SurferTim
Re: port forwarding
Sun Jun 18, 2017 6:16 pm
If that is the correct IP, it doesn't even respond to a ping.
Re: port forwarding
Sun Jun 18, 2017 6:24 pm
Can you try
traceroute -n 8.8.8.8
and post the results on here.
Can you try running this python3 program
#!/usr/bin/python3
import socket
import os
testIP = "8.8.8.8"
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.connect((testIP, 0))
ipaddr = s.getsockname()[0]
host = socket.gethostname()
print ("IP:", ipaddr, " Host:", host)
import urllib.request
hp = urllib.request.urlopen("http://"+ipaddr+"/")
print (hp.reason)
print (hp.status)
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3B*3, 3B+
Please post ALL technical questions on the forum. Do not send private messages.
hockeydudesdad
Re: port forwarding
Sun Jun 18, 2017 8:45 pm
I decided to try using my modem instead I have a tp-link tc-7610 does anybody know if it's possible to set up port forwarding on this?????
SurferTim
Re: port forwarding
Sun Jun 18, 2017 9:35 pm
If the TP-Link router gets an IP from the modem, then yes, you can. Set the RPi to dhcp and see what IP it gets.
hockeydudesdad
Re: port forwarding
Mon Jun 19, 2017 1:22 am
Ok how do I set it to dhcp???
SurferTim
Re: port forwarding
Mon Jun 19, 2017 1:28 am
Remove the static settings in /etc/dhcpcd.conf.
hockeydudesdad
Re: port forwarding
Mon Jun 19, 2017 3:13 am
I got the results for Dougie Lawson's python3 code but I am having a hard time uploading the file
hockeydudesdad
Re: port forwarding
Mon Jun 19, 2017 1:58 pm
results from Dougie lawsons previous post hope this helps
IP: 192.168.0.104 Host: raspberrypi
File "/usr/lib/python3.4/urllib/request.py", line 1174, in do_open
h.request(req.get_method(), req.selector, req.data, headers)
File "/usr/lib/python3.4/http/client.py", line 1090, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.4/http/client.py", line 1128, in _send_request
self.endheaders(body)
File "/usr/lib/python3.4/http/client.py", line 1086, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.4/http/client.py", line 924, in _send_output
self.send(msg)
File "/usr/lib/python3.4/http/client.py", line 859, in send
self.connect()
File "/usr/lib/python3.4/http/client.py", line 836, in connect
self.timeout, self.source_address)
File "/usr/lib/python3.4/socket.py", line 509, in create_connection
raise err
File "/usr/lib/python3.4/socket.py", line 500, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File "/home/pi/Austin .py", line 12, in <module>
File "/usr/lib/python3.4/urllib/request.py", line 153, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.4/urllib/request.py", line 455, in open
response = self._open(req, data)
File "/usr/lib/python3.4/urllib/request.py", line 473, in _open
'_open', req)
File "/usr/lib/python3.4/urllib/request.py", line 433, in _call_chain
result = func(*args)
File "/usr/lib/python3.4/urllib/request.py", line 1202, in http_open
return self.do_open(http.client.HTTPConnection, req)
File "/usr/lib/python3.4/urllib/request.py", line 1176, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 111] Connection refused>
Re: port forwarding
Mon Jun 19, 2017 5:08 pm
Your Raspberry isn't running a web server on port 80 if you get ERRNO 111. My python3 program gets the IP address for your RPi, then attempts to fetch the web-server's home page from that address.
MQTT Evangelist
hockeydudesdad
Re: port forwarding
Mon Jun 19, 2017 6:27 pm
Ok Does my windows firewall have anything to do with this??? because I think it's blocking everything and I don't know how to access it
B.Goode
Re: port forwarding
Mon Jun 19, 2017 6:41 pm
hockeydudesdad wrote:Does my windows firewall have anything to do with this???
You will have to tell us, because you haven't mentioned a Windows system previously as far as I can see.
I thought you wanted the Rest of The World to be able to access your RPi by setting up port forwarding on your Internet router?
Can you provide a word sketch of how your Windows system fits into your network topology, and how it would affect traffic flowing to and from your RPi?
Re: port forwarding
Mon Jun 19, 2017 8:35 pm
Is it safe to assume you ran my python3 program on your Raspberry?
MQTT Evangelist
hockeydudesdad
Re: port forwarding
Mon Jun 19, 2017 9:58 pm
Yes I ran it I'm not sure why it didn't work or how to fix it.
Re: port forwarding
Mon Jun 19, 2017 10:09 pm
When my program works you should get something like
pi@viking /tmp $ python3 ./checkWWW.py
IP: 192.168.3.14  Host: viking
OK
200
pi@viking /tmp $
MQTT Evangelist
hockeydudesdad
Re: port forwarding
Mon Jun 19, 2017 11:55 pm
I finally got it working However my camera keeps shutting off automatically how do I fix this?????
klricks
Re: port forwarding
Tue Jun 20, 2017 1:39 am
hockeydudesdad wrote:I finally got it working However my camera keeps shutting off automatically how do I fix this?????
Please tell us and whoever stumbles (Googles) across this thread, what it was that fixed your issue.
It would be best to start a new thread about your camera issue. Be sure to give lots of details so people can help you without having to guess. eg what camera brand and model with link? How is it connected? Power supply specs? OS installed? etc.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
hockeydudesdad
Re: port forwarding
Tue Jun 20, 2017 2:07 am
I set up port forwarding but I used the public Ip address assigned to my computer instead of the local ip address of my pi. I hope this makes sense and I hope this helps
Who is online
Users browsing this forum: bradwiggo, PeterO and 17 guests
