sprinkmeier
some help with "command not found" errors
Sat May 11, 2013 1:55 am
So you're running a script of some kind which fails on a missing command:
pi@gatepie ~ $ ./SomeScript.sh
./SomeScript.sh: line 2: uuencode: command not found
yup... it's missing alright.
pi@gatepie ~ $ uuencode
There's a helper to identify mising commands:
pi@gatepie ~ $ sudo apt-get install command-not-found
Reading package lists... Done
You need to run 'update-command-not-found' as root to update the cache.
update it's database:
pi@gatepie ~ $ sudo update-command-not-found
Downloading complete file http://mirrordirector.raspbian.org/raspbian/dists/wheezy/main/Contents-armhf.gz
OK, you might need to log out and back in again for this to work
The program 'uuencode' is currently not installed.  To run 'uuencode' please ask your administrator to install the package 'sharutils'
if you're root it will even tell you how to do that:
root@gatepie ~ # uuencode
The program 'uuencode' is currently not installed.  You can install it by typing:
apt-get install sharutils
there's even a sort of spell-checker in case you mostly remember the name of a command:
pi@gatepie ~ $ dhcp
No command 'dhcp' found, did you mean:
 Command 'dicp' from package 'dish' (main)
 Command 'hcp' from package 'lam4-dev' (main)
 Command 'chcp' from package 'nilfs-tools' (main)
 Command 'dhcpd' from package 'isc-dhcp-server' (main)
 Command 'dccp' from package 'dcap' (main)
dhcp: command not found
pi@gatepie ~ $
SimonSmall
Re: some help with "command not found" errors
Sat May 11, 2013 11:26 am
Ooohh - good call. I'll try this later :D
recantha2
Contact: Website Facebook Twitter
Thu May 16, 2013 8:04 am
Sweet :-) Will feature on my blog
Michael Horne - @recantha
Raspberry Pi blog - http://www.recantha.co.uk/blog
Cambridge Raspberry Jam
Website: http://camjam.me
Facebook: https://www.facebook.com/cambridgeraspberryjam
Follow the Cambridge Raspberry Jam on Twitter - @cambridgejam
