rudiratlos
Re: freepascal on RPi
Tue May 01, 2012 1:46 pm
1. Has anyone tried to install FreePascal (FPC) on the RPI?
2. Has anyone tried to run a crosscompiled FPC program on the RPI?
plugwash
Tue May 01, 2012 2:31 pm
I would have done if I had managed to get my hands on the bloody thing. I have however used it on other arm hardware with no problems.
If you are running debian armel it should be a simple matter of apt-get install fpc.
Never had much luck with cross compiling myself, i'm sure it can be made to work but it's a PITA getting everything in the right places.
rudiratlos
Thu May 03, 2012 1:36 pm
Does anyone have installed FPC on the RPI with apt-get install fpc ?
and run the compiler and a hello-world program ?
Thu May 03, 2012 2:30 pm
I'll try and remember to try it this evening.
Thu May 03, 2012 7:57 pm
OK, tried this....seems to work fine.
[email protected]:~$ cat test.pas
program temperature(output) ;
{ Program to convert temperatures from
Fahrenheit to Celsius. }
const
MIN = 32 ;
MAX = 50 ;
CONVERT = 5 / 9 ;
var
fahren: integer ;
celsius: real ;
begin
writeln('Fahrenheit Celsius') ;
writeln('---------- -------') ;
for fahren := MIN to MAX do begin
celsius := CONVERT * (fahren - 32) ;
writeln(fahren: 5, celsius: 18: 2) ;
end ;
end.
[email protected]:~$ fpc test.pas
Free Pascal Compiler version 2.4.0-2 [2010/02/20] for arm
Copyright (c) 1993-2009 by Florian Klaempfl
Target OS: Linux for ARMEL
Compiling test.pas
Assembling temperature
Linking test
/usr/bin/ld: warning: link.res contains output sections; did you forget -T?
18 lines compiled, 1.4 sec
[email protected]:~$ ls
Desktop test test.o test.pas
[email protected]:~$ ./test
Fahrenheit Celsius
32 0.00
33 0.56
34 1.11
35 1.67
36 2.22
37 2.78
38 3.33
39 3.89
40 4.44
41 5.00
42 5.56
43 6.11
44 6.67
45 7.22
46 7.78
47 8.33
48 8.89
49 9.44
50 10.00
KenP
Thu Jun 21, 2012 1:14 pm
rudiratlos wrote:Hi,
1. Not yet, but will do tonight!
2. No, and once FPC is up and running, no reason (for me) to bother, really.
IMO, the Pi and FPC are ideal bed-mates. Pascal was invented as a teaching language, and encourages good coding habits. The OO that was later added was done (again, IMO) right. Not over-complicated, easy to understand, and extremely powerful. Being open-source is a major bonus, and I can easily see somebody packaging up a PascalPi, with OS and FPC pre-installed and ready to go.
BTW, FPC includes a simple IDE (FP), which runs beautifully in text mode (i.e. over an SSH connection), and you can add Lazarus for Delphi-style GUI development, although I'm so unimpressed with the GUI desktops looked at so far on the Pi that I'll probably keep mine headless.
Opinions expressed in this message are not necessarily those of the author.
I don't know where they come from.
It scares me sometimes.
forumisto
Thu Jun 21, 2012 6:08 pm
sudo apt-get install fpc
It needs 139MB :shock: :shock: :shock:
KenP
Thu Jun 21, 2012 9:07 pm
...and hangs and apparently kills the Pi
Just being overly dramatic - my Pi isn't well, I have a feeling I've got a dodgy SD card; it hangs up for a minute or two periodically, and hung up permanently while trying to install FP. I'll try again, otherwise will wait for my new SDs from Amazon.
forumisto
Thu Jun 21, 2012 9:26 pm
maybe the reason is a bad power supply
AndrewS
Fri Jun 22, 2012 12:41 am
forumisto wrote:sudo apt-get install fpc
To be fair, it's all the development libraries that fpc relies on that use up all the diskspace, rather than fpc itself. More libraries = more features that fpc supports :)
KenP
Fri Jun 22, 2012 9:33 am
forumisto wrote:maybe the reason is a bad power supply
I think the biggest problem was a dodgy USB hub, as a lot of things which were going squiffy have now resolved themselves.
Now.... talking to a Velleman K8055 over USB in Pascal....hmmm....
AndrewS
Fri Jun 22, 2012 10:27 am
KenP wrote:Now.... talking to a Velleman K8055 over USB in Pascal....hmmm....
You need to split it down into two problems:
1) get http://libk8055.sourceforge.net/ working on the RPi ( http://www.raspberrypi.org/phpBB3/viewt ... =37&t=8598 )
2) get Pascal talking to libk8055
