Pepsiman
SITECOM USB Micro Adapter N150
Sat Jan 26, 2013 8:50 pm
Hi, i bought this wifi adaptor but the raspi doesn't recognize it... How can i make it works? Thank you!
This is what i get with the command lsusb
Bus 001 Device 004: ID 0df6:005b Sitecom Europe B.V.
Bus 001 Device 005: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Bus 001 Device 006: ID 1a2c:0002
Bus 001 Device 007: ID 046d:c05a Logitech, Inc. Optical Mouse M90
Spid
Re: SITECOM USB Micro Adapter N150
Sat Jan 26, 2013 10:38 pm
Model number and revision ? http://www.sitecom.com/network-adapters
Also it it came with CD it may have Linux Drivers.....
I will always assume you are running Raspbian for desktop and Raspbmc for XMBC !
Pepsiman
Sat Jan 26, 2013 11:05 pm
It's the 512 MB RAM model, i think is Rev. 2 but i'm not sure... Where i can check it?
Anyway drivers are only for Windows and OS X... And no CD with the adaptor...
Spid
Sun Jan 27, 2013 1:49 pm
The actual model of Sitecom adaptor........
The Linux Distribution recognises devices, therefore if running Raspbian is it fully updated ?
Pepsiman
Sun Jan 27, 2013 2:43 pm
This is the adaptor
http://www.sitecom.com/wi-fi-usb-adapter-n150/p/925
Yes, raspbian is updated
Spid
Sun Jan 27, 2013 3:31 pm
If you have undertaken a sudo apt-get update & sudo apt-get dist-upgrade then the Realtek RTL8192 chipset should be recognised !
Pepsiman
Sun Jan 27, 2013 4:59 pm
Ok, now it works! Thank you!
Spid
Sun Jan 27, 2013 5:08 pm
Pepsiman wrote:Ok, now it works! Thank you!
Great news, always worth undertaking an update every couple of weeks, the developers are on the ball !!
