daniil1
Build project with makefile
Fri Jul 30, 2021 11:27 am
I am trying to build a project "blink" using a makefile. But it throws an unknown error, what am I doing wrong
Here is the makefile itself:
CXX      = arm-none-eabi-g++.exe
MCU      = -mcpu=cortex-m0plus
FLAG1    = -mthumb -O3 -DNDEBUG -Wl,--build-id=none
SPECS    = --specs=nosys.specs
PICO_SDK = K:\sdk
PICO_EXAMPLES = K:\example
PICO_OBJ = K:\obj
FLAG2    = \
	-Wl,--wrap=sprintf -Wl,--wrap=snprintf -Wl,--wrap=vsnprintf \
	-Wl,--wrap=__clzsi2 -Wl,--wrap=__clzdi2 -Wl,--wrap=__ctzsi2 -Wl,--wrap=__ctzdi2 \
	-Wl,--wrap=__popcountsi2 -Wl,--wrap=__popcountdi2 -Wl,--wrap=__clz -Wl,--wrap=__clzl \
	-Wl,--wrap=__clzll -Wl,--wrap=__aeabi_idiv -Wl,--wrap=__aeabi_idivmod -Wl,--wrap=__aeabi_ldivmod \
	-Wl,--wrap=__aeabi_uidiv -Wl,--wrap=__aeabi_uidivmod -Wl,--wrap=__aeabi_uldivmod -Wl,--wrap=__aeabi_dadd \
	-Wl,--wrap=__aeabi_ddiv -Wl,--wrap=__aeabi_dmul -Wl,--wrap=__aeabi_drsub -Wl,--wrap=__aeabi_dsub \
	-Wl,--wrap=__aeabi_cdcmpeq -Wl,--wrap=__aeabi_cdrcmple -Wl,--wrap=__aeabi_cdcmple -Wl,--wrap=__aeabi_dcmpeq \
	-Wl,--wrap=__aeabi_dcmplt -Wl,--wrap=__aeabi_dcmple -Wl,--wrap=__aeabi_dcmpge -Wl,--wrap=__aeabi_dcmpgt \
	-Wl,--wrap=__aeabi_dcmpun -Wl,--wrap=__aeabi_i2d -Wl,--wrap=__aeabi_l2d -Wl,--wrap=__aeabi_ui2d \
	-Wl,--wrap=__aeabi_ul2d -Wl,--wrap=__aeabi_d2iz -Wl,--wrap=__aeabi_d2lz -Wl,--wrap=__aeabi_d2uiz \
	-Wl,--wrap=__aeabi_d2ulz -Wl,--wrap=__aeabi_d2f -Wl,--wrap=sqrt -Wl,--wrap=cos \
	-Wl,--wrap=sin -Wl,--wrap=tan -Wl,--wrap=atan2 -Wl,--wrap=exp -Wl,--wrap=log -Wl,--wrap=ldexp \
	-Wl,--wrap=copysign -Wl,--wrap=trunc -Wl,--wrap=floor -Wl,--wrap=ceil -Wl,--wrap=round \
	-Wl,--wrap=sincos -Wl,--wrap=asin -Wl,--wrap=acos -Wl,--wrap=atan -Wl,--wrap=sinh -Wl,--wrap=cosh \
	-Wl,--wrap=tanh -Wl,--wrap=asinh -Wl,--wrap=acosh -Wl,--wrap=atanh -Wl,--wrap=exp2 -Wl,--wrap=log2 \
	-Wl,--wrap=exp10 -Wl,--wrap=log10 -Wl,--wrap=pow -Wl,--wrap=powint -Wl,--wrap=hypot -Wl,--wrap=cbrt \
	-Wl,--wrap=fmod -Wl,--wrap=drem -Wl,--wrap=remainder -Wl,--wrap=remquo -Wl,--wrap=expm1 \
	-Wl,--wrap=log1p -Wl,--wrap=fma -Wl,--wrap=__aeabi_lmul -Wl,--wrap=__aeabi_fadd -Wl,--wrap=__aeabi_fdiv \
	-Wl,--wrap=__aeabi_fmul -Wl,--wrap=__aeabi_frsub -Wl,--wrap=__aeabi_fsub -Wl,--wrap=__aeabi_cfcmpeq \
	-Wl,--wrap=__aeabi_cfrcmple -Wl,--wrap=__aeabi_cfcmple -Wl,--wrap=__aeabi_fcmpeq \
	-Wl,--wrap=__aeabi_fcmplt -Wl,--wrap=__aeabi_fcmple -Wl,--wrap=__aeabi_fcmpge -Wl,--wrap=__aeabi_fcmpgt \
	-Wl,--wrap=__aeabi_fcmpun -Wl,--wrap=__aeabi_i2f -Wl,--wrap=__aeabi_l2f -Wl,--wrap=__aeabi_ui2f \
	-Wl,--wrap=__aeabi_ul2f -Wl,--wrap=__aeabi_f2iz -Wl,--wrap=__aeabi_f2lz -Wl,--wrap=__aeabi_f2uiz \
	-Wl,--wrap=__aeabi_f2ulz -Wl,--wrap=__aeabi_f2d -Wl,--wrap=sqrtf -Wl,--wrap=cosf -Wl,--wrap=sinf \
	-Wl,--wrap=tanf -Wl,--wrap=atan2f -Wl,--wrap=expf -Wl,--wrap=logf -Wl,--wrap=ldexpf -Wl,--wrap=copysignf \
	-Wl,--wrap=truncf -Wl,--wrap=floorf -Wl,--wrap=ceilf -Wl,--wrap=roundf -Wl,--wrap=sincosf \
	-Wl,--wrap=asinf -Wl,--wrap=acosf -Wl,--wrap=atanf -Wl,--wrap=sinhf -Wl,--wrap=coshf -Wl,--wrap=tanhf \
	-Wl,--wrap=asinhf -Wl,--wrap=acoshf -Wl,--wrap=atanhf -Wl,--wrap=exp2f -Wl,--wrap=log2f \
	-Wl,--wrap=exp10f -Wl,--wrap=log10f -Wl,--wrap=powf -Wl,--wrap=powintf -Wl,--wrap=hypotf \
	-Wl,--wrap=cbrtf -Wl,--wrap=fmodf -Wl,--wrap=dremf -Wl,--wrap=remainderf -Wl,--wrap=remquof -Wl,--wrap=expm1f \
	-Wl,--wrap=log1pf -Wl,--wrap=fmaf -Wl,--wrap=malloc -Wl,--wrap=calloc -Wl,--wrap=free -Wl,--wrap=memcpy \
	-Wl,--wrap=memset -Wl,--wrap=__aeabi_memcpy -Wl,--wrap=__aeabi_memset -Wl,--wrap=__aeabi_memcpy4 \
	-Wl,--wrap=__aeabi_memset4 -Wl,--wrap=__aeabi_memcpy8 -Wl,--wrap=__aeabi_memset8
MAP    = -Wl,-Map=blink.elf.map
SKRIPT = -Wl,--script=$(PICO_SDK)/src/rp2_common/pico_standard_link/memmap_default.ld
FLAG3  = \
	-Wl,--gc-sections -Wl,--wrap=printf -Wl,--wrap=vprintf -Wl,--wrap=puts -Wl,--wrap=putchar -Wl,--wrap=getchar
OBJ = blink.c.obj \
	$(PICO_OBJ)/rp2_common/pico_stdlib/stdlib.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_gpio/gpio.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_claim/claim.c.obj \
	$(PICO_OBJ)/rp2_common/pico_platform/platform.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_sync/sync.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_uart/uart.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_divider/divider.S.obj \
	$(PICO_OBJ)/common/pico_time/time.c.obj \
	$(PICO_OBJ)/common/pico_time/timeout_helper.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_timer/timer.c.obj \
	$(PICO_OBJ)/common/pico_sync/sem.c.obj \
	$(PICO_OBJ)/common/pico_sync/lock_core.c.obj \
	$(PICO_OBJ)/common/pico_sync/mutex.c.obj \
	$(PICO_OBJ)/common/pico_sync/critical_section.c.obj \
	$(PICO_OBJ)/common/pico_util/datetime.c.obj \
	$(PICO_OBJ)/common/pico_util/pheap.c.obj \
	$(PICO_OBJ)/common/pico_util/queue.c.obj \
	$(PICO_OBJ)/rp2_common/pico_runtime/runtime.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_clocks/clocks.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_irq/irq.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_irq/irq_handler_chain.S.obj \
	$(PICO_OBJ)/rp2_common/hardware_pll/pll.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_vreg/vreg.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_watchdog/watchdog.c.obj \
	$(PICO_OBJ)/rp2_common/hardware_xosc/xosc.c.obj \
	$(PICO_OBJ)/rp2_common/pico_printf/printf.c.obj \
	$(PICO_OBJ)/rp2_common/pico_bit_ops/bit_ops_aeabi.S.obj \
	$(PICO_OBJ)/rp2_common/pico_bootrom/bootrom.c.obj \
	$(PICO_OBJ)/rp2_common/pico_divider/divider.S.obj \
	$(PICO_OBJ)/rp2_common/pico_double/double_aeabi.S.obj \
	$(PICO_OBJ)/rp2_common/pico_double/double_init_rom.c.obj \
	$(PICO_OBJ)/rp2_common/pico_double/double_math.c.obj \
	$(PICO_OBJ)/rp2_common/pico_double/double_v1_rom_shim.S.obj \
	$(PICO_OBJ)/rp2_common/pico_int64_ops/pico_int64_ops_aeabi.S.obj \
	$(PICO_OBJ)/rp2_common/pico_float/float_aeabi.S.obj \
	$(PICO_OBJ)/rp2_common/pico_float/float_init_rom.c.obj \
	$(PICO_OBJ)/rp2_common/pico_float/float_math.c.obj \
	$(PICO_OBJ)/rp2_common/pico_float/float_v1_rom_shim.S.obj \
	$(PICO_OBJ)/rp2_common/pico_malloc/pico_malloc.c.obj \
	$(PICO_OBJ)/rp2_common/pico_mem_ops/mem_ops_aeabi.S.obj \
	$(PICO_OBJ)/rp2_common/pico_standard_link/crt0.S.obj \
	$(PICO_OBJ)/rp2_common/pico_standard_link/binary_info.c.obj \
	$(PICO_OBJ)/rp2_common/pico_stdio/stdio.c.obj \
	$(PICO_OBJ)/rp2_common/pico_stdio_uart/stdio_uart.c.obj
CHECKSUMM = $(PICO_EXAMPLES)\build\pico-sdk\src\rp2_common\boot_stage2\bs2_default_padded_checksummed.S
CXX_DEFINES = -DLIB_PICO_BIT_OPS=1 \
	-DLIB_PICO_BIT_OPS_PICO=1 \
	-DLIB_PICO_DIVIDER=1 \
	-DLIB_PICO_DIVIDER_HARDWARE=1 \
	-DLIB_PICO_DOUBLE=1 \
	-DLIB_PICO_DOUBLE_PICO=1 \
	-DLIB_PICO_FLOAT=1 \
	-DLIB_PICO_FLOAT_PICO=1 \
	-DLIB_PICO_INT64_OPS=1 \
	-DLIB_PICO_INT64_OPS_PICO=1 \
	-DLIB_PICO_MALLOC=1 \
	-DLIB_PICO_MEM_OPS=1 \
	-DLIB_PICO_MEM_OPS_PICO=1 \
	-DLIB_PICO_PLATFORM=1 \
	-DLIB_PICO_PRINTF=1 \
	-DLIB_PICO_PRINTF_PICO=1 \
	-DLIB_PICO_RUNTIME=1 \
	-DLIB_PICO_STANDARD_LINK=1 \
	-DLIB_PICO_STDIO=1 \
	-DLIB_PICO_STDIO_UART=1 \
	-DLIB_PICO_STDLIB=1 \
	-DLIB_PICO_SYNC=1 \
	-DLIB_PICO_SYNC_CORE=1 \
	-DLIB_PICO_SYNC_CRITICAL_SECTION=1 \
	-DLIB_PICO_SYNC_MUTEX=1 \
	-DLIB_PICO_SYNC_SEM=1 \
	-DLIB_PICO_TIME=1 \
	-DLIB_PICO_UTIL=1 \
	-DPICO_BOARD=\"pico\" \
	-DPICO_BUILD=1 \
	-DPICO_CMAKE_BUILD_TYPE=\"Release\" \
	-DPICO_COPY_TO_RAM=0 \
	-DPICO_CXX_ENABLE_EXCEPTIONS=0 \
	-DPICO_NO_FLASH=0 \
	-DPICO_NO_HARDWARE=0 \
	-DPICO_ON_DEVICE=1 \
	-DPICO_PROGRAM_URL=\"https://github.com/raspberrypi/pico-examples/tree/HEAD/blink\" \
	-DPICO_TARGET_NAME=\"blink\" \
	-DPICO_USE_BLOCKED_RAM=0
CXX_INCLUDES = \
	-I$(PICO_SDK)\src\common\pico_stdlib\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_gpio\include \
	-I$(PICO_SDK)\src\common\pico_base\include \
	-I$(PICO_EXAMPLES)\build\generated\pico_base \
	-I$(PICO_SDK)\src\boards\include \
	-I$(PICO_SDK)\src\rp2_common\pico_platform\include \
	-I$(PICO_SDK)\src\rp2040\hardware_regs\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_base\include \
	-I$(PICO_SDK)\src\rp2040\hardware_structs\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_claim\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_sync\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_uart\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_divider\include \
	-I$(PICO_SDK)\src\common\pico_time\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_timer\include \
	-I$(PICO_SDK)\src\common\pico_sync\include \
	-I$(PICO_SDK)\src\common\pico_util\include \
	-I$(PICO_SDK)\src\rp2_common\pico_runtime\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_clocks\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_irq\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_resets\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_pll\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_vreg\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_watchdog\include \
	-I$(PICO_SDK)\src\rp2_common\hardware_xosc\include \
	-I$(PICO_SDK)\src\rp2_common\pico_printf\include \
	-I$(PICO_SDK)\src\rp2_common\pico_bootrom\include \
	-I$(PICO_SDK)\src\common\pico_bit_ops\include \
	-I$(PICO_SDK)\src\common\pico_divider\include \
	-I$(PICO_SDK)\src\rp2_common\pico_double\include \
	-I$(PICO_SDK)\src\rp2_common\pico_int64_ops\include \
	-I$(PICO_SDK)\src\rp2_common\pico_float\include \
	-I$(PICO_SDK)\src\rp2_common\pico_malloc\include \
	-I$(PICO_SDK)\src\rp2_common\boot_stage2\include \
	-I$(PICO_SDK)\src\common\pico_binary_info\include \
	-I$(PICO_SDK)\src\rp2_common\pico_stdio\include \
	-I$(PICO_SDK)\src\rp2_common\pico_stdio_uart\include
CXX_FLAGS = \
	-mcpu=cortex-m0plus -mthumb -O3 -DNDEBUG -ffunction-sections -fdata-sections -fno-exceptions -fno-unwind-tables \
	-fno-rtti -fno-use-cxa-atexit -std=gnu++17
all:
	$(CXX) $(CXX_DEFINES) $(CXX_INCLUDES) $(CXX_FLAGS) -o blink.c.obj -c blink.c
	$(CXX) $(MCU) $(FLAG1) $(SPECS) $(FLAG2) $(MAP) $(SKRIPT) $(OBJ) -o blink.elf
Re: Build project with makefile
Fri Jul 30, 2021 11:31 am
I doubt I will be able to help - we use CMake for very good reasons, but some indication of the error (copy of the result of running make?) would be useful. Along with the OS you are using and more details on the setup.
Working in the Applications Team.
jayben
Fri Jul 30, 2021 12:03 pm
It is possible to create a working executable using a makefile, but it is quite hard work, and the binary image I've produced is much larger than the cmake version, so I'm currently trying to understand why.
What is the actual error message? I suspect you are being tripped up by some cmake-specifics, or maybe the command line is just too long.
If that is true, a quick way to reduce the length is to put all the -D definitions in a single file (e.g. changing -DLIB_PICO_BIT_OPS_PICO=1 to #define LIB_PICO_BIT_OPS_PICO 1) then using the gcc -include command to force that file to be processed before everything else.
daniil1
Fri Jul 30, 2021 12:19 pm
Sorry, while I was solving the problem with the syntax, I forgot to describe the error itself.
I am building a project on windows 10 64 bit. I want to compile a project for Rasbery Pi Pico. The linker displays the error:
arm-none-eabi / bin / ld.exe: ERROR: Pico second stage bootloader must be 256 bytes in size
I don't want to use cmake, as the PICO library is built on every build. This is a very long time if I need to experiment with connecting different src files
Fri Jul 30, 2021 12:22 pm
That should not be the case - it should only build the files that have changed, and the SDK files won't be changing.
You are fixing the wrong problem. Fix the Cmake issue; so describe in more detail what you think the problem is and how is happens.
jayben
Fri Jul 30, 2021 1:11 pm
I had that problem, and I think it was because I hadn't used the correct linker script. The link line I'm using is:
$(BIN): lib $(SRC)
	$(CC) $(CFLAGS) --specs=nosys.specs -Wl,--build-id=none -Wl,--script=$(SDK_SRC)/rp2_common/pico_standard_link/memmap_default.ld -Wl,--gc-sections blink.c.obj -L./ -lpico -Wl,-Map=$(MAP) -o $(BIN) bs2_default_padded_checksummed.S
..where libpico.a is a library containing all the object files.
However I (as the most ardent supporter of simpler build systems) have to admit that cmake shouldn't be rebuilding everything when one of the source files is changed - you have an error in its configuration.
WizIO
Fri Jul 30, 2021 1:15 pm
the error:
the bootloader ( boot stage 2 ) is not compiled or not exist for the linker
or use some precompiled bootloaders
https://github.com/Wiz-IO/framework-wiz ... /main/boot
daniil1
Fri Jul 30, 2021 2:09 pm
You are right, I programmed the deletion of the output files myself. But I would still like to collect the PICO library separately and then link it with the project. And if that doesn't work, so much the better. This makes it possible to connect to the project only those objects that are necessary for the work of a particular project. Write your own makefile - it is great to control the output file
Fri Jul 30, 2021 2:26 pm
I'd suggest writing your own CMake files to do what you want, should fit in much better with the system. Much easier to trying to redo the entire CMake system in make (which CMake translates to anyway)
kilograham
Fri Jul 30, 2021 2:27 pm
Yeah, you are almost certainly trying to fix the wrong problem (which is none of our business, but then again you are opening yourself up to a world of hurt and fragility). The cmake only rebuilds files when it needs to (i.e. you change the files, you change the headers they depend on, or you change the compile options). This can of course happen as a result of you changing the dependent libraries since they inject defines into the build.
If you were using make I'd just say "add -j" to do a parallel build, but you can't do that with nmake. you can however use ninja which is about 10x faster for me on windows.
Of course unless you are building the entirety of pico-examples, I'm surprised it is slow for you anyway.
hippy
Fri Jul 30, 2021 2:37 pm
That seems to be a common motif when it comes to criticism of using 'cmake' but I haven't experienced it myself.
In my experience 'cmake' hasn't rebuilt anything it doesn't need to rebuild. Sometimes more can need rebuilding on a change than one might have expected but only because it's a more significant change than one had anticipated. Perhaps there are some cases where more may get rebuilt than strictly necessary but that's not been my experience.
If there is an issue then perhaps someone experiencing it could provide an example of 'cmake' rebuilding stuff when it shouldn't so it can be replicated and investigated, accepted as an issue or dismissed as not.
kilograham
Fri Jul 30, 2021 2:46 pm
yes, i guess there is some nuance here. the SDK code is itself recompiled when you make certain structural/config changes to what you are building (or include paths) or build defines. This is because the SDK is designed to be customizable on a per application basis, and you get a different/optimized set of code based on what you have chosen/what other libraries you have included
This may be surprising if you are used to a monolithic static library, however once again it shouldn't happen that much, and there aren't that many files that the SDK is usually pulling in.
hippy
Fri Jul 30, 2021 3:25 pm
I think so. If one is repeatedly adding and removing files during development, changing options, then a lot more may be rebuilt on every step to make the result optimal than would be when one has a pre-built library where the linker decides what to keep and discard.
That's seems to me a consequence of the design goal - optimal result - and working that way.
Adding files, simply not calling their routines rather than taking them out, when not strictly needed at a step, should mean a lot less rebuilding at each step.
MicroPython builds can be painful because MicroPython keeps a database of strings and allocated ID's, a small change can mean the database changes, which means everything depending on that databases needs to be rebuilt and that often explodes to 'everything'. Providing one doesn't affect that database, everything is a quick rebuild, only the thing edited and related being rebuilt.
I suppose it comes down to "I'd rather have a sub-optimal build and faster build times than an optimal build which rebuilds more frequently and takes longer".
I can empathise with the desire to keep a sub-optimal build which supports A, B and C as is, even if some or all are not required, because they will be later; continually re-building to keep optimal becoming a nuisance, which is perhaps the basis for criticism of the 'cmake' approach.
Fri Jul 30, 2021 3:56 pm
We are horribly spoilt nowadays when it comes to build times! When I was a lad, just after punch cards didn't become a thing, we still had to wait for a considerable time (many minutes, sometimes hours) to get any Pascal compile results out of the MicroVAX we used at University. In the end I moved to the BBC Micro Pascal system. Much quicker.
ejolson
Fri Jul 30, 2021 4:15 pm
I'm glad you figured out the problem with the linker. The project
https://github.com/Wiz-IO/framework-wiz ... e/main/SDK
appears to be a proof of concept in which the standard Pico SDK is reorganised to make it easier to use with make. I haven't looked at the details, but my impression is the include files have been automatically copied to a single include directory and the library precompiled into a single file.
Presumably this means only one directory is needed for headers and only one library for the routines they declare. It would be interesting to know if this alternative build system works and whether the resulting executables are the same size.
lurk101
Fri Jul 30, 2021 4:18 pm
I don't know how many times you'll need to repeat this before it sinks in?
BTW. The entirety of pico-examples compiles in 15 seconds on my Ubuntu box. Any project I've done so far on Pi4 has built in under a 30 seconds. I don't think build times are a legitimate concern.
Fri Jul 30, 2021 4:21 pm
Lots. Lots and lots.
hippy
Fri Jul 30, 2021 4:57 pm
It takes over 9 minutes to build 'pico-examples' on my Pi 3B (non-plus). Adding -j4 got that down to about a third, and gave me my first exposure to the 'ooh, that's hot' thermometer on my desktop.
A clean build of MicroPython takes over 3 minutes. With -j4 that falls to just over 2 minutes, so, as a whole, not so well suited to multi-core as the C and Pico SDK parts are.
On the other hand, a clean build of something simple like an out of tree "hello_usb" is just 45 seconds, reducing to 27 with -j4.
And most times I'm not doing clean builds. They usually zing along, a couple of seconds if nothing has changed.
Whether build times are problematic comes down to what one is doing, prepared to accept or put up with, how much money one is willing to throw at bringing them down.
I'm not complaining because I can live with what I get.
jahboater
Fri Jul 30, 2021 5:39 pm
When I learned Pascal at University, we handed the punched cards in during the afternoon and the next day we received a printout with the results.
Made you learn not to make careless mistakes ....
nick.mccloud
Sun Aug 01, 2021 7:35 pm
jahboater wrote: When I learned Pascal at University, we handed the punched cards in during the afternoon and the next day we received a printout with the results.
Punched cards? Luxury! Toggle switches on the Altair 8800. And if you tell the kids today that 640KB is enough, they don't believe you.
Pico/RP2040 ≠ Arduino
Pico = hot rod kit car, Arduino = hot rod kit car wrapped in cotton wool with buoyancy aids & parachute
ejolson
Sun Aug 01, 2021 8:52 pm
Where did you get an Altair 8800 with 640KB?
Return to “General”
