I have been using my Pi3 happily for years now. Then I recently decided to update some projects to Pi3b+ boards in search of that small CPU power advantage, but I am finding a very annoying problem regarding ethernet connection. I am using the same sd card on both the Pi3 and the Pi3b+.
I have already updated the Raspbian system to the latest stable versions of the firmware and kernel before coming here to ask for help, by doing:
sudo apt update && sudo apt full-upgrade -y
The network connection on my Pi systems is NOT managed by systemd, instead it's manually configured by me with this simple sequence of commands in a bash script I run whenever I need to access the board via ssh, etc. No X server or networking services are active. Just simple manual configuration like this:
# Up with the ethernet and ssh!
sudo ifconfig eth0 up
sudo ip addr add 192.168.5.8/24 dev eth0
sudo ip route add default via 192.168.5.7
sudo /etc/init.d/dropbear start > /dev/null 2>&1
And now for the funny part: If I ping the PC from the Pi3b+, then I can ping the Pi3+ from the PC back!!!
That's crazy, I know. Never encountered anything like this before. It's as if pinging from the Pi3b+ would be activating something that does not need to be activated on a plain Pi3...
Any idea on what's going on here?
NOTE: I am using the vc4 plan kms overlay. I don't think it's related, but.. just in case.
