jbeale
internal temperature offset on 3rd party boards?
Sun Apr 18, 2021 1:21 am
I'm using the code below to read out the internal temperature:
sensor_temp = machine.ADC(4)       # Pico internal temperature sensor
conversion_factor = 3.3 / (65535)  # ADC scaling
reading = sensor_temp.read_u16() * conversion_factor
degC = 27 - (reading - 0.706)/0.001721  # RP2040 internal temp
With an ambient temperature of 23.6 C, I find that two different Raspberry Pi Pico boards read 24.3 and 22.4 C.
I just got two Adafruit Feather RP2040 boards, and using this same code at the same ambient temperature, they read 34.5 and 32.7 C.
I know Raspberry Pi has no control over 3rd party boards, but I had the impression the temperature sensor was internal to the RP2040 chip.
It doesn't seem just chance that the different boards would be so far apart, when each pair of boards of the same type is that close.
Maybe the Adafruit layout is not connecting the chip's bottom thermal pad to a ground plane (?)
cleverca22
Re: internal temperature offset on 3rd party boards?
Sun Apr 18, 2021 2:14 am
the 3.3 figure in your formula may need correcting
use a volt meter to measure the actual 3.3v rail, and enter the correct voltage
on my pico, it was 3.27v
hippy
Sun Apr 18, 2021 1:42 pm
I too would guess that presuming Vref to be 3V3 is the main issue. The temperature sensor output is quite low voltage and only changes slightly per whole degree C so small discrepancies in the conversion equation can cause quite significant divergence in reported values against actual.
The Adafruit Feather RP2040 circuit diagram is here -
https://cdn-learn.adafruit.com/assets/a ... 1614787563
As can be observed; it connects leg 43, ADC_IOVDD / ADC_AVDD, direct to 3V3, where the Pico connects it via a 200R + 1R to 3V3. This means the Arduino Feather RP2040 should have a slightly higher Vref than the Pico.
But that would mean the Adafruit Feather RP2040 should be reporting its internal temperature more accurately than the Pico with 3V3 Vref presumed. So perhaps there is something else going on. I have always found on-chip temperature sensors more trouble than they are worth.
It can be beneficial to convert the fudged 16-bit ADC reading back to its native 12-bit so that fudging is taken out of play -
VREF = 3.3
temperatureSensor = machine.ADC(4)
def ReadTemperatureC():
    adc12 = temperatureSensor.read_u16() >> 4
    voltage = adc12 * VREF / 4095
    degreeC = 27 - (voltage - 0.706) / 0.001721
    return degreeC
jbeale
Sun Apr 18, 2021 4:23 pm
Your points are well taken, and I found there is some variation between each of the boards. However, the pattern of variation does not exactly match the pattern of the temperature differences I found. For example, the voltage rail on Pico #1 and Feather #1 are closer together than the two Pico boards, yet the reported temperatures are not. I used the same meter for each measurement, and it reports consistent values on re-tests.
Pi Pico #1: V = 3.294
Pi Pico #2: V = 3.259
Feather #1: V = 3.297
Feather #2: V = 3.300
To make it more clear, here is code (running on a Pico, in this case) to use both the max and min measured Vref number (2.249 and 3.300) to see how much that affects reported temperature:
raw = sensor_temp.read_u16()
f1 = 3.300 / (65535)  # ADC scaling assuming 3.300 V
f2 = 3.259 / (65535)  # ADC scaling assuming 3.259 V
degC1 = 27 - ((raw*f1) - 0.706)/0.001721  # RP2040 internal temp
degC2 = 27 - ((raw*f2) - 0.706)/0.001721  # RP2040 internal temp
print("Temp: %5.3f %5.3f" % (degC1,degC2))
Result: Temp: 20.959 26.130
So worst-case error among my four boards should be 5.17 C, based only on the variation in Vref, and yet I observe twice that.
davidcoton
Sun Apr 18, 2021 4:29 pm
I'm not sure that there needs to be. At least one of the original RPT board readings is almost certainly "wrong", how can the chip temp be below ambient? Does it help to measure and correct the Vref on the RPT board -- does that bring it closer in line with Adafruit?
If there is another factor, it might be how each board is engineered to dissipate heat. We know RPT have some experience of using what's on the board to keep it cool, though this will be less significant on a Pico.
jbeale
Sun Apr 18, 2021 4:42 pm
Certainly there is an expected error tolerance, and the various Vref values are a significant contribution, accounting for a total difference of 5 degrees C among my specific four boards, as I found in my previous note. However I observed 12 degrees C variation among those 4 boards, and with each board from the same mfr (RPi Pico vs Adafruit Feather) reporting a temperature closer to its sibling, even though the measured Vref values were not. That suggests to me something aligned with the design and manufacturing of the boards is actually the dominant factor.
Another possibility is the calibration factor of the Vbe junction voltage (?) used as the temperature sensor, maybe there is per-lot process variation and the different mfrs. used parts from different lots. Still, a delta of 12 C seems pretty big for that kind of variation.
I wasn't able to tell much with my "FLIR 1" mini thermal-IR camera. There's a parallax offset between its low-res thermal, and visible image when you have it close to small objects. Waving around to try to measure where the top of the RP2040 chip is-- maybe-- suggests there's only about 1 deg. C difference between the two boards, at least on top of the chip package, with both running the same uPython code.
(The USB connectors look hot, but smooth metal surfaces are mostly reflectors, showing what is in front of them, in this case my hand.)
thermal image of Pico & Feather
Pico & Feather
fdufnews
Sun Apr 18, 2021 7:43 pm
As said in the datasheet, the result is not guaranteed.
As the Vbe and the Vbe slope can vary over the temperature range, and from device to device, some user calibration may be required if accurate measurements are required.
I have not find, in the datasheet, any tolerance on the value of Vbe @ambiant.
jbeale
Sun Apr 18, 2021 8:34 pm
That is true, but I am confident there are some bounds on the performance of working parts, though the datasheet may not specify exactly what that is.
I'm just presenting what observations I have, from my limited dataset.
hippy
Mon Apr 19, 2021 7:03 pm
If we assume a perfect world, one thing were reporting 22.4C with 3V3 Vref and another thing were reporting 34.5C with the same 3V3 Vref - which are the extremes of the readings being seen, we can determine what the sensor voltage must have been for both -
34.5 C = 714 mV
22.4 C = 693 mV
An 11 mV A 21 mV change produces around an 11 C change.
With the nominal sensor voltage of 706 mV at 27 C, that 11 mV 21 mV would represent about 1.6%, +/-0.8% 3%, +/-1.5%
I don't know what manufacturing tolerance should be expected from a silicon etched diode but that sort of discrepancy fits with my experience of on-chip temperature sensors.
jbeale
Tue Apr 20, 2021 12:38 am
Thanks for making that point; indeed, the actual voltage difference seems less noteworthy than the calculated temperature difference. So perhaps it is just random chance, given I only measured 4 boards.
It also reminds me of another thing: the Pico brings out 8 separate ground pins to the board edges (9 if you count the debug pins). The Feather board presents only one ground pin, in addition to its onboard connectors. Unavoidably there will be differences in trace routing on the two boards, which may well affect what the chip sees as (Vref-Ground) vs what I see on the board pins, at the 11 mV level.
FWIW the Feather uses a USB3 connector, and its shell is not grounded (maybe that's the standard USB3 thing, I don't know). The two plated-through mounting holes to either side of the USB connector are not grounded either.
hippy
Tue Apr 20, 2021 2:46 pm
Not sure how I calculated 714 - 693 as being 11. Have updated the post.
Return to “MicroPython”
