After a year or two of being in a cupboard I dragged my Pi 2 out and tried to update it. The update failed. So I thought, no matter. I formatted the SD card and used balena etcher to put on a new raspbian image but i get the same errors.
sudo apt update results in ~620 packages are upgradable
sudo apt upgrade does all the Get portion says
Fetched 736 Mb in 5min 13s
dpkg-deb: error: subprocess <decompress> returned error exit status 2
dkpg-deb (subprocess): cannot copy archive member from '/var/cache/apt/archives/bash_4.3-11+deb8u2_armhf.deb' to decompressor pipe: failed to write (Broken pipe)
dpkg-deb: error: `/var/cache/apt/archives/libcomerr2_1.43.3-1~bpo8+1_armhf.deb' is not a debian format archive
After this it just gets darker and repetitive. This is on a fresh replacement of the OS
Anyone take a guess at the likely culprit?
I'm guessing it's a hardware issue, probably the SD card itself gone dud?
Forgive me for not doing a proper copy paste of the errors, I had to type it by hand as the browser version that installs doesn't want to play ball on quite a few sites ( this version of safari is no longer supported ) and I can't install iceweasel because errors.
