CaptOveur
Can't get full 0-255 color from RasPlex
Sun Oct 08, 2017 5:29 pm
Not sure if this is the correct place to post this.
I just set up a Pi 3 with RasPlex 1.8.0. It's working flawlessly other that it doesn't seem to want to run on anything but limited 16-235 color.
I have tried entering hdmi_pixel_encoding=2 and =4 into the config file. And plugged the Pi into two different TVs. But when viewing AVS HD 709 test patterns its still clipping the blacks/whites.
When I run "vcgencmd get_config int" I get the following.
RasPlex (official) Version: 1.8.0.148-573b6d73
RasPlex git: e2efbe6dff28a97ec76f0db00073fa3d00b45584
RasPlex:~ # vcgencmd get_config int
arm_freq=1200
audio_pwm_mode=1
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x36ee80
disable_commandline_tags=2
disable_l2cache=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_drive=2
hdmi_force_cec_address=65535
hdmi_force_hotplug=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=0x1b774
over_voltage_avs_boost=0x1b774
overscan_bottom=48
overscan_left=48
overscan_right=48
overscan_top=48
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
temp_limit=85
Suggestions?
CaptOveur
Re: Can't get full 0-255 color from RasPlex
Mon Oct 09, 2017 1:31 am
I just ran the "tvservice -s" command and go the following
state 0x12000a [HDMI CEA (16) YCbCr444 full 16:9], 1920x1080 @ 60.00Hz, progress
To me that means it should be displaying the full 0-255 range. But when looking at test patterns it is still clipping.
And here's the edid info if it's helpful.
RasPlex:~ # tvservice -d edid.dat; edidparser edid.dat
Written 256 bytes to edid.dat
Enabling fuzzy format match...
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, screen size 104x58 cm
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 50-77 Hz, horizontal is 31-70 kHz, max pixel clock is 150 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found monitor S/N descriptor tag 0xff
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is M470NV
HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID established timing I/II bytes are A5 CE 00
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz (native)
HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
HDMI:EDID found audio format 2 channels AC3, sample rate: 32|44|48 kHz, bitrate: 448 kbps
HDMI:EDID found HDMI VSDB length 7
HDMI:EDID HDMI VSDB has physical address 4.0.0.0
HDMI:EDID HDMI VSDB supports AI:no, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:no DC_yuv444:yes
HDMI:EDID HDMI VSDB max TMDS clock 225 MHz
HDMI:EDID HDMI VSDB has no latency information
HDMI:EDID adding mandatory support for CEA (2) 720x480p @ 60Hz
HDMI:Warning EDID must support pcm or no audio
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 61864)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 66472)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 4135592)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID CEA mode (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz has a score of 149416
HDMI:EDID DMT mode (6) 640x480p @ 75 Hz with pixel clock 31 MHz has a score of 23040
HDMI:EDID DMT mode (9) 800x600p @ 60 Hz with pixel clock 40 MHz has a score of 28800
HDMI:EDID DMT mode (10) 800x600p @ 72 Hz with pixel clock 50 MHz has a score of 34560
HDMI:EDID DMT mode (11) 800x600p @ 75 Hz with pixel clock 49 MHz has a score of 36000
HDMI:EDID best score mode is now CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz (score 5398248)
HDMI:EDID DMT mode (16) 1024x768p @ 60 Hz with pixel clock 65 MHz has a score of 47185
HDMI:EDID DMT mode (17) 1024x768p @ 70 Hz with pixel clock 75 MHz has a score of 55050
HDMI:EDID DMT mode (18) 1024x768p @ 75 Hz with pixel clock 78 MHz has a score of 58982
HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score of 124532
HDMI:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz
HDMI:EDID has HDMI support and audio support
edid_parser exited with code 0
CaptOveur
Fri Oct 13, 2017 4:32 am
Bueller?
I spent hours messing with various config settings without any luck....
Who is online
Users browsing this forum: wildfire and 50 guests
