Glasairman
Re: WiFi ONLY works if Ethernet is plugged in
Sat Dec 23, 2017 10:06 pm
I found a simpler solution using systemd
In the file where the various interfaces are defined /etc/systemd/network , make sure the wlan0 file has a lower name that the eth0 file, as follows:
[email protected]:/etc/systemd/network$ ls 30-static-wireless.network 40-static.network 99-default.link
Now I don`t need the cable to start anymore!
SurferTim
Sat Dec 23, 2017 10:27 pm
I didn't need the cable any time. Wifi works with or without it.
rwe
Tue Feb 06, 2018 11:01 am
I have also been fighting this problem, and I have found the last solution given seems to fix it for me.
Here are the details:
Modify the file /lib/systemd/system/wpa_supplicant.service using your editor of choice.
change the line:
ExecStart=/sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
to include the -W option:
ExecStart=/sbin/wpa_supplicant -W -u -s -O /run/wpa_supplicant
This works for me and I no longer need an ethernet plugged in...
My system:
2017-11-29-raspbian-stretch.img
raspberry pi 2.
Have fun...
a-tibi
Fri Oct 12, 2018 3:37 am
giupo wrote:
Wed Jun 28, 2017 10:03 am
If anyone still has this issue, try to remove the "ip" definition in the "/boot/cmdline.txt"
Just my 2 cents,
Giuseppe
Thanks so much it solved my problem
