In the PDF guides, it mentions that PI 5V and Pico VSYS should be connected via a diode, and ideally a Schotky diode. Is there any specifics specs to look at for this diode, or will any schotky diode work?
This is what I have so far. Not much, just added some headers, the EEPROM circuit from the hats github, and some links.
Would anyone recommend any tweaks/changes to the pi/pico wiring? Any extra protection necessary, or would it be OK as is?
I'll probably add a pair of headers alongside the pico headers so you can plug things in while it's in place. May also add some on-board bits and bobs for testing. A few RGB leds and such.
Edit: Note - I've not wired the SWD pins yet in that diagram.
