charyshiv
Using GPIOs 14 and 15 also?
Sun Aug 19, 2012 7:18 pm
Hi All,
I am trying to use all 17 gpios, but pins GPIO 14 & 15 are assigned to the alternate function UART0. Could you please help me how to switch back to GPIO and disable UART0?
Thanks,
Regards,
Shiva.
joan
Re: Using GPIOs 14 and 15 also?
Sun Aug 19, 2012 7:32 pm
I think it's probably as simple as setting the pin modes to an INPUT or an OUTPUT. You'll probably want to remove references to /dev/ttyAMA0 from /boot/cmdline.txt and /etc/inittab as well (/dev/ttyAMA0 is the device for that uart).
charyshiv
Sun Aug 19, 2012 8:13 pm
Thanks a lot. It is working fine. I can use all 17 gpios now. :)
Shiva.
eatenbyagrue
Fri Aug 22, 2014 3:25 am
Thanks for this - removing the console references totally fixed my problem as well.
