiri Kosina
[    0.577756] usbcore: registered new interface driver usbhid
[    0.577779] usbhid: USB HID core driver
[    0.578612] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[    0.580392] [vc_sm_connected_init]: start
[    0.591950] [vc_sm_connected_init]: end - returning 0
[    0.593058] Initializing XFRM netlink socket
[    0.593100] NET: Registered protocol family 17
[    0.593204] Key type dns_resolver registered
[    0.593472] Registering SWP/SWPB emulation handler
[    0.594103] registered taskstats version 1
[    0.594133] Loading compiled-in X.509 certificates
[    0.601110] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    0.601196] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[    0.606274] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    0.606829] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[    0.607485] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    0.607512] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    0.631338] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
[    0.631436] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
[    0.649414] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    0.651219] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.652859] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.655791] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    0.657431] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    0.663410] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[    0.665863] of_cfs_init
[    0.665960] of_cfs_init: OK
[    0.666554] Waiting for root device PARTUUID=738a4d67-02...
[    0.700943] mmc0: new SD card at address ef92
[    0.702160] mmcblk0: mmc0:ef92 SU02G 1.84 GiB
[    0.704167]  mmcblk0: p1 p2
[    0.706317] random: fast init done
[    0.724849] mmc1: new high speed SDIO card at address 0001
[    0.735764] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    0.735843] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    0.749513] devtmpfs: mounted
[    0.757201] Freeing unused kernel memory: 2048K
[    0.768424] Run /sbin/init as init process
[    1.860755] systemd[1]: System time before build time, advancing clock.
[    2.066290] NET: Registered protocol family 10
[    2.067553] Segment Routing with IPv6
[    2.128782] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    2.129502] systemd[1]: Detected architecture arm.
[    2.139794] systemd[1]: Set hostname to <raspberrypi>.
[   11.112852] random: systemd: uninitialized urandom read (16 bytes read)
[   11.120753] random: systemd: uninitialized urandom read (16 bytes read)
[   11.121098] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   11.121812] random: systemd: uninitialized urandom read (16 bytes read)
[   11.125844] systemd[1]: Created slice User and Session Slice.
[   11.139664] systemd[1]: Listening on Syslog Socket.
[   11.140645] systemd[1]: Listening on udev Control Socket.
[   11.141083] systemd[1]: Reached target Slices.
[   11.142045] systemd[1]: Listening on Journal Socket.
[   11.149038] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   11.156582] systemd[1]: Starting Set the console keyboard layout...
[   11.158049] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   11.164522] systemd[1]: Mounting POSIX Message Queue File System...
[   11.999077] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   12.097886] systemd-journald[107]: Received request to flush runtime journal from PID 1
[   12.726379] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[   12.735985] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[   12.736580] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[   12.737213] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[   12.803576] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[   12.805599] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[   12.805618] [vc_sm_connected_init]: start
[   12.811389] [vc_sm_connected_init]: installed successfully
[   12.822156] media: Linux media interface: v0.10
[   12.886134] videodev: Linux video capture interface: v2.00
[   13.025762] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[   13.031476] bcm2835_audio soc:audio: card created with 8 channels
[   13.075639] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[   13.077972] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[   13.095956] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[   13.131878] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[   13.151636] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[   13.151670] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[   13.161756] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[   13.161791] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[   13.173367] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[   13.173401] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[   13.396538] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[   13.414754] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   13.435360] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[   13.435456] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[   13.435905] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[   13.435917] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   13.435927] [drm] No driver support for vblank timestamp query.
[   13.435936] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[   13.518717] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   13.619083] brcmfmac: F1 signature read @0x18000000=0x15264345
[   13.634804] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[   13.635463] usbcore: registered new interface driver brcmfmac
[   13.942853] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[   13.958357] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar  2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[   15.545354] uart-pl011 fe201000.serial: no DMA platform data
[   15.692955] random: crng init done
[   15.692970] random: 7 urandom warning(s) missed due to ratelimiting
[   16.085004] 8021q: 802.1Q VLAN Support v1.8
[   16.563988] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   16.930197] bcmgenet: Skipping UMAC reset
[   17.028521] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[   17.028902] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   18.088468] bcmgenet fd580000.genet eth0: Link is Down
[   22.248437] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   22.248475] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   22.949322] Bluetooth: Core ver 2.22
[   22.949388] NET: Registered protocol family 31
[   22.949396] Bluetooth: HCI device and connection manager initialized
[   22.949414] Bluetooth: HCI socket layer initialized
[   22.949427] Bluetooth: L2CAP socket layer initialized
[   22.949462] Bluetooth: SCO socket layer initialized
[   22.966563] Bluetooth: HCI UART driver ver 2.3
[   22.966574] Bluetooth: HCI UART protocol H4 registered
[   22.966641] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   22.966831] Bluetooth: HCI UART protocol Broadcom registered
[   23.289545] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   23.289551] Bluetooth: BNEP filters: protocol multicast
[   23.289562] Bluetooth: BNEP socket layer initialized
Re: USB bus died?
Thu Mar 26, 2020 10:50 pm
Then I think your hardware is broken. If you're sure it's nothing you've done to break it contact your vendor for an RMA.
xfarre
Re: USB bus died?
Tue Mar 31, 2020 9:29 am
Ok, I did RMA and I get a new device right now.
Should I take any consideration to connect a powered USB hub? Is there any limitation for these devices?
Thanks in advance.
Xavi.-
RaTTuS
Contact: Twitter YouTube
Re: USB bus died?
Tue Mar 31, 2020 10:01 am
post a link to this hub .
Covfefe
Re: USB bus died?
Tue Mar 31, 2020 10:51 am
Thanks in advance.
Xavi.-
Don't connect that again until you're sure it's not the perpetrator with the loaded weapon.
