pic0
Check claim status of DMA channel
Mon Apr 19, 2021 11:29 am
how can I check if a DMA channel (specific channel number) is currently claimed or not?
When I do a
dma_channel_unclaim(channel);
it will end in a assertion if the given channel is not claimed before. So I want to call this function only in case the channel has been claimed before.
martinkooij
Re: Check claim status of DMA channel
Tue Apr 20, 2021 3:18 pm
Haven't found one in the SDK (you could check the SDK code how it administers claimed channels and add the function yourself ;). Or use a try/catch pair in C++ with exceptions enabled (haven't tried that one yet myself though).
I think the intended use case is my_chan = dma_claim_unused_channel(false). my_chany is negative when it fails and the channel number when you get one. At the end you can do dma_channel_unclaim(my_chan) to free for other users/libraries.
You want to unclaim a "surprise" channel that you didn't claim before?
Cheers,
Martin
pic0
Tue Apr 20, 2021 10:11 pm
yes, I have searched in the SDK too without success. Thats why I have asked.
The use case would be to release all active DMA channels. Yes, usually it is known which are were claimed before. But sometimes it would be easier to just do a simple loop and close just every channel.
But if there is no such function, I will go without it.
danjperron
Wed Apr 28, 2021 8:19 pm
Why not making you own!
in pico-sdk/src/rp2_common/hardware/dma.c add this function
bool dma_channel_is_claimed(uint channel) {
    check_dma_channel_param(channel);
    return hw_is_claimed(uint8_t *) &_claimed,channel);
and add the function declaration in the include/harwdare/dma.h
kilograham
Thu Apr 29, 2021 1:22 am
better still, make a PR on github
danjperron
Thu Apr 29, 2021 1:28 am
How long a PR will take ?
Maybe doing both is the best!
When the PR returns with something modify the code with the official code.
Return to “SDK”
