thradtke
boot from external HDD/hub
Wed Sep 19, 2012 5:09 am
Is it possible to boot an OS from a hard disk connected via external hub? I've installed Raspbian but booting stops with a notification that /dev/sda1 isn't found. Is there anything I can do about it?
Thanks!
Rocket Scientist.
Lob0426
Re: boot from external HDD/hub
Wed Sep 19, 2012 6:00 am
Yes it works just fine for me.
One thing to try is /sda2 or just /sda
Make sure you have this in cmdline.txt and that there is a space before and after it. You should have changed it from "/dev/mmcblk0p2" to "/dev/sda1"
root=/dev/sda1
Make sure you have the right rootfs type stated in cmdline.txt also.
rootfstype=ext4
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
thradtke
Wed Sep 19, 2012 6:19 am
Lob0426 wrote:Yes it works just fine for me.
I've created partitions 1 (ext4) and 2 (swap), but I'll try sda tonight.
Lob0426 wrote:Make sure you have this in cmdline.txt and that there is a space before and after it. You should have changed it from "/dev/mmcblk0p2" to "/dev/sda1"
I started out with no cmdline.txt at all and had to create it with this single line you quoted, but it appears the systems identifies correctly what I want as it complains about exactly the /dev/sda1 device I stated there. At least, I hope I understand what's going on ;-).
Lob0426 wrote:Make sure you have the right rootfs type stated in cmdline.txt also.
rootfstype=ext4
Ah, that's promising. I'll try your suggestions tonight. Thanks!
Rocket Scientist.
RaTTuS
Wed Sep 19, 2012 7:30 am
http://www.raspberrypi.org/phpBB3/viewt ... 3&p=122743 - read the thread
http://www.raspberrypi.org/phpBB3/viewt ... fs#p122476 <- plus the small typo I made and fixed in a later post
Covfefe
thradtke
Wed Sep 19, 2012 5:56 pm
Specifying the fs and/or changing sda1 to sda had it all ended up with that nice rainbow screen. boot_delay=1000 and rootdelay=30 did apparently nothing. In no time, I had the screen full of text and still it is reported that /dev/sda1 isn't found.
Powering up all at the same time or having hub and usb HDD powered first than Pi made no difference.
Back without cmdline.txt, Raspbian boots just fine from SD and the USB HDD is accessible at /dev/sda1.
I'm lost here (again).
Rocket Scientist.
thradtke
Wed Sep 19, 2012 6:22 pm
Whoops ... it wasn't patient enough. After some time, the rainbow screen went away and fun started :-).
Well, it now complains about the swap partition apparently have holes, but I'll try to resolve it myself. At least one thing I should do myself :lol: .
Thanks guys, you are great!
Rocket Scientist.
thradtke
Thu Sep 20, 2012 4:43 pm
Deinstalled swapfile, removed dphys-swap symlink, created swap partition entry in fstab - solved.
Ha!
Rocket Scientist.
