KnotMan33
Error Message while running Startx command[solved]
Tue Mar 05, 2013 9:08 pm
Hello, I just received my Pi and am very new to Linux and am having lots of trouble starting my Pi.
i am able to start it and go through the Config process. However then when I try to run the startx command it runs for a few Seconds pauses then gives me the error message
(Running Newest Wheezy version on a brand new board)
"Fatal server error:
could not create lock file in /inp/.1xd-lock
Please consult the X.org Foundation support
at http://wiki.x.org
for help
(I cannot read first letter of the first word of the following with the Screen i am Using but the rest is)
init: giving up
init: unable to connect to X server: Bad file descriptor
init: server error
nuth: error in locking authority file /home/pi/.xauthority"
I have done lots of research online and have found no one with the same problem, or a fix even on the X.org website.
Please help I am very confused and do not know what to do.
Thank you.
malakai
Re: Error Message while running Startx command
Wed Mar 06, 2013 7:22 am
Did you expand the SD Card in
sudo raspi-config
. Is it just running out of space and that's why it can't create the file? What size card are you using and are you just running
startx
after login?
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
jojopi
Wed Mar 06, 2013 8:50 am
KnotMan33 wrote:could not create lock file in /inp/.1xd-lock
I believe that should say "/tmp/.tX0-lock". Do you get an error if you try to create a file in /tmp yourself:
touch /tmp/test
KnotMan33
Wed Mar 06, 2013 7:58 pm
Thank YOU my pi is now working!!
I didn't do anything but check my SD card usage with
df -h
and then it ran Startx again and i worked!
I think that the Pi didn't recognize that there was space available until i ran
df -h where it realized there was lots of extra space.
Thank you again!!!
Repus
Re: Error Message while running Startx command[solved]
Thu Mar 14, 2013 1:35 am
Exact same problem for me using a 16gb Sandisk 4, df -h solved issue.
ShunJianLee
Fri Aug 05, 2016 6:44 am
sorry, you mean type dh -h then the problem solved? Because nothing change after i type df-h.
RaTTuS
Contact: Twitter YouTube
Fri Aug 05, 2016 7:26 am
start as new thread with your issues provide as much info as you can - this is 3Years old
Covfefe
gokul96
Thu Mar 23, 2017 6:16 am
this happens when the storage is full,
or sometimes if you do sudo startx
delete file .tX0-lock and try again,
if not clear some disk space by deleting unneeded files or by running sudo apt clean it should work afterwards
