photopuppet
Root needed for Raspbian software manager
Thu Apr 26, 2018 8:57 am
Hi everyone and thanks for any help in advance...
I'm having a little issue with the software manager in the Raspbian (squeeze) desktop, every time I try to install anything the package manager wants to use root identity for authentication and I can't find any way to get around it.
I have the root password disabled and use sudo normally. Is there any way to get the manager to use sudo for elevated privileges instead as I can't install things through this unless I make a root pass?
Apt-get works fine through sudo but I just wanted to get the GUI manager working properly. I've tried searching this issue but no luck. :)
Thank you!
B.Goode
Re: Root needed for Raspbian software manager
Thu Apr 26, 2018 9:18 am
I'll ask, because someone is bound to -
Why do you need to persist with running a long-superceded version of the Raspbian Operating System?
I'm pretty sure software installation works relatively smoothly with current and recent releases of Raspbian and the associated Desktop. Although personally I am comfortable with the shell and the apt family of tools for software package maintenance.
klricks
Thu Apr 26, 2018 12:23 pm
Why not enable root password?
You did not mention which package manager you are using....
Have you tried using sudo to start the PM from command line
sudo aptitude
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
photopuppet
Thu Apr 26, 2018 6:01 pm
Apologies, I mean Raspbian Stretch! Whatever the latest edition is on this site? :)
I'm talking about the default package manager... The one that appears when you go to Add/Remove Programs in the desktop.
When you select something to install, it comes up with an authorization box that has Root in the selection but I can't go any further as there isn't a root password and there aren't any other choices apart from root in the box?
I've been told before that it wasn't a good idea to have a root password set if you have no reason to use it and use sudo for root operations normally. I thought Raspbian normally installs with no root pass set. It is fine to just have a root pass set all the time normally?
Thanks for the help :)
mattmiller
Thu Apr 26, 2018 6:38 pm
When you select something to install, it comes up with an authorisation box that has Root in the selection
I've never used the GUI version before but when I tried it out just now, I was asked for the pi user password not the root user
I just installed gparted using this method and it works fine
This is on a 2018-04-18 Raspbian stretch setup
photopuppet
Thu Apr 26, 2018 6:42 pm
Thanks Matt... I did change the username from pi to something else... Wonder if I messed something up by doing that. :(
klricks
Thu Apr 26, 2018 7:25 pm
Make sure the new user is a member of all the same groups as pi:
[email protected]:~ $ groups pi
pi : pi adm dialout cdrom sudo audio video plugdev games users input netdev spi i2c gpio
photopuppet
Thu Apr 26, 2018 10:31 pm
Thanks for the help. You're right, with further research it does seem like the groups (or secondary groups??) get messed up somehow if you change the name. I couldn't figure it out even though 'groups photopuppet' seemed to show the same groups as you put, klricks.
I changed the username back to pi again with the same method as I used originally to change it and now the GUI package manager works as it should do and how matt described it.
I guess its best just to keep the default pi username and keep it secure using a key pair. :)
Thanks to everyone for your advice!
klricks
Fri Apr 27, 2018 1:43 am
I prefer to use Synaptic PM as the default PM is lacking much function.
sudo apt update
sudo apt install synaptic
photopuppet
Fri Apr 27, 2018 3:04 am
I've installed Synaptic now and it has quite a few more features. Thank you for the tip. :)
