errorflash
Toggle Switch Read Out
Sat Jul 24, 2021 7:03 pm
Hello
I came from Arduino programming and have no high IQ in MicroPython.
I need a code that read the Status from a toggle switch. The code must read the only status change. When i Switch On the pi must send a "1" at GP0 and when i switch off GP1 must send a "1" only one times for 1 Second and every time at status change.
Thanks for Help!
danjperron
Re: Toggle Switch Read Out
Mon Jul 26, 2021 5:36 pm
from machine import Pin
import utime
class Debounce:
    def __init__(self,pin,debounceTimems=10):
        self.pin = pin
        self.pinValue = self.pin.value()
        self.utimems = utime.ticks_ms()
        self.debounceTimems = debounceTimems
    def isChanged(self):
        if pinValue is not self.pinValue:
            if (utime.ticks_ms()-self.utimems) > self.debounceTimems:
                self.pinValue= pinValue
                return True, pinValue
        else:
            self.utimems= utime.ticks_ms()
        return False, pinValue
if __name__ == "__main__":
    debouncePin = Debounce(Pin(19,Pin.IN,Pin.PULL_UP))
while True:
    flag, pinValue = debouncePin.isChanged()
    if flag:
        print(pinValue)
    utime.sleep_ms(1)
Can't figure out what you mean! The code I send you only send the status when the switch changes. I include a debounce timeout of 10 ms. Do you mean that if the switch is toggle in less than 1 second the status is not send. If it is then the debounce should be 1 second.
Return to “MicroPython”
