hippy
[Solved] Overcoming a GCC 'sudo' issue
Fri Feb 14, 2020 2:50 pm
I installed a pre-built compiler package for creating code for the ZyLin ZPU processor ...
cd ~
mkdir zpugcc
cd zpugcc
wget ftp://ftp.embeddedarm.com/ts-arm-sbc/ts-7180-linux/zpu/armhf-zpu-elf-gcc-3.4.2.tar.bz2
bzip2 -dk armhf-zpu-elf-gcc-3.4.2.tar.bz2
tar -xvf armhf-zpu-elf-gcc-3.4.2.tar
That all works fine but when I create my C program, run the compiler, I get "Permission denied" errors and no assembler source code output ...
[email protected]:~/zpugcc $ ./armhf-zpu-elf-gcc-3.4.2/bin/zpu-elf-gcc -S fibo.c
cc1: /root/Downloads/zpugcc/toolchain/install/lib/gcc/zpu-elf/3.4.2/include: Permission denied
cc1: /root/Downloads/zpugcc/toolchain/install/zpu-elf/sys-include: Permission denied
cc1: /root/Downloads/zpugcc/toolchain/install/zpu-elf/include: Permission denied
[email protected]:~/zpugcc $ ls -l fibo.*
-rw-r--r-- 1 pi pi 170 Feb 14 14:29 fibo.c
If I run it with 'sudo' it works as expected and I get my assembler code, though that's then owned by root ...
[email protected]:~/zpugcc $ sudo ./armhf-zpu-elf-gcc-3.4.2/bin/zpu-elf-gcc -S fibo.c
-rw-r--r-- 1 root root 1303 Feb 14 14:30 fibo.s
The issue seems to me to be that the compiler has been configured to use /root ...
[email protected]:~/zpugcc $ sudo ./armhf-zpu-elf-gcc-3.4.2/bin/zpu-elf-gcc -v -S fibo.c
Reading specs from /home/pi/zpugcc/armhf-zpu-elf-gcc-3.4.2/bin/../lib/gcc/zpu-elf/3.4.2/specs
Configured with: ../gcc/configure --target=zpu-elf --prefix=/root/Downloads/zpugcc/toolchain/gccbuild/../install --enable-languages=c,c++ --with-gnu-as --with-gnu-ld --with-newlib --disable-shared --enable-newlib -v --enable-checking=misc,tree,rtl,rtlflag,gc,gcac,fold --disable-multilib --disable-threads --enable-sjlj-exceptions --enable-libstdcxx-allocator=malloc
Thread model: single
gcc version 3.4.2
 /home/pi/zpugcc/armhf-zpu-elf-gcc-3.4.2/bin/../libexec/gcc/zpu-elf/3.4.2/cc1 -quiet -v -iprefix /home/pi/zpugcc/armhf-zpu-elf-gcc-3.4.2/bin/../lib/gcc/zpu-elf/3.4.2/ fibo.c -quiet -dumpbase fibo.c -auxbase fibo -version -o fibo.s
ignoring nonexistent directory "/home/pi/zpugcc/armhf-zpu-elf-gcc-3.4.2/bin/../lib/gcc/zpu-elf/3.4.2/../../../../zpu-elf/sys-include"
ignoring nonexistent directory "/root/Downloads/zpugcc/toolchain/install/lib/gcc/zpu-elf/3.4.2/include"
ignoring nonexistent directory "/root/Downloads/zpugcc/toolchain/install/zpu-elf/sys-include"
ignoring nonexistent directory "/root/Downloads/zpugcc/toolchain/install/zpu-elf/include"
#include "..." search starts here:
#include <...> search starts here:
 /home/pi/zpugcc/armhf-zpu-elf-gcc-3.4.2/bin/../lib/gcc/zpu-elf/3.4.2/include
 /home/pi/zpugcc/armhf-zpu-elf-gcc-3.4.2/bin/../lib/gcc/zpu-elf/3.4.2/../../../../zpu-elf/include
End of search list.
GNU C version 3.4.2 (zpu-elf)
        compiled by GNU C version 4.9.2.
GGC heuristics: --param ggc-min-expand=0 --param ggc-min-heapsize=0
I can get around the issue by using 'sudo' and 'chown', but I accept "that's not the way to do things".
Does anyone know how I resolve the issue so I don't have to do that ?
RaTTuS
Contact: Twitter YouTube
Re: Overcoming a GCC 'sudo' issue
Fri Feb 14, 2020 2:58 pm
this :-
^^ root
1) dont run the desktop as root
2) dont download things into root
3) do it all as a normal user
i.e edit, build run....
if you need to install it somewhere then sudo install .... but never run as root normally
Covfefe
PeterO
Fri Feb 14, 2020 2:59 pm
Are you sure you wern't running as root when did the untar step ?
I can't see how the files could have got into /root unless you were running as root.
PeterO
hippy
Fri Feb 14, 2020 3:12 pm
I am not running as root, just as the normal Pi user. Nothing has been installed as root. The installation was exactly as show in the OP. Download, extract, run from a sub-directory under /home/pi
There are no files I put in root, nor did the installation. The problem appears to be that the compiler believes there may be files in /root, fails because it can't access /root because it's not run as root.
PeterO
Fri Feb 14, 2020 3:28 pm
I downloaded it and I now see what you mean.
~/armhf-zpu-elf-gcc-3.4.2/bin $ strings zpu-elf-gcc | grep root
/root/Downloads/zpugcc/toolchain/gccbuild/../install/lib/gcc/
/root/Downloads/zpugcc/toolchain/gccbuild/../install/bin/
/root/Downloads/zpugcc/toolchain/gccbuild/../install/libexec/gcc/
sysroot_suffix_spec
sysroot_hdrs_suffix_spec
  -print-multi-directory   Display the root directory for versions of libgcc
-isysroot
/root/Downloads/zpugcc/toolchain/gccbuild/../install/share/locale
target_system_root
target_system_root_changed
target_sysroot_suffix
target_sysroot_hdrs_suffix
sysroot_suffix_spec
add_sysrooted_prefix
Looks like it's been built incorrectly . I doubt those paths into /root should be in there !
PeterO
hippy
Fri Feb 14, 2020 7:18 pm
Thanks; that pointed to the path to salvation. Replaced every occurrence of "/root/Downloads/" with "/home/pi/shazam/" in every file in the tree and now it works without 'sudo'.
Will maybe look for somewhere better to point them at, and make sure I've found any hiding in unicode or other endian forms waiting to bite me.
And I think I've got the (same) explanation as to why the PiDuino framework doesn't work on a Pi without launching the desktop Arduino IDE with 'sudo'.
I had tried building from source but that was another "Why does nothing ever seem to work on Linux?" venture into the circles of hell. The official source and two other forks all failed with varying errors.
-rw-r--r-- 1 pi pi 1303 Feb 14 19:17 fibo.s
