KAG Tech
Enabling and disable a GPIO
Tue Jul 20, 2021 9:39 am
Below is a program I used to read varying voltages from a variable resistor and it worked perfectly.
from machine import ADC, Pin
from time import sleep
adcX = ADC(0)
oldX = 0
conversion_factor = 3.3/65536
while True:
valX = adcX.read_u16()
sleep(5)
if valX != oldX:
print("X:", valX * conversion_factor, "volts")
oldX = valX
Please assist on how I can enable another GPIO when the input voltage on ADC 0 is equal to or above 2.3 V and disable it when the voltage reads equal to or below 2.2 V
fdufnews
Re: Enabling and disable a GPIO
Tue Jul 20, 2021 9:53 am
Use the Pin class. Have a look here
hippy
Tue Jul 20, 2021 11:04 am
From first principles, an ADC will return a 16-bit 'Nadc' value as follows -
Nadc = Vin * 65535 / Vref
You can then determine what the voltage in was from -
Vin = Nadc * Vref / 65535
So one solution is to convert the ADC reading to the voltage in -
Vref = 3.3
while True:
  Nadc = adcX.read_u16()
  if Vin >= 2.3:
  elif Vin <= 2.2:
Or, you could pre-calculate what 'Nadc' would be for the two voltage input limits -
Vref = 3.3
Nadc_at_2_point_3_volts = 2.3 * 65535 / Vref
Nadc_at_2_point_2_volts = 2.2 * 65535 / Vref
while True:
  if Nadc >= Nadc_at_2_point_3_volts:
  elif Nadc <= Nadc_at_2_point_2_volts:
hippy
Tue Jul 20, 2021 11:24 am
Just a quick note on terminology -
"Enabling and disable a GPIO" - It's not exactly clear what "enable" or "disable" may mean. You will know what that means to you but others will understand that differently.
"Turn on" and "turn off" might be better choices, but what is "on" and what is "off" ? In some cases "on" may mean setting a pin high, but in other cases it may mean setting it low.
The recommendation is to be explicit as to setting a pin high or low, or to use the generic terms "asserted" and "deasserted" when it doesn't matter if "asserted" is high or low, may vary depending on hardware configuration.
KAG Tech
Thu Jul 22, 2021 9:03 am
Thank you for the reply, the documentation was of great help especially with commands we did not know of.
We managed to figure it(the program) out. It was surprisingly as simple as using >= or <= and it worked perfectly fine.
Below is how we programmed Pi Pico:
POT = ADC(0)
LED = machine.Pin(7, machine.Pin.OUT)
while True:
volt = POT.read_u16()
if volt <= 43590:
LED.value(0)
elif volt >= 43591:
LED.value(1)
KAG Tech
Thu Jul 22, 2021 9:15 am
Vref = 3.3
while True:
  if Vin >= 2.3:
  elif Vin <= 2.2:
Vref = 3.3
while True:
Thank you for the reply. We managed to figure it out and it worked perfectly fine but we will definitely try your program too, it will help improve our programming skills since we are beginners.
Below is how we programmed the Pi Pico
POT = ADC(0)
while True:
if volt <= 43590:
LED.value(0)
elif volt >= 43591:
LED.value(1)
KAG Tech
Thu Jul 22, 2021 9:17 am
Noted. Thank you for the reply.
fdufnews
Thu Jul 22, 2021 10:13 am
Please use the Code tag on the tool bar to put your code online otherwise it will not be correctly formated.
All the indentations are lost.
Return to “MicroPython”
