elliskev
Power restriction in Quick Start guide
Tue Jul 10, 2012 6:36 pm
The Quick Start guide says, "Do not attempt to power your Raspberry Pi by plugging it into a computer or a hub."
Why? What is the danger of plugging into my PC's USB port for power?
kaos
Re: Power restriction in Quick Start guide
Tue Jul 10, 2012 10:50 pm
Standard USB ports only deliver max 500mA of current, and then only after negotiation with the connected device, which Raspi doesn't do, while Raspi requires 700mA. Lately some computers have come out with special "charging" ports that can deliver more current, intended to charge mobile phones and tablets, and it should be safe to power the Raspi from one of those. What will happen if you connect a Raspi to a standard USB port anyway? That depends on the design of the USB host (computer). If the port is protected by a polyfuse of the same kind as used in the Raspi itself, it will likely start to boot up fine, possibly even finish booting, but then die. Disconnecting and waiting a few minutes will reset the polyfuse and allow you to use the port again. Of course, you may also get away with running the Raspi this way with no problems, either because the Raspi isn't drawing the full 700mA (depends on what you have connected to it and what you are using it for), or the designers of the host allowed for more than 500mA current, or the USB port has ineffective overcurrent protection (cheap USB hubs may, indeed, have no overcurrent protection for individual ports).
Best regards, Kári.
elliskev
Tue Jul 10, 2012 10:59 pm
Great response. Thanks. That explains a lot.
itimpi
Wed Jul 11, 2012 6:59 am
You can always use a USB Y cable of the sort frequently used with 2.5" hard disks in PC USB sockets to power the Pi. This allows the power from 2 ports to be used giving up to 1A which is more than enough for the Pi. The downside is you have used two USB ports and you may not have that many to spare :D
