mike603
Non Blocking (interrupt driven) UART functions
Tue Jun 22, 2021 2:57 am
Looking at the SDK documentation I could not find non-blocking interrupt driven routines.
Does calling uart_set_irq_enables() turn the blocking routines into interrupt driven?
Also, is there any SDK support for DMA driven UART Tx or Rx?
pidd
Re: Non Blocking (interrupt driven) UART functions
Tue Jun 22, 2021 12:52 pm
If the interrupt tells you that a character is ready then a you can call a blocking fetch routine to get that character, it will not be blocking because you know a character is ready.
Generally you still poll for character availability before calling a blocking fetch routine because there may be more than one character available and also it avoids blocking. ie you treat the interrupt as advisory rather than absolute.
I generally poll everything and don't use interrupts but if the data is high speed or the polling latency is too slow then it is sometimes a solution - but it may not always the fastest in extreme circumstances.
kilograham
Tue Jun 22, 2021 1:00 pm
There is no common asynchronous IO support in the SDK API currently
The SDK gives you all the building blocks to build your own , and yes you can DMA to/from UART.
uart_set_irq_enables just sets the hardware interrupt enables
You might want to check out https://datasheets.raspberrypi.org/pico ... -c-sdk.pdf section 2.3 on library structure. hardware_ libraries provide thin wrappers over the hardware. pico_ provide higher level stuff at a more "OS" level but bear in mind this is a small SDK on a small microcontroller.
matherp
Tue Jun 22, 2021 4:53 pm
I do this:
unsigned char *com2Rx_buf;											// pointer to the buffer for received characters
volatile int com2Rx_head, com2Rx_tail;								// head and tail of the ring buffer for com2 Rx
unsigned char *com2Tx_buf;											// pointer to the buffer for transmitted characters
volatile int com2Tx_head, com2Tx_tail;								// head and tail of the ring buffer for com2 Tx
Initialise the serial function including the interrupts.
#define UART_ID  (uart ? uart1: uart0)
void setupuart(int uart, int s2,int parity, int b7, int baud){
	uart_init(UART_ID,baud);
    uart_set_hw_flow(UART_ID, false, false);
    uart_set_format(UART_ID, b7, s2, parity);
    uart_set_fifo_enabled(UART_ID, false);
    int UART_IRQ = (UART_ID == uart0 ? UART0_IRQ : UART1_IRQ);
    if(uart){
		irq_set_exclusive_handler(UART_IRQ, on_uart_irq1);
    	irq_set_enabled(UART_IRQ, true);
	} else {
		irq_set_exclusive_handler(UART_IRQ, on_uart_irq0);
    uart_set_irq_enables(UART_ID, true, false);
Add a character to the serial output buffer.
unsigned char SerialPutchar(int comnbr, unsigned char c) {
        int empty=uart_is_writable(uart0);
		if(com1Tx_tail == ((com1Tx_head + 1) % TX_BUFFER_SIZE)); //wait if buffer full
		com1Tx_buf[com1Tx_head] = c;							// add the char
		com1Tx_head = (com1Tx_head + 1) % TX_BUFFER_SIZE;		   // advance the head of the queue
		if(empty){
	        	uart_set_irq_enables(uart0, true, true);
			irq_set_pending(UART0_IRQ);
	int SerialGetchar(int comnbr) {
	int c;
    	c = -1;                                                         // -1 is no data
	    uart_set_irq_enables(uart0, false, true);
		if(com1Rx_head != com1Rx_tail) {                            // if the queue has something in it
			c = com1Rx_buf[com1Rx_tail];                            // get the char
 			com1Rx_tail = (com1Rx_tail + 1) % com1_buf_size;        // and remove from the buffer
void on_uart_irq0() {
    if(uart_is_readable(uart0)) {
		com1Rx_buf[com1Rx_head]  = uart_getc(uart0);   // store the byte in the ring buffer
		com1Rx_head = (com1Rx_head + 1) % com1_buf_size;     // advance the head of the queue
		if(com1Rx_head == com1Rx_tail) {                           // if the buffer has overflowed
			com1Rx_tail = (com1Rx_tail + 1) % com1_buf_size; // throw away the oldest char
    if(uart_is_writable(uart0)){
		if(com1Tx_head != com1Tx_tail) {
			uart_putc_raw(uart0,com1Tx_buf[com1Tx_tail]);
			com1Tx_tail = (com1Tx_tail + 1) % TX_BUFFER_SIZE;       // advance the tail of the queue
		} else {
			uart_set_irq_enables(uart0, true, false);
void on_uart_irq1() {
	    while (uart_is_readable(uart1)) {
		com2Rx_buf[com2Rx_head]  = uart_getc(uart1);   // store the byte in the ring buffer
		com2Rx_head = (com2Rx_head + 1) % com2_buf_size;     // advance the head of the queue
		if(com2Rx_head == com2Rx_tail) {                           // if the buffer has overflowed
			com2Rx_tail = (com2Rx_tail + 1) % com2_buf_size; // throw away the oldest char
    if(uart_is_writable(uart1)){
		if(com2Tx_head != com2Tx_tail) {
			uart_putc_raw(uart1,com2Tx_buf[com2Tx_tail]);
			com2Tx_tail = (com2Tx_tail + 1) % TX_BUFFER_SIZE;       // advance the tail of the queue
		} else {
			uart_set_irq_enables(uart1, true, false);
/code]
carlk3
Sun Jul 25, 2021 2:52 am
I do this:
I like that! I would like to use something like that for the command line terminal user interface in my FreeRTOS-FAT-CLI-for-RPi-Pico project. This is a solution for a UART-connected terminal. However, I would like to maintain the ability to change the destination for stdin and stdout using CMake directives, with input/output directed to UART or USB CDC. Can something similar be done for USB CDC?
Looping waiting for a character works poorly in a multi-tasking OS, so my current solution is to move the looping to core1 and set up a fifo and interrupt for core0. (Currently, the OS is only running on core0.)
Return to “SDK”
