edwardattardmontalto
CRON scheduler runs - but nothing happens
Wed Sep 13, 2017 4:10 pm
I am using a python script that reads the tempreature from a temprature prob and then spins a motor based on the tempreature. Once thats done, I log that the motor has spun into a log file. The pi is the model 2B and is NOT connected to wifi. Code below:
# -*- coding: utf-8 -*-
import MotorControl
import RPi.GPIO as GPIO
import datetime
import os
import glob
import collections
import subprocess
##Sets up GPIO pins for motor
def establishMotorPins():
    ##Setting up pins and enabling the motor
    MotorControl.setUpGPIOPins(27, 24, 5)
    GPIO.output(5, GPIO.HIGH)
##Spins the motor - feeding the fish
def feedFish(duration):
    ##print("Feedig time!")
    MotorControl.motorCycle(27, 24, 'c', duration) #c standing for clockwise
##Write to a log file
def writeToFile(t, s):
    logFile.write("\nFish have been fed on: " + str(datetime.datetime.now()) +
                  " Tempreature is (°C): " + str(t) + " Speed: " + s)
    logFile.flush()
    os.fsync(logFile.fileno())
##Reading tempreature from sensor (tempreature is stored in file)
def read_temp_raw():
    catdata = subprocess.Popen(['cat',device_file], stdout=subprocess.PIPE, stderr=subprocess.PIPE)
    out,err = catdata.communicate()
    out_decode = out.decode('utf-8')
    lines = out_decode.split('\n')
    return lines
##Extracting tempreature from reading stored in text file
def read_temp():
    lines = read_temp_raw()
    while lines[0].strip()[-3:] != 'YES':
        time.sleep(0.2)
    equals_pos = lines[1].find('t=')
    if equals_pos != -1:
        temp_string = lines[1][equals_pos+2:]
        temp_c = float(temp_string)/1000.0
        temp_f = temp_c*9.0/5.0 + 32.0
        return temp_c #include ,temp_f to return temp F
##Defining a function as my main method
def main():
    temp = read_temp()
    if(temp >= 0 and temp <= 5):
        feedFish(0.5)
        speed = "a"
    elif(temp > 5 and temp <= 10):
        feedFish(0.5)
        speed = "b"
    elif(temp > 10 and temp <= 15):
        feedFish(1)
        speed = "c"
    elif(temp > 15 and temp <= 20):
        feedFish(2)
        speed = "d"
    elif(temp > 20 and temp <= 25):
        feedFish(3)
        speed = "e"
    elif(temp > 25 and temp <= 30):
        feedFish(4)
        speed = "f"
    elif(temp > 30 and temp <= 35):
        feedFish(4.5)
        speed = "f"
    elif(temp > 35 and temp <= 40):
        feedFish(5)
        speed = "g"
    elif(temp > 40):
        feedFish(5)
        speed = "h"
    writeToFile(temp, speed)
##Calling the pre-defined functions
##Setting up connection to the tempreature sensor
os.system('modprobe w1-gpio')
os.system('modprobe w1-therm')
base_dir = '/sys/bus/w1/devices/'
device_folder = glob.glob(base_dir + '28*')[0]
device_file = device_folder + '/w1_slave'
##Setting up a log file
logFile = open("/home/pi/Desktop/AutomaticFishFeeder/log.txt", "a") ##use w to write or a to append to file
try:
    ##remember to change direction of spin!!!!!
    main()
    GPIO.output(5, GPIO.LOW)
    quit()
except KeyboardInterrupt:
    print("keyboard interrupt detected, program will exit")
except SystemExit:
    print("SystemExit exception caught, program has terminated.")
finally:
    logFile.close()
    GPIO.cleanup()
I am using cron scheduler to run this script twice a day, once at 9am and once at 4pm. The script ran this morning at 9am but nothing happened at 4pm. I've checked the raspbery pis log and at 4pm there is an entry in the pi's log that look like the following: Sep 13 16:00:01 raspberrypi
CRON[16792]: (pi) CMD (python ~/Desktop/AutomaticFishFeeder/CronSchedule.py # JOB_ID_3)
The exact same line appears in the raspberry pis logs at 9am aswell, and the log file I use to register when the motor spins does not record anything at 4pm. I used the GUI helper from cron and both entrys say that the script will be run at 9am and 4pm each day.
Any ideas? Could the pi be faulty?
Silverlock
Re: CRON scheduler runs - but nothing happens
Wed Sep 13, 2017 4:20 pm
Is there a ~ in the command line in the crontab file? If so, try replacing it with /home/pi (or whichever user you're running this command under).
RPi3+external HDD/Raspbian/Pixel desktop
pcmanbob
Wed Sep 13, 2017 9:03 pm
If your Cron job runs at 9 but not at 4 the problem might be in your Cron file
Post your Cron file so we can see what you have as entries for each time
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
Fri Sep 15, 2017 6:37 am
Yes there is, I've replaced it with /home/pi for both the path of the python script and the path to python itself. Thanks, hopefully it works now :D
Fri Sep 15, 2017 6:40 am
Hi, contents of the cron file look like:
* 9 * * * python /home/pi/Desktop/AutomaticFishFeeder/CronSchedule.py
* 16 * * * python /home/pi/Desktop/AutomaticFishFeeder/CronSchedule.py
So the only difference is that one is set for 9 and the other 16
pcmanbob
Fri Sep 15, 2017 11:38 am
Well I would have thought you should have had a minute figure in the as well if you only wanted it to run once at 9am and once at 4pm
try running with just one cron line like this
 0 9,16 * * * python /home/pi/Desktop/AutomaticFishFeeder/CronSchedule.py
or if you want to use 2 cron line then this
 0 9 * * * python /home/pi/Desktop/AutomaticFishFeeder/CronSchedule.py
 0 16 * * * python /home/pi/Desktop/AutomaticFishFeeder/CronSchedule.py
I always find this site helpful when setting up cron times https://crontab-generator.org/
SkyRise
Fri Sep 15, 2017 12:57 pm
You might also need to put in
/path/to/python
Fri Sep 15, 2017 2:05 pm
Copied your code exactly, even included the full path to python on my machine, and the motor still hasn't spun. Any other ideas?
Fri Sep 15, 2017 2:06 pm
/path/to/python
Change the cron to do that now, still doesn't work
SkyRise
Fri Sep 15, 2017 2:10 pm
Just to be clear, which crontab are you editing and how are you doing it?
Fri Sep 15, 2017 2:13 pm
Do you mean which entry in the crontab? if so both of them have been updated to the root of python on the pi. Again today it worked at 9 and not at 16
SkyRise
Fri Sep 15, 2017 2:24 pm
Is the one at 4pm the last thing in the file? Is there a newline at the end (i.e. is there a blank line following the 4pm one?)
I have seen some programs which require a newline to terminate the last line or they don't function correctly. It is a long-shot though
pcmanbob
Fri Sep 15, 2017 2:27 pm
Well seeing as you updated cron and posted back at 15:05 it wont do any thing until 4pm or 9am tomorrow because that is the time you asked for it to run at.
Fri Sep 15, 2017 3:52 pm
I posted back at 16:05 my time
pcmanbob
Fri Sep 15, 2017 6:00 pm
OK .
So assuming your program actually works if you run it from the command line.
try setting your cron up like this and then leave you pi alone till after 4pm tomorrow
then post back the contents of /home/pi/log.txt
0 9 * * * date >>/home/pi/log.txt
0 9 * * * python /home/pi/Desktop/AutomaticFishFeeder/CronSchedule.py >>/home/pi/log.txt 2>&1
0 16 * * * date >>/home/pi/log.txt
0 16 * * * python /home/pi/Desktop/AutomaticFishFeeder/CronSchedule.py >>/home/pi/log.txt 2>&1
what this will do is post the time and date to the log file then it will post any output from your program to the log file including any errors.
it might be a good idea to un-comment any print statements in your program like the one that says feeding time and may be add one that prints the duration and in the main loop to print temp and speed.
this then might give us some indication of what's happening.
Sat Sep 16, 2017 7:57 am
OK .
Ok great thanks, script worked this morning at 9am. Here are the contents of the /home/pi/log.txt file:
Sat 16 Sep 09:00:01 CEST 2017
sh: 1: modprobe: not found
And here are the contents of my log.txt file, showing that the script ran properly at 9:00
Fish have been fed on: 2017-09-16 09:00:06.036100 Tempreature is (°C): 24.875 S$
I'll post the contents of both files again at 16:00, thank you very much for your help :D
rpdom
Sat Sep 16, 2017 8:12 am
Regarding the "modprobe not found" errors, perhaps you should put the full path to the modprobe command in your script: /sbin/modprobe, although I'm not sure why you are using that. Can you post the contents of the script?
[edit]
Ah, you have already done that.
These lines
should not be needed. Get rid of them. I think you have been following some old instructions. All you need to get the temperature sensor working is one line in /boot/config.txt
dtoverlay=w1-gpio
Sat Sep 16, 2017 8:17 am
Ok sure, script is below. I am using modprobe in order to interface the temperature sensor. Although it managed to read the temperature anyway ... :?:
import MotorControl
import datetime
import os
import glob
import collections
import subprocess
    logFile.flush()
    return lines
def read_temp():
        time.sleep(0.2)
def main():
    try:
        temp = read_temp()
    except:
        feedFish(3.5)
        speed="ERROR"
        return;
        feedFish(0.5)
        speed = "a"
        feedFish(0.5)
        speed = "b"
        feedFish(1)
        speed = "c"
        feedFish(2)
        speed = "d"
        feedFish(3)
        speed = "e"
        feedFish(4)
        speed = "f"
        feedFish(4.5)
        speed = "f"
        feedFish(5)
        speed = "g"
    elif(temp > 40):
        feedFish(5)
        speed = "h"
try:
    main()
    quit()
except SystemExit:
finally:
    logFile.close()
    GPIO.cleanup()
Sat Sep 16, 2017 8:49 pm
If you add that one line (as noted by Dom here posting.php?mode=reply&f=28&t=193177#pr1211609) to /boot/config.txt you can completely remove any trace of running /usr/bin/sudo /sbin/modprobe from your python program.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
Tue Sep 19, 2017 9:30 am
Ok so it turns out the issue was originating from the modprobe packages. Removed both of them and now everything works perfectly well! Thank you all very much for your advice :D 8-)
Martin Frezman
Tue Sep 19, 2017 11:57 am
Funny how that works...
If this post appears in the wrong forums category, my apologies.
Who is online
Users browsing this forum: shashank0129 and 46 guests
