jhihn
I2C repeat start support?
Sun May 09, 2021 2:55 pm
I just got burned on a project where the slave was using repeat start variant fo the I2C protocol but the connected micro did not support it.
Can I get official word if Pi Pico supports the repeat-start variant protocol?
The slave is: https://learn.adafruit.com/using-melexi ... s?view=all
"This sensor uses a slightly non-standard type of I2C called "repeated-start". If you are not using an Arduino, make sure your microcontroller can support "repeated start I2C requests"!"
ronter
Re: I2C repeat start support?
Sun May 09, 2021 5:02 pm
Section 4.3 of RP2040 Datasheet says it supports I2C Restart. I haven't actually tried it, though.
fivdi
Sun May 09, 2021 5:41 pm
It should work. Take a look at the nostop parameter that can be passed to several of the I2C read and write functions. See here.
pica200
Mon May 10, 2021 5:42 pm
What do they mean with its non-standard? As far as i know repeated start is perfectly fine and standard behavior for devices with registers when you change the direction.
Return to “General”
