taylorkh
No sound on Pi3b+
Fri Jan 11, 2019 10:05 pm
My first Pi 3B with Ubuntu Mate 16.04 played sound out of the audio jack with no issues that I can remember. I have a 3B+ also with Ubuntu Mate both 16.04 and 18.04 installs (different SD cards) and neither one of them will play sound. I have seen a lot of posts re. playing sound via HDMI but I am simply needing to use the audio port.
Sound preferences shows:
- Hardware tab
- - bcm2835 ALSA
- - choices of mono or stereo on 16.04, mono only on 18.04
- Output tab
- - Analog output
alsa-utils are installed and up to date
pulseaudio is also installed and up to date
Any suggestions? I can look at the 3B again but that is a bit problematic as it is my production gateway, route, firewall, dhcp and vpn sharing box.
TIA,
Ken
taylorkh
Re: No sound on Pi3b+
Sat Jan 12, 2019 12:32 am
I just tried a fresh install of Raspbian Stretch - same thing. I installed audacious and played an mp3 file. No sound output.
taylorkh
Sat Jan 12, 2019 12:58 am
It has been a long day... I did a search on configuring sound on the Pi and found the instructions https://www.raspberrypi.org/documentati ... -config.md which reminded me I needed to run raspi-config. I did that an am now listening to Metal Queen by Lee Aaron :mrgreen:
This issue is SOLVED.
