g8gkq
No OpenVG in Raspbian Stretch Lite? Solved
Wed Oct 11, 2017 7:35 pm
I (and about 200 others) have been using OpenVG graphics on a headless RPi running Jessie Lite with a touchscreen to control a Digital Amateur Television Transmitter for a year or so. We realise that sooner or later we are going to have to migrate to Stretch and I have started testing.
I can't seem to find the components that I need for OpenVG in either the Desktop or Lite versions of Stretch (we will end up using the Lite version). One cause of the problem appears to be that libOpenVG.so and a number of other files are not included in /opt/vc/lib/. This means that when I come to compile I get errors such as :
libshapes.o: In function `loadfont':
libshapes.c:(.text+0x1c0): undefined reference to `vgCreatePath'
libshapes.c:(.text+0x1e4): undefined reference to `vgAppendPathData'
I have already changed the makefile to use -lbrcmEGL -lbrcmGLESv2 rather than -lEGL and -lGLESv2
Is there a package that I can load to install the OpenVG library files? Or am I missing something else obvious?
Thanks for any suggestions
Dave
Project Lead for the Portsdown DATV Transmitter: https://github.com/BritishAmateurTelevisionClub/rpidatv
topguy
Re: No OpenVG in Raspbian Stretch Lite?
Wed Oct 11, 2017 8:18 pm
Small tips on how to solve similar problems...
Step 1: Which header file defines the function we are missing ?
[email protected]:/ $ cd /opt/vc/include/
[email protected]:/opt/vc/include $ rgrep vgCreatePath .
./VG/openvg.h:VG_API_CALL VGPath VG_API_ENTRY vgCreatePath(VGint pathFormat,
Ok, so "openvg.h" it is..
Step 2: Which library file can be suitable ?
[email protected]:/opt/vc/include $ cd /opt/vc/lib/
[email protected]:/opt/vc/lib $ ls
libbcm_host.so    libdebug_sym.so        libGLESv1_CM.so        libmmal_core.so       libvcfiled_check.a  libWFC.so
libbrcmEGL.so     libdebug_sym_static.a  libGLESv2.so           libmmal.so            libvchiq_arm.so     plugins
libbrcmGLESv2.so  libdtovl.so            libGLESv2_static.a     libmmal_util.so       libvchostif.a
libbrcmOpenVG.so  libEGL.so              libkhrn_client.a       libmmal_vc_client.so  libvcilcs.a
libbrcmWFC.so     libEGL_static.a        libkhrn_static.a       libopenmaxil.so       libvcos.so
libcontainers.so  libelftoolchain.so     libmmal_components.so  libOpenVG.so          libvcsm.so
hmm.. this libOpenVG looks promising considering the name of the headerfile...
Step 3 : Can we check which functions are in a library ?
Yes we can.
[email protected]:/opt/vc/lib $ nm libOpenVG.so | grep vgCreatePath
00008ac0 T vgCreatePath
So I would make sure that "-L/opt/vc/lib -lOpenVG" is part of my compiler options.
Also tip if you are unsure which package a file belongs to:
[email protected]:/opt/vc/lib $ dpkg -S libOpenVG.so
libraspberrypi0: /opt/vc/lib/libOpenVG.so
[email protected]:/opt/vc/lib $ dpkg -l | grep libraspberrypi0
ii  libraspberrypi0                1.20170703-1                      armhf        EGL/GLES/OpenVG/etc. libraries for the Raspberry Pi's VideoCore IV
g8gkq
Re: No OpenVG in Raspbian Stretch Lite? Solved
Wed Oct 11, 2017 9:34 pm
@topguy Thanks very much - you led me to the solution:
libOpenVG.so is not included in Raspbian Stretch, but I did notice a file called libbrcmOpenVG.so in /opt/vc/lib. Running:
[email protected]:/opt/vc/lib $ nm libbrcmOpenVG.so | grep vgCreatePath
00008ac8 T vgCreatePath
showed that this file was promising.
In another post, I found that someone had solved a similar issue by creating a symlink of /usr/lib/arm-linux-gnueabihf/libOpenVG.so to this file. So I ran
[email protected]:/usr/lib/arm-linux-gnueabihf $ sudo ln -s /opt/vc/lib/libbrcmOpenVG.so libOpenVG.so
I also changed all the lines in my makefile that read
LIBFLAGS=-L/opt/vc/lib -lEGL -lGLESv2 -ljpeg
to
LIBFLAGS=-L/opt/vc/lib -lbrcmEGL -lbrcmGLESv2 -ljpeg
With those changes, the compile ran without errors and the touchscreen OpenVG graphics are now working.
Thanks again
Dave
topguy
Thu Oct 12, 2017 9:59 am
I was pretty sure I was running on Raspbian Stretch Lite too and when I look back at my I see I have both "libbrcmOpenVG.so" and "libOpenVG.so" in the directory. So I had already made that symlink at some point but just didn't realise it.
g8gkq
Thu Oct 12, 2017 4:18 pm
Is your symlink in the /opt/vc/lib/ folder or the /usr/lib/arm-linux-gnueabihf folder?
Dave
topguy
Fri Oct 13, 2017 2:13 pm
NO links to anything in "/usr/lib/arm-linux-gnueabihf" from "/opt/vc", that will very quickly break stuff. (IMO)
Its also possibly the reason they renamed the libs to include "brcm" because it caused confusion with duplicate named Mesa libraries.
g8gkq
Fri Oct 13, 2017 2:21 pm
Thanks! I'll change it.
Dave
Who is online
Users browsing this forum: billgufran, Google [Bot] and 35 guests
