PiJohn
Corrupted struct variables when using multicore
Mon Jun 14, 2021 4:59 pm
Hello!
I've been trying to get the following working for myself locally as part of a larger program:
https://github.com/raspberrypi/pico-exa ... er_queue.c
You can see my simplified version of the code here
I have a struct as follows:
typedef struct
    int32_t (*func)(std::string);
    std::string data;
} queue_entry_t;
I initialise the struct and send it to the other core via the queue method:
        if(first==false){
            rcv = "A long string to test with..............";
            first=true;
            entry.func = &displayString;
            entry.data = rcv;
            queue_add_blocking(&call_queue, &entry);
Then in a loop, we check to see if the function has been called and the result posted back to the result queue.
        if(queue_try_remove(&results_queue, &res)){
            std::cout << "rcv is now:" << rcv << std::endl;
            printf("Added to queue remove\n");
The core runner code looks as follows:
void core1_entry() {
    while (1) {
        printf("Inside core1....\n");
        queue_entry_t entry;
        queue_remove_blocking(&call_queue, &entry);
        std::cout << "Entry is:" << entry.data << std::endl;
        int32_t (*func)(std::string){entry.func};
        int32_t result = func(entry.data);
        queue_add_blocking(&results_queue, &result);
The problem is, after running this a few times my string gets corrupted when read inside the core1_entry() function:
Starting....
Setup queues...
Launching core1
Inside core1....
Entry is:A long string to test with..............           <---- String ok here
In function: A long string to test with..............
Inside core1....
rcv is now:A long string to test with..............
Entry is:Ä Ä tring to test with..............               <---- String is now corrupted
In function: Ä Ä tring to test with..............
Inside core1....
One thing to note is that this is a cpp program making a call to a C function, not sure if that matters at all but when searching I found someone had encountered a similar issue where their structs were corrupted. Does anyone know what might be going wrong here?
PiJohn
Re: Corrupted struct variables when using multicore
Mon Jun 14, 2021 5:20 pm
Hmm I think I've sorted it, moving the definition of entry inside the core before the for loop no longer results in a corrupted string.
    while (1) {
Not how it's done in the original code though. https://github.com/raspberrypi/pico-exa ... ueue.c#L30
Any one any idea why this might corrupted the variable?
kilograham
Mon Jun 14, 2021 5:29 pm
1) A pretty fundamental problem in the full version; you are using the same global "entry" instance for core local stuff on each core... though you may have fixed that as you have a stack local one in the fragments of code
2) But yeah, you are passing a structure containing a c++ class std::string by value (the event structure is copied) through c code which has no idea that the string is there and has special copy semantics. The "value" you pass must be "Plain Old Data"
fivdi
Mon Jun 14, 2021 5:46 pm
I'd put a C style string (a char array) rather than a std::string in the struct to avoid the issues that will occur copying a std::string to and from the queue.
PiJohn
Mon Jun 14, 2021 5:56 pm
Thanks for the responses, yep, will try not using the string type.
Certainly seems much better now though once that variable is defined outside of the loop in the core function.
EDIT - after running the loop for a long time the struct was eventually corrupted as before :)
Going down the c char array route.
Return to “SDK”
