junglejunkey
Using Pi3 microSD on Pi3+
Sun Apr 15, 2018 9:43 am
Hey folks,
I wanted to use my SD card, which is running since 2 years now on a pi3 on my pi3+
so i updated and upgraded via apt-get. haltet my pi, removed the sd, put it in pi3+ and when i try to power it on the red onboard LED starts flashing.
what did i do wrong?
i early set up a clean new raspbian on my pi3+ and it worked perfectly fine, but i want to keep all my data in a 1:1 copy from the pi3.
thanks
greetings
B.Goode
Re: Using Pi3 microSD on Pi3+
Sun Apr 15, 2018 2:31 pm
What Operating System (named version or download date) do you have on the card that works in your old RPi?
hippy
Sun Apr 15, 2018 2:44 pm
Did you install to your original Pi 3 using NOOBS ?
Did you search the forum for other answers to your question ?
junglejunkey
Sun Apr 15, 2018 6:27 pm
currently i am running:
Linux PiVPN 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
Jul  3 2017 14:16:43
Copyright (c) 2012 Broadcom
version 4139c62f14cafdb7d918a3eaa0dbd68cf434e0d8 (tainted) (release)
i installed the raspbian image back then.
yes i tried to search for something but didnt match anything thats helpful for me also i didnt really know which words to use for the seachbox
gkaiseril
Sun Apr 15, 2018 6:46 pm
Jessie is very old and has been replaced by Stretch. You need to download the 2018-03-19 version and move it onto a new 8GB or larger micro SC card.
You could try to update the distribution but it is more complicated than just running the dist-upgrade since you will need to also update the packages repositories.
Sun Apr 15, 2018 11:18 pm
VERSION_ID="8"
ID=raspbian
ID_LIKE=debian
Jul  3 2017 14:16:43
Jessie is end of life and pre-dates the 3B+ by 6+ months.
If you did not use NoobS to install Jessie youu will need to put SD Card back in 3B and:
sudo apt-get update
sudo apt-get dist-upgrade
sudo rpi-update
sudo reboot
If you use NoobS good luck !!
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
junglejunkey
Mon Apr 16, 2018 7:04 pm
[email protected]:~ $ sudo apt-get update
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Reading package lists... Done
[email protected]:~ $ sudo apt-get dist-upgrade
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[email protected]:~ $ sudo rpi-update
sudo: rpi-update: command not found
What to do now?
Mon Apr 16, 2018 9:53 pm
What to do now?
sudo apt-get install rpi-update
adieu
junglejunkey
Sat Apr 21, 2018 6:43 am
Still got a red flashing LED.
Thank you so far.
drgeoff
Sat Apr 21, 2018 2:38 pm
Run the RPI3B+ from the new SD card that you say works OK. Put the old card in a USB card reader and plug it into one of the USB ports of the RPi3B+. Copy what you need from old card to new card.
junglejunkey
Mon Apr 23, 2018 7:46 am
thank you, that worked much better than expected.
