CX32
PICO with wifi
Mon May 17, 2021 9:23 pm
Is there a WiFi Pico coming soon?
Imperf3kt
Contact: Twitter
Re: PICO
Mon May 17, 2021 9:34 pm
No
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
Gavinmc42
Re: PICO
Mon May 17, 2021 9:41 pm
Not from Raspberry Pi Foundation?
Seen third party ones with things like ESP32 on them?
Not sure how many re shipping yet.
I'm dancing on Rainbows.
neilgl
Re: PICO
There is an Arduino using the RP2040 with WiFi - “ARDUINO NANO RP2040” I am buying one…
davidcoton
Re: PICO
Mon May 17, 2021 9:42 pm
https://store.arduino.cc/nano-rp2040-co ... th-headers
bgolab
Re: PICO
Tue May 18, 2021 12:11 pm
ESP-01/ESP-01S ESP8266 is the cheapest option for RP2040. Connected through UART, I guess
dshadoff
Re: PICO
Tue May 18, 2021 12:26 pm
Best bet is to look at the offerings from the likes of Pimoroni, Adafruit and Sparkfun. Some add-on boards are available, and there is at least one board with WiFi and RP2040 already together on the same board.
jayben
Re: PICO with wifi
Mon May 24, 2021 6:37 pm
I've got a Microchip ATWINC1500 WiFi module working with the Pico, see https://iosoft.blog/winc_wifi
Will be releasing the socket interface in the next week or two...
HermannSW
Re: PICO with wifi
Tue May 25, 2021 12:42 am
With ESP01.
Out of the Pico:
"Pico HTTPS GET through ESP01 serial2wifi"
viewtopic.php?f=146&t=307704&p=1852291#p1840946
Into the Pico:
"Re: Wireless Pico Micropython REPL"
viewtopic.php?f=146&t=307527&p=1840712#p1840001
https://stamm-wilbrandt.de/2wheel_balancing_robot
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/en/Raspberry_camera.html
lars_the_bear
Re: PICO with wifi
Tue May 25, 2021 7:26 am
Isn't a Pico with Wifi a Pi Zero W?
Kevin
Re: PICO with wifi
Tue May 25, 2021 8:18 am
Kevin
No, differing products entirely :roll:
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
Re: PICO with wifi
Tue May 25, 2021 8:19 am
I posted same day:
viewtopic.php?f=147&t=311992
HermannSW
Re: PICO with wifi
Tue May 25, 2021 1:48 pm
Just commented there:
HermannSW wrote:
Tue May 25, 2021 1:47 pm
If only Wifi is needed, then Pico 4$ + ESP01 2$ = 6$, but Arduino Nano does cost 22€=27$ ...
You get 4.5 Wifi enabled Raspberry Picos for same price as Arduino Nano, only network stack is not that nice.
lars_the_bear
Re: PICO with wifi
Tue May 25, 2021 5:30 pm
Kevin
Sigh... for the benefit of the irony-impaired, let me try again...
Why would the Raspberry Pi folks want to produce a wifi-enabled Pico, that would a direct competitor for one of their own, existing products? There would be two products with similar CPU and architecture, similar peripheral hardware, almost the same size, and I imagine about the same price.
At the moment there's kind-of clear water between the Pico and the original Raspberry Pi range. Start adding Wifi to the Pico, and the marketing situation will become very blurry. You might know what makes these products different, but I bet a lot of potential customers wouldn't.
Kevin.
hippy
Re: PICO with wifi
Tue May 25, 2021 5:47 pm
I understand exactly what you are saying - and it would create a challenging 'this or that' choice for some potential users, but there seems to me to be enough differentiation in capabilities to not cause a problem, the differences greater than the similarities.
And, on the other side of the coin, a Pico with Wi-Fi is a far better choice than a Zero W for some IoT applications, would increase income for the RPT rather than leaving competitor boards to capture that market.
jayben
Re: PICO with wifi
Tue May 25, 2021 7:24 pm
How many times have we seen Pi users complain that their real-time project doesn't work, as the OS adds indeterminate delays to their time-critical code? The Pi 3 & 4 are great desktop units, with an excellent hardware & software ecosystem, but (despite all my endeavours with DMA and SMI) doing real-time projects is really tricky - and as for the zero, it is remarkably slow, despite the CPU being quite fast.
Enter the Pico, which is much better suited to real-time work, with innovative I/O acceleration hardware, but to retrieve data from the board, you must tether it to a PC using USB or serial.
Hence the various WiFi projects for the Pico; it'll be interesting to benchmark my ATWINC1500 module against the various ESP devices, including the NINA-W102 module on the Arduino Nano RP2040 - mine may not be the cheapest module, but I'm hoping it'll have the best flexibility & performance.
Re: PICO with wifi
Tue May 25, 2021 7:38 pm
Kevin
Kevin.
Whatever :?
iiot2k
Re: PICO with wifi
Tue May 25, 2021 8:23 pm
I think, that the cheapest solution is with esp8266.
But I don't like the serial uart solution.
When I connect the W5500 ethetnet chip with 40Mhz spi clock to Pico, why is this
not possible with esp8266 connect to spi bus as sheep ?
Ok this need more complex programming.
I am sure, that on this forum exist lot of experts that able to write the code for esp8266.
dshadoff
Re: PICO with wifi
Tue May 25, 2021 8:51 pm
I'm not sure how well-developed their support libraries are, but there is also this device:
https://www.seeedstudio.com/Wio-RP2040- ... -4933.html
And it's interesting because if you want to make many of your device, you don't need to use the developer board, you can just get the module:
https://www.seeedstudio.com/Wio-RP2040- ... -4932.html
Gavinmc42
Re: PICO with wifi
Wed May 26, 2021 5:54 am
I regard the Pico as the foundation part.
The basic black model T with a RP2040 engine.
RPF have made it available to third party makers to add different bodies and accessories.
The Pico as it stands serves the RPF's primary Mission.
Seeed have been busy, nice little WiFi module.
lars_the_bear
Re: PICO with wifi
Thu May 27, 2021 1:09 pm
You're right, of course; but this situation is a function of the operating system, not the board. It's possible to run all the "desktop" Pi units without Linux, if you want to put the effort in. People generally don't, because it's not well documented, and there's no driver support.
But that's fundamentally true also if wifi is added to the Pico. Somebody will have to provide a software stack for it. That software could be provided for bare-metal "destop" Pi units as well, if anybody had the inclination.
The real difference, it seems to me (apart from wifi), between the Zero W and the Pico is that the Zero W has video support and more RAM. These are not trivial differences, I agree. I maintain, nonetheless, that a Pico-with-wifi would be encroaching into Zero W territory.
And let's not forget that there's a Pi Zero without wifi, that really only differs (at the hardware level) from the Pico in that it has built-in video. If running one of these bare metal was properly documented and supported, I suspect it would be very hard to distinguish it from the Pico. It's the same size and price, after all. In fact, a Zero (without wifi) would be a killer microcontroller if the bare-metal support was there. It's even cheaper than a VGA32, and has HDMI. It's only a mediocre Linux SBC, though, in my view.
In the end, though, it doesn't matter what I think. The Raspberry Pi folks will decide how best to manage their market, whatever I say.
Kevin.
mahjongg
Re: PICO with wifi
Thu May 27, 2021 1:46 pm
Keep in mind that you need not only hardware to add WiFi, you also need a WiFi-Stack, and that is a lot of software.
Re: PICO with wifi
Thu May 27, 2021 1:55 pm
The RP2040 is a microcontroller, the BCM2835 is a SoC. They are VERY different beasts, not comparable at all.
Notwithstanding the different peripheral set (Rp2040 has some basic interfaces, BCM2835 has native HDMI video, 2 and 3D acceleration, camera interfaces and ISP, display interfaces, HW codecs for video etc), but the processor cores are quite different, the RP2040 is a twin core Arm M0 running at 133Mhz, the BCM2835 is a single core Armv6 running at 1GHz, the BCM2835 also has a MMU, the RP2040 doesn't.
So, even if we did come up with a Pico with wireless, they are nowhere near the same product.
Working in the Application's Team.
jayben
Re: PICO with wifi
Thu May 27, 2021 2:14 pm
Agreed, and I'm not suggesting they should be the same; the use-case I'm advocating is a headless data acquisition unit, so no need for a video output, or a lot of CPU horsepower, but the ability to work in real time without random OS interruptions is essential, as is wireless networking.
Anyway, it looks like events are overtaking this discussion, since various wireless RP2040 boards are just becoming available; I'm eagerly awaiting their arrival.
cpq
Re: PICO with wifi
Sat May 29, 2021 3:11 pm
With ESP32 module or ESP32 board, and a pre-built ESP32 firmware, it is possible to:
- Turn ESP32 into a remote programmer and UART <-> Internet bridge
- Wire RP2040 board to the ESP32 via UART and SWD pins
- The ESP32 could reflash RP2040 remotely at any time
- The ESP32 could transparently bridge RP2040's UART to an external server of your choice - MQTT or Websocket
This way, no extra network programming is required on the RP2040 side. It becomes connected without even being aware about it.
Here is a howto:
- RP2040 <-> ESP32 wiring https://vcon.io/docs/#raspberrypi-pico
- Flashing ESP32 firmware https://vcon.io/docs/#generic-esp32
Disclaimer - the above uses a product vcon.io, which I do represent. It is free to use for the first 10 registered devices.
Return to “Other RP2040 boards”
