mytechnotalent
Contact: Twitter
TFT ST7735 Raspberry Pi Pico C Driver
Sun Feb 28, 2021 5:59 pm
Is anyone aware of a TFT ST7735 Raspberry Pi Pico C driver available for the Pico using C? I have one for MicroPython however I wanted to use this with the C SDK but I can't seem to find any.
Any information and/or with a simple code example would be helpful. Thanks in advance.
Kevin Thomas
Senior Software Engineer in Test
HermannSW
Re: TFT ST7735 Raspberry Pi Pico C Driver
Mon Mar 01, 2021 1:56 am
Pico not mentioned, but Raspberry.
ST7735S and C:
https://github.com/michal037/driver-ST7735S
https://stamm-wilbrandt.de/2wheel_balancing_robot
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/en/Raspberry_camera.html
mytechnotalent
Contact: Twitter
Mon Mar 01, 2021 2:39 am
ST7735S and C:
Thank you HermannSW! I will see what I can do but this is based on the WiringPi lib that I am not sure will compile inside of the Pico as it is a microcontroller with limited memory.
Kevin Thomas
tipam
Thu Apr 15, 2021 4:53 pm
Did you get the driver working for the Pico?
Raspberry Pi == small computer == big dreams
martinkooij
Thu Apr 15, 2021 5:49 pm
In the community libraries above I have a reference to HAL drivers that mentions your display as being tested...
https://github.com/tuupola/hagl_pico_mipi
I haven't used it myself. Just a pointer...
Have fun tinkering!
Martin
tipam
Fri Apr 16, 2021 9:55 pm
Have fun tinkering!
Martin
Thanks! I'll tinker!!
mytechnotalent
Contact: Twitter
Fri Apr 16, 2021 11:04 pm
No luck.
Kevin Thomas
tipam
Fri Apr 16, 2021 11:32 pm
No luck.
Works a treat with a cheap 128x160 LCD (st7735)!
Frame-rate averaging around 40+ FPS for the demos:
(right click image and open in new tab to view)
Had to do a bit of fiddling though ... on my RPi I opened a terminal win and entered the following;
(I am assuming that CMake is already installed)
git clone https://github.com/tuupola/pico_effects.git
git clone https://github.com/raspberrypi/pico-sdk.git
cd pico-effects/external
git clone https://github.com/tuupola/hagl_pico_mipi.git hagl_hal
git clone https://github.com/tuupola/hagl.git
cd ..
cmake ..
cd build
make
(Note: I didn't use tuupola's instructions as I had permission issues!)
I then encountered an error when making the project - it seems as though passing a 'uint64_t' to the timer function 'busy_wait_until' is no longer valid (line 210 in 'main.c' of pico-effects)
I changed the code to read:
absolute_time_t updatetime;
update_us_since_boot(&updatetime, start + US_PER_FRAME_60_FPS);
busy_wait_until(updatetime);
Lastly, I reconfigured the 'CMakeLists.txt' in the pico-effects folder with the following changes for my particular ST7735 160x128 screen ...
target_compile_definitions(firmware PRIVATE
  MIPI_DISPLAY_PIN_RST=21
  MIPI_DISPLAY_WIDTH=128
  MIPI_DISPLAY_HEIGHT=160
  MIPI_DISPLAY_DEPTH=16
  MIPI_DISPLAY_OFFSET_X=0
  MIPI_DISPLAY_OFFSET_Y=0
  MIPI_DISPLAY_INVERT=0
I then rebuilt with 'make' and a 'firmware.uf2' appeared in the build folder :D
Oh, and I used the following GPIO pins on my Pico connecting to my screen;
Pico      Screen
  Pin 21 = RST
  Pin 19 = SDA (MOSI)
  Pin 18 = SCL (CLK)
  Pin 17 = CS
  Pin 16 = DC
  3v3_OUT = VCC
  GND = GND
I hope that helps!
TIP: If you want to change the image, upload a small image (around 80x80 in size) to https://lvgl.io/tools/imageconverter and download a 'c array' ... select the '16 && LV_COLOR_16_SWAP != 0' byte section and paste into the head.h file (with correct width and height)
tuupola
Sun Apr 18, 2021 10:47 am
cd ..
cmake ..
cd build
make
I think you do not have ssh keys set up for GitHub? I changed the instructions to use https based cloning which should work without ssh keys. The following should work now:
$ git clone --recursive https://github.com/tuupola/pico_effects.git
Did you compile without NDEBUG flag? Pico SDK has different datatypes for time related functions depending on whether NDEBUG is set or not.Or maybe something has changed with the SDK recently, will check.
Mika Tuupola
https://appelsiini.net/
tipam
Sun Apr 18, 2021 11:16 am
cd ..
cmake ..
cd build
make
Fantastic! ... that's nice and simple :D
No, I didn't compile with the NDEBUG flag - maybe that could fix it?
Thanks for you're drivers - they're great!
mytechnotalent
Contact: Twitter
Sun Apr 18, 2021 11:49 am
Very helpful! Is there any code to actually work with text on this device as these all seem to be image libs.
Kevin Thomas
tuupola
Mon Apr 19, 2021 9:02 pm
I just checked and NDEBUG is set by default and code should build ok with the latest Pico SDK. I can reproduce the error only if I force the debug build with:
$ cd pico_effects/build
$ cmake -DCMAKE_BUILD_TYPE=Debug ..
$ make -j8
One possibility is that you tried to compile with old version of Pico SDK which had NDEBUG logic reversed. This was fixed mid march.
Mika Tuupola
Return to “SDK”
