George Shering
fifo and multicore.h
Sun Apr 11, 2021 2:22 pm
Problem 1:
I do not seem to have pico/multicore.h. is there something wrong with my installation.
Problem 2:
I feed sequences of 10 char into a hardware UART with fifos enabled. It only sees a single char, the first one, correctly . I feed the second UART in parallel using the interrupt to receive the data and I get all 10 correctly. The fifo is enabled? do I need to allocate memory for it somehow?
Please help.
EvanEscent
Contact: Website Yahoo Messenger Facebook Skype Twitter
Re: fifo and multicore.h
Sun Apr 11, 2021 2:45 pm
Re [2]: maybe a daft question but are you waiting for the fifo
to empty before you send additional data? If not you'll lose it.
I read, I tinker, I test, I repeat.
Sometimes I learn.
lurk101
Sun Apr 11, 2021 3:05 pm
You shouldn't need to wait for empty. Better to wait for 'not full'.
Growing old is getting old.
EvanEscent
Sun Apr 11, 2021 3:39 pm
This is true, depending on the responsiveness of the code.
I used empty imprecisely when I meant what you said. :)
Sometimes I learn.
George Shering
Sun Apr 11, 2021 3:59 pm
char numbytes;
while(1)
index=0;
dshot(100,1); // asks for 10 characters
busy_wait_us_32(2000);
numbytes=uart_is_readable(uart0);
if (numbytes>0)
for (int i=0;i<numbytes;i++) SerialBuf = uart_getc(uart0);
Wait 20ms then loop. numbytes is always 1. and SerialBuf[1] is changing and correct.
Reading the character on interrupt and filling the array there gives the same first character and the correct subsequent characters. I also checked on an oscilloscope.
Tried uart_set_fifo_enabled(uart0, true); both true and false.
it seems that there is never more than 1 byte in the buffer.
kilograham
Problem 1:
Please help.
You need to add pico_multicore to the target_link_libraries of your application; worth reading chapter 2 here https://datasheets.raspberrypi.org/pico ... -c-sdk.pdf
George Shering
Mon Apr 12, 2021 4:24 pm
multicore.h
I am trying to generate uart_rx whidh uses multicore
Thanks for the tip kilograham. I have started reading, but also to progress tried to generate uart_rx as a stand-alone example.
got as far as
-- Configuring done
CMake Error: Error required internal CMake variable not set, cmake may not be built correctly.
CMakeLists.txt is:
cmake_minimum_required(VERSION 3.16)
set(PICO_SDK_PATH /home/george/pico/pico-sdk)
include(pico_sdk_import.cmake)
project(uart_rx)
pico_sdk_init()
add_executable(pio_uart_rx)
pico_generate_pio_header(pio_uart_rx /home/george/pico/uart_rx/uart_rx.pio)
target_sources(pio_uart_rx PRIVATE uart_rx.c)
target_link_libraries(pio_uart_rx PRIVATE
pico_stdlib
pico_multicore
hardware_pio
pico_add_extra_outputs(pio_uart_rx)
Any suggestions?
kilograham
Mon Apr 12, 2021 6:03 pm
do
project(pio_uart_rx C ASM)
and recreate an empty build directory again first.
George Shering
Mon Apr 12, 2021 8:28 pm
Thanks kilograham. I see my mistake. It generates with project(pio_uart_rx).
But I had to remove the C ASM parts. I hope it will run.
I don't understand the "Code: Select all". It rejected that also.
Maybe as I read more!
I am developing on Ubuntu 20.04 on Intel!
pic0
Mon Apr 12, 2021 10:17 pm
this is just a feature of this forum. "code" means this block is formatted for showing programming code. And when you click on "Select all", all of the code in this block will be selected so you can easy copy it.
George Shering
Tue Apr 13, 2021 4:28 am
Code tested and runs. Thanks again kilograham.
I will ask on a more appropriate forum about the hardware uart fifo problem.
Return to “SDK”
