geotek1
Import “Machine” Question?
Thu Jun 17, 2021 5:02 pm
Greetings
As a newbie to a Pico, I need some assistance.
I am trying to experiment with both CircuitPython and Micropython.
I have typed and try to run some programs - some of these programs call ‘import machine’ and when Try to run the program I get an error message - no module ‘machine ‘ found.
Where does this ‘machine’ come from? Where does it come from- is there a library that I am missing?
Thanks in advance
Tom
fivdi
Re: Import “Machine” Question?
Thu Jun 17, 2021 7:56 pm
machine is a built-in module in MicroPython which means it's part of MicroPython itself. CircuitPython and MicroPython similar but not exactly the same. One difference is that CircuitPython has no built-in module called machine.
B.Goode
Thu Jun 17, 2021 8:44 pm
.... for microcontrollers flashed with CircuitPython the corresponding hardware functionality is probably in the board module instead.
scruss
Thu Jun 17, 2021 8:56 pm
… so basically, if you get the ImportError: no module named 'machine' error, you're running on CircuitPython.
I'd stick to one or the other, since the language differences that CircuitPython introduced make it incompatible. CircuitPython has better support for add-on hardware, though.
Pronouns: he/him
fivdi
Thu Jun 17, 2021 9:17 pm
Not really, board is all about board specific pins.
>>> import board
>>> board.
A0              A1              A2              A3
BAT_SENSE       GP0             GP1             GP10
GP11            GP12            GP13            GP14
GP15            GP16            GP17            GP18
GP19            GP2             GP20            GP21
GP22            GP25            GP26            GP26_A0
GP27            GP27_A1         GP28            GP28_A2
GP3             GP4             GP5             GP6
GP7             GP8             GP9             I2C
LED             SCL             SDA             USER_SW
VBUS_DETECT
>>> board.
The microcontroller module in CircuitPython is porbably closest to machine in MicroPython
>>> import microcontroller
>>> microcontroller.
Pin             Processor       ResetReason     RunMode
cpu             cpus            delay_us
disable_interrupts              enable_interrupts
nvm             on_next_reset   pin             reset
watchdog
>>> microcontroller.
Correct.
>>> import machine
  File "<stdin>", line 1, in <module>
hippy
Fri Jun 18, 2021 11:24 am
It is really the libraries and various API rather then the language which are different but that can make a program written for one incompatible with the other, so considering them different languages isn't unreasonable.
MicroPython isn't CircuitPython isn't Python. It is possible to write code which will run 'as is' on all three but it does make things tricky and means more work. I don't have CircuitPython currently installed but, as well as try-except, these can help identify which is which -
print( os.uname() )
print( sys.platform )
In theory CircuitPython libraries should be usable with MicroPython but I don't believe all are and it's a bit of a faff installing and using them -
viewtopic.php?f=146&t=312345
As I don't have a Pico set-up for hardware development, don't have access to hardware, I haven't done much with those other than make things easier to install.
Return to “MicroPython”
