zapta
How to convert a double to a C string?
Tue May 11, 2021 3:24 pm
I am trying to convert a double to a C string. Any suggestion on how this can be done? Preferably without anything that will allocate memory from the heap. I looked at the SDK floating point functions bout couldn't find any string conversion.
E.g.
double x = -12.3.
char bfr[50]; // Assuming large enough.
double_to_string(x, 2, bfr); // value, after decimal point, buffer address, buffer size.
expecting bfr to have "-12.30\0";
cleverca22
Re: How to convert a double to a C string?
Tue May 11, 2021 3:31 pm
snprintf is the usual way to do that
jahboater
Tue May 11, 2021 3:39 pm
snprintf(bfr, 50, "%.2f", x);
or
sprintf(bfr, "%.2f", x);
which wont check that the buffer is large enough (but the C compiler may do so instead).
On the Pi you can say "man sprintf" to display the documentation.
carlk3
Tue May 11, 2021 5:23 pm
Yeah, I wouldn't be so sure that snprintf doesn't allocate memory. Have a look at newlib and FreeRTOS: "The most common functions that bite unsuspecting embedded developers are sprintf using %f, dtoa, ftoa, rand, and strtok."
I highly recommend mpaland/printf: Tiny, fast, non-dependent and fully loaded printf implementation for embedded systems.
cleverca22
Tue May 11, 2021 6:08 pm
the pico is already using its own variant of printf, rather then the one your toolchain provides
so it may already be a solved problem, you would have to double-check the disassembly of the final .elf file
zapta
Tue May 11, 2021 6:16 pm
Does the Pico's C++ SDK comes out of the box with sprintf that supports int64 and double ? Do I need to enable it somehow?
fivdi
Tue May 11, 2021 6:17 pm
The pico-sdk uses Marco Poland's printf / sprintf / snprintf implementation which doesn't allocate memory on the heap. See https://github.com/raspberrypi/pico-sdk ... f/printf.c
DarkElvenAngel
Tue May 11, 2021 7:03 pm
I haven't tried it but it might work out of the box. I'm not at my desk to try it.
carlk3
Tue May 11, 2021 8:43 pm
It works for me.
carlk3
Tue May 11, 2021 8:47 pm
That's the same implementation that I linked. I forgot that it was included in the SDK.
kilograham
Tue May 11, 2021 11:58 pm
yeah floats are on by default; you can turn off via PICO_PRINTF_SUPPORT_FLOAT=0
It is also turned off automatically if you do
set_pico_float_implentation(my_app none)
in your CMakeLists.txt, as the printf implementation for floats uses the floating point code!
zapta
Wed May 12, 2021 5:22 am
Thanks everybody! sprintf() indeed works with doubles and it solved by problem.
However, I am having problems with formatting int64 values. For example this code:
#include <inttypes.h>
uint64_t foo = 12345678912346;
printf("%s\n", PRId64);
printf("%d\n", foo);
printf("%" PRId64 "\n", foo);
printf("%ld\n", foo);
printf("%lld\n", foo);
Outputs this:
lld
536883544
ld
268607280
ld
DarkElvenAngel
Wed May 12, 2021 1:07 pm
Have a look at this https://stackoverflow.com/questions/922 ... -type-in-c
EDIT::
    const uint64_t foo = 12345678912346;
    Printf("%lld", foo);
Worked for me I got 12345678912346
My Printf function is a wrapper for vsprintf that write to my VGA screen buffer.
BTW didn't need to include inttypes.h
Last edited by DarkElvenAngel on Wed May 12, 2021 3:26 pm, edited 2 times in total.
kilograham
Wed May 12, 2021 2:52 pm
Outputs this:
lld
536883544
ld
268607280
ld
Trivial to try, so i did. and it works fine (the lines giving 0 give compiler warnings, are you getting any?)
lld
0
12345678912346
0
12345678912346
Are you using just the SDK or are you using some other environment?
zapta
Wed May 12, 2021 3:44 pm
Thanks @kilograham. I am using a platform adaptation of the SDK. Will take the question there.
Does the SDK has a #define or other setting that controls the support of int64 printf support?
Edit: I tried in the past to install the C++ SDK but it was way too complicated, going back to the days of the 'tool-chains'. These days I prefer out of the box installations similar to platformio (a full development environment) or Arduino (a minimalist environment). I hope that RPI will come with a simpler solution, preferably platformio.
fivdi
Wed May 12, 2021 4:59 pm
Yes, PICO_PRINTF_SUPPORT_LONG_LONG. See here.
WizIO
Thu May 13, 2021 5:05 am
for PlatformIO
project INI add:
board_build.nano = disable
by default is enabled: -specs=nano.specs
then %llu, %lld, PRIu64 .... is valid
zapta
Thu May 13, 2021 4:36 pm
Thanks WizIO, that works.
For anybody that interested, here is compatibility discussion on the platformio side.
https://community.platformio.org/t/my-p ... ce/21407/3
Return to “SDK”
