GloomyGhost
Yuzuki2040, I made the pico board myself
Sun Aug 01, 2021 11:03 am
Just use EasyEDA to draw a pcb, all schematic and pcb are Open Source based on CERN Open Hardware Licence Version 2 - Strongly Reciprocal license.
Github: https://github.com/YuzukiHD/Yuzuki2040
So happy to have my first own-made development board :D :D
Student from China
karadev
Contact: Website Skype
Re: Yuzuki2040, I made the pico board myself
Sun Aug 01, 2021 4:55 pm
cool mate, look is great :) i have a sugestion for next version of pcb. set on pcb and RESET button near by BOOT SELECT button to not need replug usb cable any time ;) see in net how need to connect RESET button to RPI2040.
link >>> https://www.raspberrypi.org/blog/how-to ... y-pi-pico/
http://www.karadev.net - electronic systems hardware, software, programming, LINUX, PICO and more :)
SirSydom
Mon Aug 02, 2021 7:21 am
where are all those decoupling Cs ?
aallan
Raspberry Pi Trading Employee & Forum Moderator
Mon Aug 02, 2021 8:10 am
They do seem to be absent? Although it could be a double-sided board perhaps? Should be as close as possible to the power pins, see "Hardware design with RP2040".
An extract from %22Hardware Design with RP2040%22.jpg (188.97 KiB) Viewed 1027 times
Technical Documentation Manager
Raspberry Pi (Trading) Limited
About me, http://alasdairallan.com
GloomyGhost
Mon Aug 02, 2021 11:36 am
Well, I just simply removed a lot of decoupling caps. Because this is a double-layer board and with a linear regulator AMS1117-3.3 as the power, Beside I put almost all of the gpios circuit to the first layer. I think it is also feasible to simplify some capacitors. There was no problem in my test, but the stability may not be so good, I will consider adding it in a later version
By the way, I only use two caps for decoupling, which is above to the crystal circuit.
Student from China
GloomyGhost
Mon Aug 02, 2021 11:42 am
Thanks! I will add it
Student from China
karadev
Mon Aug 02, 2021 4:23 pm
coool mate, also make pin headers bread board frendly raster :) to can use it directly in bread board. did you see my pcb design for rpi pico shield ???
see here >>> http://www.karadev.net/site/index.php/rpidevelop
and here others pcb in rpi pico set >>> http://www.karadev.net/site/index.php/rpidevelop3
GloomyGhost
Mon Aug 09, 2021 1:11 pm
New Version, add CH340N as USB to UART.
By the way, I tried many flash chips such as GD25Q16CSIG, W25Q128FWPM, GD25Q80BSIG, but only GD25Q80BSIG work as well. I also change some data in the pico-sdk but no effort. I wonder how to debug with the flash problem.
Student from China
GloomyGhost
Sun Sep 12, 2021 6:10 am
Add a new version and add reset button
And Make MicroPython Run
Student from China
Return to “Other RP2040 boards”
