DarkElvenAngel
[SOLVED] Problem filling my array [BUT WHY?]
Tue Jun 15, 2021 5:04 am
Hello Everyone,
I have a function that is suppose to fill and array nibble by nibble but it doesn't work for some reason.
bool _Prase_ESC(char data)
    static uint8_t count = 0;
    static byte char_data[9] = { 0 };
    if (count == 0) { char_data[0] = data; count++; return 1; }
    char_data[((count - 1)  / 2) + 1] |= ((data & 0x0f) << ( 8 * count % 2));
    if (count == 16 )
           Define_User_Char(char_data[0], &char_data[1]);
           memset(char_data,0,9);
           count = 0;
           return true;
     count++;
     return false;
The char_data array only ever has the low nibble set the high nibble is always 0.
I've rewritten this 10 different ways and the result is always the same.
This code fragment of the function is the important part, this part is triggered correctly and ends when it should the problem is the data is half missing.
I've tested this with a string ajjee````````jjee and that should reproduce
0x61 0xaa, 0x55, 0x00, 0x00, 0x00, 0x00, 0xaa, 0x55
what I get is
0x61 0x0a, 0x05, 0x00, 0x00, 0x00, 0x00, 0x0a, 0x05
What am I missing? (besides half the data)
Last edited by DarkElvenAngel on Tue Jun 15, 2021 3:06 pm, edited 1 time in total.
Memotech Bill
Re: Problem filling my array
Tue Jun 15, 2021 7:23 am
A nibble is only four bits, not eight.
Try:
char_data[((count - 1)  / 2) + 1] |= ((data & 0x0f) << ( 4 * count % 2));
DarkElvenAngel
Re: [SOLVED] Problem filling my array [BUT WHY?]
Tue Jun 15, 2021 3:26 pm
So yes coding when you are tired isn't a good idea and a nibble is 4 and not 8.
But that didn't work! I don't know if there is a compiler bug or what but what I had to do to get it to work was this.
    static uint8_t params[2] = { 0 };
    if (count == 0)
          params[0] = data - FONTSET_START ;
          if (params[0] >= FONTSET_SIZE) return false;
          Clear_User_Char(data);
          count++;
          return 1;
    data &= 0xf;
    data <<= 4 * (count % 2);
    USR_FONT[(params[0] * 8) +  ((count - 1)  / 2) ] |= data;
    if (count == 16 )
           count = 0;
           return true;
     count++;
     return false;
No combination of doing that in one line would work. Trouble shooting this was a real pain I thought the most effective method was to load the values straight into RAM and not buffer them then I could see how the buffer would fill as I entered them.
Any idea as to why this solution didn't work
Memotech Bill wrote: A nibble is only four bits, not eight.
Try:
It's the same code but it will never shift the bits the shift is always 0
jojopi
Tue Jun 15, 2021 3:47 pm
* and % have the same precedence and associate from left from right. You need the parentheses around the modulo.
Or (count % 2 * 4), but that may be not the best style.
vikK4yHabbe7L
Wed Jun 23, 2021 6:57 pm
I like my code wordier but simpler:
indx = count / 2;  // where to put it
if ( count & 1 ) {
	buf[indx] = data;   // save bottom nibble
} else {
	buf[indx] |= data << 4;  // add top nibble
count++;
Mike /
pic0
Wed Jun 23, 2021 7:23 pm
Sure?
Starting with count=0 the first assignment will be
 	buf[0] |= data << 4;  // add top nibble
and the second after incrementing count will be
	buf[0] = data;   // save bottom nibble
and overwrite the previous one. So in my opinion the if condition needs to be inverted
DarkElvenAngel
Wed Jun 23, 2021 8:10 pm
Index 0 was used to hold the index where the data was going to be stored.
0 = Index
1 - 16 = data
now I've change things to be
if (count == 0)
       params[0] = data
       count++;
       return 1;
data = strtol(&data,NULL,16);
USR_FONT[(params[0] * 8) +  ((count - 1)  / 2) ] |= data << (4 * (count % 2));
count++;
USR_FONT being where the buffer was to be copied after it was fully processed I just cut out the buffer
The trip up was the order of operations
Return to “SDK”
