bhl88
Unable to login, screen turns black when I login and goes back
Thu Oct 12, 2017 11:03 pm
Raspberry Pi 3 16 GB card
Login as admin
Screen turns black
Returns to login screen
asandford
Re: Unable to login, screen turns black when I login and goes back
Fri Oct 13, 2017 12:41 am
Login as admin
Screen turns black
Is there a user called admin? The default user is pi.
B.Goode
Fri Oct 13, 2017 7:24 am
Is this the same RPi that previously had a White login screen?
viewtopic.php?f=91&t=194715&p=1221067#p1219045
Neither situation is expected or normal.
Your reference to 'admin' might be a clue...
Trying to start the GUI Desktop as 'root' - the administrator or superuser - is in general Not A Good Idea, and will change the permissions on vital files such that the system will no longer boot up cleanly.
To repeat the query implied in the reply in the previous post: what are you doing to get into this situation. Starting from a fresh installation of 2017-09-07-raspbian-stretch, what steps would we need to take to recreate the issue you are seeing?
bhl88
Fri Oct 13, 2017 7:41 pm
Nvm I found out that rm /home/(insert user)/.XAuthority or mv /home/(insert user)/.XAuthority /home/(insert user)/.XAuthority-backup works
As for pi being removed, I checked how to secure Linux and it ended up with removing the default user.
asandford
Sun Oct 15, 2017 1:59 am
So, you ask a question without mentioning a whole lot of other stuff you'd done...
Who is online
Users browsing this forum: No registered users and 24 guests
