20sstevens
Gpio pins and pygame
Mon Jul 16, 2018 1:48 am
I've been trying to use a rotary switch to navigate menus in pygame and have been everything but successful. I've managed to use the switch in python just using the RPi GPIO module without pygame and the switch has worked so I know the pins/switch aren't my issues. I've tried binding the controls to the actual pins, using pikeyd and retrogame to emulate keypresses and using background scripts but they have either been unsuccessful or not achieving what I intended, such as pikeyd spamming the intended keypress. This issue has been bugging me for weeks and if anyone has any suggestions it would be much appreciated, thanks.
gordon77
Re: Gpio pins and pygame
Mon Jul 16, 2018 12:53 pm
Can you supply any of your code to see what you are doing ?
scotty101
Mon Jul 16, 2018 1:07 pm
I'd consider using your existing GPIO code to generate "custom" pygame events that can then be processed as part of the main game loop.
The answer to this question shows how to create custom events and how they are processed.
https://stackoverflow.com/questions/244 ... stom-event
This also shows a similar method to create a custom event
http://www.raspberry-pi-geek.com/Archiv ... e-programs
If your existing GPIO code to read the rotary switch uses callbacks, then you can create a function that generates an event when the switch is turned.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
20sstevens
Tue Jul 17, 2018 11:03 pm
Here is the main script which is just a slightly modified version of select none's code here: https://bitbucket.org/selectnone/raspipboy
# RasPipBoy: A Pip-Boy 3000 implementation for Raspberry Pi
#       Neal D Corbett, 2013
# Main file
import pygame, os, time, random, math, datetime
from pygame.locals import *
import config
from pipboy_gps import *
from pipboy_tab_stats import *
from pipboy_tab_items import *
from pipboy_tab_data import *
from pipboy_cmdline import *
# Load optional libraries: (these will have been tested by config.py)
if config.USE_SERIAL:
        global serial
        import serial
if config.USE_CAMERA:
        from pipboy_camera import *
def getTimeStr():
        curTime = time.localtime(time.time())
        curTimeStr = "%s.%s.%s, %s:%s" %(curTime.tm_mday, curTime.tm_mon, curTime.tm_year, curTime.tm_hour, '%02d' % curTime.tm_min, )
        return curTimeStr
class Engine:
        # Default page-settings:
        torchMode = False
        tabNum = 0
        modeNum = 0
        serBuffer = ""
        background = None
        def __init__(self, *args, **kwargs):
                if(config.USE_SERIAL):
                        self.ser = config.ser
                        True#self.ser.write("gaugeMode=2")
                print "Init pygame:"
                pygame.init()
                pygame.display.init()
                print "(done)"
                self.rootParent = self
                self.screenSize = (pygame.display.Info().current_w, pygame.display.Info().current_h)
                self.canvasSize = (config.WIDTH, config.HEIGHT)
                print 'Resolution: {0}x{1}'.format(self.screenSize[0], self.screenSize[1])
                print 'Canvas Size: {0}x{1}'.format(self.canvasSize[0], self.canvasSize[1])
                # Don't show mouse-pointer:
                pygame.mouse.set_visible(0)
                pygame.display.set_mode(self.screenSize)
                # Block queuing for unused events:
                pygame.event.set_blocked(None)
                for ev in (QUIT,KEYDOWN,MOUSEMOTION,MOUSEBUTTONDOWN):
                        pygame.event.set_allowed(ev)
                # Set up gps, clock, tab-list:
                self.gpsModule = GpsModuleClass()
                self.clock = pygame.time.Clock()
                        self.tabs = (Tab_Stats(self), VATS(self), Tab_Data(self))
                else:
                        self.tabs = (Tab_Stats(self), Tab_Items(self), Tab_Data(self))
                self.currentTab = self.tabs[self.tabNum]
                self.screen = pygame.display.set_mode(self.screenSize)
                self.background = config.IMAGES["background"]
                self.background = pygame.transform.smoothscale(self.background, self.canvasSize)
                # Lighten background:
                backAdd = 30
                self.background.fill((backAdd, backAdd, backAdd),None,pygame.BLEND_RGB_ADD)
                # Untextured background:
                self.background = pygame.Surface(self.canvasSize)
                greyback = 100
                self.background.fill((greyback,greyback,greyback))
                self.background = self.background.convert()
                # Scanlines:
                scanline = config.IMAGES["scanline"]
                lineCount = 60 # 48 60 80
                lineHeight = config.HEIGHT / lineCount
                scanline = pygame.transform.smoothscale (scanline, (config.WIDTH, lineHeight))
                self.scanLines = pygame.Surface(self.canvasSize)
                yPos = 0
                while yPos < config.HEIGHT:
                        self.scanLines.blit (scanline, (0, yPos))
                        yPos += lineHeight
                # Increase contrast, darken:
                self.scanLines.blit(self.scanLines, (0, 0), None, pygame.BLEND_RGB_MULT)
                #scanMult = 0.5
                scanMult = 0.7
                scanMultColour = (scanMult * 255, scanMult * 255, scanMult * 255)
                self.scanLines.fill(scanMultColour, None, pygame.BLEND_RGB_MULT)
                self.scanLines = self.scanLines.convert()
                # Start humming sound:
                if config.USE_SOUND:
                        hum = pygame.mixer.Sound('sounds/pipboy/ui_pipboy_hum_lp.wav')
                        config.SOUNDS["start"].play()
                        self.humSound = config.SOUNDS["hum"]
                        self.humSound.play(loops=-1)
                        self.humVolume = self.humSound.get_volume()
                # Set up data for generating overlay frames
                distortLine = config.IMAGES["distort"]
                distortLineHeight = (config.HEIGHT / 4)
                distortLine = pygame.transform.smoothscale (distortLine, (config.WIDTH, distortLineHeight))
                distortLine = distortLine.convert()
                distortY = -distortLineHeight
                distortSpeed = (config.HEIGHT / 40)
                self.overlayFrames = []
                print "START"
                cmdLine = CmdLineClass(self)
                bootPrintQueue = [
                        "WELCOME TO ROBCO INDUSTRIES (TM) TERMLINK",
                        ">SET TERMINAL/INQUIRE",
                        "RIT-V300",
                        ">SET FILE/PROTECTION=OWNER:RWED ACCOUNTS.F",
                        ">SET HALT RESTART/MAINT",
                        "Initializing Robco Industries(TM) MF Boot Agent v2.3.0",
                        "RETROS BIOS",
                        "RBIOS-4.02.08.00 52EE5.E7.E8",
                        "Copyright 2201-2203 Robco Ind.",
                        "Uppermem: 64 KB",
                        "Root (5A8)",
                        "Maintenance Mode",
                        ">RUN DEBUG/ACCOUNTS.F",
                        "**cls",
                        "ROBCO INDUSTRIES UNIFIED OPERATING SYSTEM",
                        "COPYRIGHT 2075-2077 ROBCO INDUSTRIES",
                # Print Robco boot-up text, interleaving lines with overlay-frame generation:
                lineNum = 0
                canPrint = True
                genOverlays = True
                while (canPrint or genOverlays):
                        willPrint = (lineNum < len(bootPrintQueue))
                        if canPrint:
                                thisLine = bootPrintQueue[lineNum]
                                cmdLine.printText(thisLine)
                                lineNum += 1
                                canPrint = (lineNum < len(bootPrintQueue))
                        # Generate overlays until all required frames are done:
                        if genOverlays:
                                if (distortY < config.HEIGHT):
                                        # Use scanlines as base:
                                        thisFrame = self.scanLines.convert()
                                        # Add animated distortion-line:
                                        thisFrame.blit(distortLine, (0, distortY), None, pygame.BLEND_RGB_ADD)
                                        # Tint screen:
                                        thisFrame.fill(config.TINTCOLOUR,None,pygame.BLEND_RGB_MULT)
                                        thisFrame = thisFrame.convert()
                                        self.overlayFrames.append(thisFrame)
                                        distortY += distortSpeed
                                else:
                                        genOverlays = False
                self.animDelayFrames = len(self.overlayFrames)
                self.overlayFramesCount = (2 * self.animDelayFrames)
                self.frameNum = 0
                print "END GENERATE"
                # Get coordinates:
                self.gpsModule.getCoords(cmdLine)
                # Initial map-downloads:
                cmdLine.printText(">MAPS.DOWNLOAD")
                cmdLine.printText("\tDownloading Local map...")
                        config.SOUNDS["tapestart"].play()
                self.rootParent.localMapPage.drawPage()
                cmdLine.printText("\tDownloading World map...")
                self.rootParent.worldMapPage.drawPage()
                        config.SOUNDS["tapestop"].play()
                cmdLine.printText(">PIP-BOY.INIT")
                # Show Pip-Boy logo!
                if (not config.QUICKLOAD):
                        self.showBootLogo()
                print "END INIT PROCESS"
                self.currentTab.resetPage(self.modeNum)
                tabCanvas, tabChanged = self.drawTab()
                self.screenCanvas = tabCanvas.convert()
                self.updateCanvas("changetab")
        # Show bootup-logo, play sound:
        def showBootLogo(self):
                bootLogo = pygame.image.load('images/bootupLogo.png')
                self.focusInDraw(bootLogo)
                        bootSound = pygame.mixer.Sound('sounds/falloutBootup.wav')
                        bootSound.play()
                pygame.display.update()
                pygame.time.wait(4200)
        # Do focus-in effect on a page:
        def focusInDraw(self, canvas):
                # Reset to first animation-frame:
                self.frameNum = 0
                def divRange(val):
                        while val >= 1:
                                yield val
                                val /= 2
                # Do focusing-in effect by scaling canvas down/up:
                maxDiv = 4
                hicolCanvas = canvas.convert(24)
                for resDiv in divRange(maxDiv):
                        blurImage = pygame.transform.smoothscale(hicolCanvas, (self.canvasSize[0] / resDiv, self.canvasSize[1] / resDiv))
                        blurImage = pygame.transform.smoothscale(blurImage, self.canvasSize)
                        # Add faded sharp image:
                        multVal = (255 / (1 * maxDiv))
                        drawImage = canvas.convert()
                        drawImage.fill((multVal, multVal, multVal), None, pygame.BLEND_RGB_MULT)
                        # Add blurred image:
                        drawImage.blit(blurImage, (0,0), None, pygame.BLEND_RGB_ADD)
                        #Add background:
                        if (self.background != None):
                                drawImage.blit(self.background, (0,0), None, pygame.BLEND_RGB_ADD)
                        # Add scanlines:
                        drawImage.blit(self.overlayFrames[0], (0,0), None, pygame.BLEND_RGB_MULT)
                        # Scale up and draw:
                        drawImage = pygame.transform.scale(drawImage, self.screenSize)
                        self.screen.blit (drawImage, (0,0))
        # Generate black&white outline-image:
        def updateCanvas(self, updateSound = None):
                if config.USE_SOUND and (updateSound != None):
                        config.SOUNDS[updateSound].play()
                # Do focus-in effect when changing tab (i.e. the lit buttons)
                if (updateSound == "changetab"):
                        self.focusInDraw(self.screenCanvas)
                # Bake the background into the canvas-image:
                        self.screenCanvas.blit(self.background, (0,0), None, pygame.BLEND_RGB_ADD)
        def drawAll(self):
                # Start with copy of display-stuff:
                #       (generated by updateCanvas)
                drawImage = self.screenCanvas.convert()
                # Don't tint camera-output if VATS mode is set to untinted:
                isVats = (self.currentTab.name == 'V.A.T.S.')
                if (not isVats) or (self.currentTab.showTint):
                        # Add scanlines/tint:
                        useFrame = 0
                        if (not isVats):
                                useFrame = (self.frameNum - self.animDelayFrames)
                                if (useFrame < 0):
                                        useFrame = 0
                        drawImage.blit(self.overlayFrames[useFrame], (0, 0), None, pygame.BLEND_RGB_MULT)
                # Make screen extra-bright in torch-mode:
                if(self.torchMode):
                        drawImage.fill((0, 128, 0), None, pygame.BLEND_ADD)
                # Vary hum-volume:
                        self.humVolume += (random.uniform(-0.05,0.05))
                        if (self.humVolume > config.MAXHUMVOL):
                                self.humVolume = config.MAXHUMVOL
                        else:
                                if (self.humVolume < config.MINHUMVOL):
                                        self.humVolume = config.MINHUMVOL
                        #print self.humVolume
                        self.humSound.set_volume(self.humVolume)
                self.frameNum += 1
                if (self.frameNum >= self.overlayFramesCount):
                        self.frameNum = 0
                        # Only print FPS every so often, to avoid slowing us down:
                        print ("FPS: " + str(self.clock.get_fps()))
        drawnPage = []
        def drawTab(self):
                pageNums = [self.tabNum,self.modeNum]
                tab = self.currentTab
                pageCanvas, pageChanged = tab.drawPage(self.modeNum)
                headerCanvas, headerChanged = tab.header.getHeader()
                differentPage = (self.drawnPage != pageNums)
                canvasChange = (pageChanged or headerChanged or differentPage)
                if(canvasChange):
                        #print ("%s tabChanged: Page:%s Head:%s Different:%s %s" %(tab.name, pageChanged, headerChanged, differentPage, str(pageNums)))
                        tab.canvas = pageCanvas.convert()
                        tab.canvas.blit(headerCanvas, (0,0), None, pygame.BLEND_ADD)
                        tab.canvas.blit(tab.footerImgs[self.modeNum], (0,0), None, pygame.BLEND_ADD)
                self.drawnPage = pageNums
                return tab.canvas, canvasChange
        def run(self):
                # Main Loop
                running = True
                while running:
                        tabWas = self.tabNum
                        modeWas = self.modeNum
                        torchWas = self.torchMode
                        moveVals = [0,0,0]
                        pageEvents = []
                        doUpdate = False
                        updateSound = None
                                # Run through serial-buffer characters, converting to pygame events if required:
                                ser = self.ser
                                serMouseDist = 10
                                try:
                                        while ser.inWaiting():
                                                char = ser.read(1)
                                                if ((char != '\n') and (char != '\r')):
                                                        self.serBuffer = (self.serBuffer + char)
                                                        #print char
                                                else:
                                                        serBuffer = self.serBuffer
                                                        #print serBuffer
                                                        if (serBuffer == 'lighton'): # Torch On
        self.torchMode = True
                                                        elif (serBuffer == 'lightoff'): # Torch Off
        self.torchMode = False
                                                        elif (serBuffer == '1'):
        self.tabNum = 0
                                                        elif (serBuffer == '2'):
        self.tabNum = 1
                                                        elif (serBuffer == '3'):
        self.tabNum = 2
                                                        elif (serBuffer == 'q'):
        self.modeNum = 0
                                                        elif (serBuffer == 'w'):
        self.modeNum = 1
                                                        elif (serBuffer == 'e'):
        self.modeNum = 2
                                                        elif (serBuffer == 'r'):
        self.modeNum = 3
                                                        elif (serBuffer == 't'):
        self.modeNum = 4
                                                        elif (serBuffer == 'select'): # Select
        pageEvents.append('sel')
                                                        elif (serBuffer == 'cursorup'): # List up
        moveVals[2] += 1
                                                        elif (serBuffer == 'cursordown'): # List down
        moveVals[2] -= 1
                                                        elif (serBuffer == 'left'): # Mouse left
        moveVals[0] -= serMouseDist
                                                        elif (serBuffer == 'right'):    # Mouse right
        moveVals[0] += serMouseDist
                                                        elif (serBuffer == 'up'):       # Mouse up
        moveVals[1] += serMouseDist
                                                        elif (serBuffer == 'down'):     # Mouse down
        moveVals[1] -= serMouseDist
                                                        elif (serBuffer.startswith('volts')):   # Battery Voltage
        pageEvents.append(serBuffer)
                                                        elif (serBuffer.startswith('temp')):    # Temperature
                                                        # Clear serial buffer:
                                                        self.serBuffer = ""
                                except:
                                        print ("Serial-port failure!")
                                        config.USE_SERIAL = False
                        # Run through Pygame's keyboard/mouse event-queue:
                        for event in pygame.event.get():
                                #print event
                                if event.type == pygame.QUIT:
                                        running = False
                                elif event.type == pygame.MOUSEBUTTONDOWN:
                                elif event.type == pygame.MOUSEMOTION:
                                        mx, my = pygame.mouse.get_rel()
                                        moveVals[0] += mx
                                        moveVals[1] += my
                                elif event.type == pygame.KEYDOWN:
                                        if event.key == pygame.K_ESCAPE:
                                                running = False
                                        elif event.key == pygame.K_o: # Torch On
                                        elif event.key == pygame.K_p: # Torch Off
                                        elif event.key == pygame.K_1:
                                                self.tabNum = 0
                                        elif event.key == pygame.K_2:
                                                self.tabNum = 1
                                        elif event.key == pygame.K_3:
                                                self.tabNum = 2
                                        elif event.key == pygame.K_q:
                                                if self.modeNum > 0:
                                                        self.modeNum -= 1
                                        elif event.key == pygame.K_w:
                                                if self.modeNum < 4:
                                                        self.modeNum += 1
                                        #elif event.key == pygame.K_e:
                                        #       self.modeNum = 2
                                        #elif event.key == pygame.K_r:
                                        #       self.modeNum = 3
                                        #elif event.key == pygame.K_t:
                                        #       self.modeNum = 4
                                        elif event.key == pygame.K_RETURN:
                                        elif event.key == pygame.K_UP: # List up
                                                moveVals[2] += 1
                                        elif event.key == pygame.K_DOWN: # List down
                                                moveVals[2] -= 1
                        if (moveVals != [0,0,0]):
                                pageEvents.append(moveVals)
                        changedTab = (self.tabNum != tabWas)
                        changedMode = (self.modeNum != modeWas)
                        changedTorch = (self.torchMode != torchWas)
                        if(changedTorch):
                                if(self.torchMode):
                                        updateSound = "lighton"
                                else:
                                        updateSound = "lightoff"
                        if(changedTab):
                                updateSound = "changetab"
                        doUpdate = (changedTorch or changedTab or changedMode)
                        if(doUpdate):
                        # Update current tab, see if it's changed:
                        if doUpdate or tabChanged:
                                # updateCanvas will add background to this:
                                doUpdate = True
                        if(doUpdate or (updateSound != None)):
                                self.updateCanvas(updateSound)
                        if (len(pageEvents) != 0):
                                self.currentTab.ctrlEvents(pageEvents,self.modeNum)
                        self.drawAll()
                        self.clock.tick(config.FPS)
                        self.ser.close()
                pygame.quit()
if __name__ == '__main__':
        engine = Engine()
        engine.run()
