I2C OLED Display C//C++ Examples
Posted: Sun May 16, 2021 8:20 am
by a18041967
I’m desperately trying to configure my Pico to use I2C OLED display 3-5volts SSD1306, I’ve connected the display to the 3v pin and the SCL & SDA to pins 1 & 2 no matter what I try I never seem to get any display, my assumptions so far:
* Pins 1 & 2 are the default I2C interface
* OLED address is 0x78 this translates to 0x3c also tried 0x3d
* Multiple OLEDs tested, to rule out faulty display
* 3-5v is acceptable
I could add the various code that I have tested but I have followed this post:
https://www.element14.com/community/com ... duino-pico
Re: I2C OLED Display C//C++ Examples
Posted: Sun May 16, 2021 9:29 am
by bgolab
Many of the OLED modules on the marked are based on SH1106 chip. I used this kind of OLED successfully with the PICO. The 0,91" version.
I would check the chip version.
Posted: Sun May 16, 2021 9:32 am
by bgolab
I2C address of my chip is set to 0x3C
Posted: Sun May 16, 2021 9:09 pm
by TommyBurger
Put:
Wire.setSDA(0);
Wire.setSCL(1);
At the top of setup.
Posted: Mon May 17, 2021 8:21 am
by bgolab
Have you tried your drivers with the 0x3C address?
Posted: Mon May 17, 2021 2:31 pm
by a18041967
I’m making slow but good progress and decided to test using Python, I initially did a i2c scan which confirmed the address as being 0x3c and then I realised that I was using the wrong PIN numbers. I’d been using the actual PIN numbers 1 & 2 and I realised I should be using the GPIO numbers 0 & 1 and this resulted in success. So I now now know the correct address, PIN numbers and that the displays are all OK, I have tried C and still no success but that needs more work.
