So the encoder has nothing to do with power on/off.
Pressing two keys for 2 sec is easily catched in the kernel.
Power on by pressing F10 does not really apply power as the unit is powered from the USB C port. So you can just put chips in suspend state and wait for F10.
Re: The Raspberry Pi 400 thread!
In a way I'm glad the keyboard controller is only one-time programmable, as I suspect a key logger would have been one of the first projects.
Does the Pi 400 power on immediately after recieving power, or does one need to push the power button as well after plugging it in the first time?
my theory, is that there is a mosfet somewhere, that can cut the main 5v rail off when you shutdown, and then the SoC is 100% deadkarrika wrote: ↑Fri Nov 06, 2020 3:35 pmSo the encoder has nothing to do with power on/off.
but the uC handling the keyboard matrix remains active (on the usb-c side), and can turn that mosfet back on when you hit the magic key
the keyboard uC might even stop its scanning, just activate one row permanently, and then use gpio edge interrupts on the right column, so it can only wake to a single key
but ive not checked its datasheet in detail, to see if its capable of that
still waiting for my pi400 to arrive, and then i can begin to analyze and confirm/deny my theories
Won't quite work with a Pi400...but my general solution is two (hopefully, 3 some time late next Spring) KVM switches. I have enough ports to handle 11 devices, assuming the right sorts of connections are available on them.fanoush wrote: ↑Fri Nov 06, 2020 11:59 amThis was my first reaction too but it has some merit, kind of remote desktop/KVM, imagine your Pi 400 with monitor and then another Pi or PC with screen next to it but no keyboard. Happens to me when having more Pi-s on the desk , e.g. two displays, two Pi-s, just one keyboard. In fact I was just thinking about ordering second raspberry keyboard when Pi400 came. Obviously I ordered Pi400 but now I will have three Pis with two keyboards, same problem.davidcoton wrote: ↑Fri Nov 06, 2020 11:44 amYou didn't notice that Pi keyboards are available without the SOC etc? Much lower cost, full keyboard functionality of the Pi400 (except power control, but that wouldn't work on a target PC).
There seems to be more naughty kids on the block that want to take their Pi 400 apart to see what makes it tick.cleverca22 wrote: ↑Fri Nov 06, 2020 3:43 pmmy theory, is that there is a mosfet somewhere, that can cut the main 5v rail off when you shutdown, and then the SoC is 100% deadkarrika wrote: ↑Fri Nov 06, 2020 3:35 pmSo the encoder has nothing to do with power on/off.
I did read the datasheet of the controller. It can go to low power sleep by executing HALT.
It can wake from sleep by taking an IO-line from high to low.
But this also means that all the keyboard scan lines must be hi or low. They cannot be floating. As wakeup reacts to a key press going from high to low that scan line must be powered.
I really don't see why they would have added a powerful MOSFET to the 5V rail. Software is cheaper.
On a portable unit a MOSFET makes perfect sense. But the Pi 400 does not run on batteries.
With a keyboard built into the computer there is no need for a KVM switch. At the same time, one should still be able to plug another keyboard into the Pi 400 and use that in place of or in addition to the built-in one.W. H. Heydt wrote: ↑Fri Nov 06, 2020 4:43 pmWon't quite work with a Pi400...but my general solution is two (hopefully, 3 some time late next Spring) KVM switches. I have enough ports to handle 11 devices, assuming the right sorts of connections are available on them.fanoush wrote: ↑Fri Nov 06, 2020 11:59 amThis was my first reaction too but it has some merit, kind of remote desktop/KVM, imagine your Pi 400 with monitor and then another Pi or PC with screen next to it but no keyboard. Happens to me when having more Pi-s on the desk , e.g. two displays, two Pi-s, just one keyboard. In fact I was just thinking about ordering second raspberry keyboard when Pi400 came. Obviously I ordered Pi400 but now I will have three Pis with two keyboards, same problem.davidcoton wrote: ↑Fri Nov 06, 2020 11:44 am
Given how well RealVNC works and even the xorgxrdp remote desktop, I see little reason for switching the same keyboard between multiple computers. Simply attach one keyboard and two monitors to the computer which needs ultra-low latency for gaming and conferencing; then use the others through the network.
It's an amazing to think a single Pi 400 could be the point from which to control all other networked computers.
- HermannSW
- Contact: Website Twitter YouTube
In this postingfruitoftheloom wrote: ↑Fri Nov 06, 2020 9:37 amPresuming the same USB Via Hub Chip as 4B total for all 4 ports (keyboard use one) is 1200mA.
viewtopic.php?f=63&t=290131&p=1755625#p1754996
W. H. Heydt made me aware that a USB 3.0 port needs to be capable of delivering 0.9A.
I just looked up for USB 2.0, and there it is 0.5A.
So Pi4B as well as Pi400 with only 1200mA are underpowered for 4 USB ports (2*0.5A+2*0.9A=2.8A would be needed according spec):
https://en.wikipedia.org/wiki/USB
There is a <10$ 4port USB 3.0 hub that can be powered with 5V/2A.
If using only two of the 4 ports, they are correctly powered.
If connecting two of those hubs to both Pi400 USB 3.0 ports, and using only 2 ports per hub, you get 4 correctly powerd USB 3.0 ports (4*0.9A < 2*2A) for the Pi400:
https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/working_with_FPGAs
Yes. That has always been the case with Pis. The original Model B had 140mA polyfuses, one for each (of two) USB 2 ports. Those were first replaced by zero ohm resistors (a simple change in component with no PCB change) and later eliminated altogether.HermannSW wrote: ↑Fri Nov 06, 2020 5:20 pmSo Pi4B as well as Pi400 with only 1200mA are underpowered for 4 USB ports (2*0.5A+2*0.9A=2.8A would be needed according spec):
Who knows...perhaps the innovative change for the Pi5B will be to provide standard specified power for the USB ports... (That would probably mean a board specification of a 5A PSU.)
Sure, the kernel can catch the shutdown key combination; but how does it catch the power-up key press ? It can only do that if the SoC is powered up and running, along with a USB stack, which means soft power-off is far short of powered off. I can't see that as the chosen model but perhaps it is.karrika wrote: ↑Fri Nov 06, 2020 3:35 pmSo the encoder has nothing to do with power on/off.
It could be that the kernel catches shutdown and there's some additional hardware monitoring the single key which powers it back on.
The keyboard encoder is programmable and low power so that's where I'd put the on-off control.
But we won't know until someone tells us or reverse engineers the circuitry and figures out where control signals go.
I did note that putting a Pi400 (and my first one is due to be delivered today) behind a KVM switch won't really work... Well, it would, but there's no real point to it as it still has its own keyboard.ejolson wrote: ↑Fri Nov 06, 2020 4:58 pmWith a keyboard built into the computer there is no need for a KVM switch. At the same time, one should still be able to plug another keyboard into the Pi 400 and use that in place of or in addition to the built-in one.W. H. Heydt wrote: ↑Fri Nov 06, 2020 4:43 pmWon't quite work with a Pi400...but my general solution is two (hopefully, 3 some time late next Spring) KVM switches. I have enough ports to handle 11 devices, assuming the right sorts of connections are available on them.fanoush wrote: ↑Fri Nov 06, 2020 11:59 am
I do make some use of VNC, however I do my best to have a direct link (through the KVM switches) between a Pi being booted and the monitor on my desk so that the Pi will get the geometry right. The reason being that not all of my Pis use the same monitor geometry all the time, so I don't want to "hard code" that in config.txt. Beyond that...not all the systems behind the KVM switches are Pis, so even NOT having the Pis on a KVM switch, the switch is still needed.
There are other Pis that are up from time to time that I *don't* run through the KVM. The usual reason is that they're brought up for software update/upgrades, may be running RPiOS Lite, and ssh is suitable to doing the work. A typical use for that is a Pi0 or Pi0W with a 3.5" display on the GPIO pins. I just plug in a USB to Ethernet adapter and power and away it goes.
- Contact: Website Facebook Twitter YouTube
Fn alone doesn't send a keypress - it has to be used with other keys, so the OS just would wait for Scroll Lock being held down for two seconds and then do sudo poweroff. In that case it would also power off if Scroll Lock was sent from other keyboards. It could also be the keyboard controller that detects Fn+F10 and powers off using a GPIO (hopefully one not connected to the GPIO port in order not to interfere with user projects). Powering on could be done by the keyboard controller lowering GPIO3 (pin 5) for a short while when it detects F10.karrika wrote: ↑Fri Nov 06, 2020 3:35 pmSo the encoder has nothing to do with power on/off.
This would be similar to this project:
https://howchoo.com/g/mwnlytk3zmm/how-t ... spberry-pi
Have Pi0&1A&1B&1B+&2B&3B&4B w/ rasPiOS. Started w/ BASIC on ABC80&ZX81 then Forth, Z80… https://scratch.mit.edu/users/mobluse/ https://github.com/mobluse/ https://twitter.com/mobluse/ https://YouTube.com/MOBiL4u/
It should be easy to determine whether the keyboard encoder chip or the kernel is catching the "power off" key combination. If it doesn't work with an external USB keyboard, it isn't the kernel. I don't have a Pi400 to try it.
Quis custodiet ipsos custodes?
mob-i-l wrote: ↑Fri Nov 06, 2020 6:01 pmFn alone doesn't send a keypress - it has to be used with other keys, so the OS just would wait for Scroll Lock being held down for two seconds and then do sudo poweroff. In that case it would also power off if Scroll Lock was sent from other keyboards. It could also be the keyboard controller that detects Fn+F10 and powers off using a GPIO (hopefully one not connected to the GPIO port in order not to interfere with user projects). Powering on could be done by the keyboard controller lowering GPIO3 (pin 5) for a short while when it detects F10.karrika wrote: ↑Fri Nov 06, 2020 3:35 pmSo the encoder has nothing to do with power on/off.
[clever@amd-nixos:~/apps/rpi/linux/arch/arm/boot/dts]$ vi bcm2711-rpi-400.dts
// Board specific stuff here
power_ctrl: power_ctrl {
compatible = "gpio-poweroff";
gpios = <&expgpio 5 0>;
force;
it says that if external gpio 5 (the i2c gpio expander) goes to a certain state, it should act like the power button has been pressed
that gets routed to systemd, which will do the configured action for the power button, as it would on any x86 machine
but, that doesnt explain how things get turned back on
and the rpi4 draws 110mA, even in its lowest power state, thats definitely power you could save if you just cut power to the SoC entirely
the old POWER_OFF_ON_HALT could still be used for that, then the keyboard uC only has to poke the GLOBAL_EN to kick the PMIC back into gear, and it will come back up
Wow. I am surprised to learn that Fn does not send keycodes like the other modifiers do (Left Shift, Right Shift, Alt and Ctrl). But it actually modifies the keycodes sent by the keyboard.mob-i-l wrote: ↑Fri Nov 06, 2020 6:01 pmFn alone doesn't send a keypress - it has to be used with other keys, so the OS just would wait for Scroll Lock being held down for two seconds and then do sudo poweroff. In that case it would also power off if Scroll Lock was sent from other keyboards. It could also be the keyboard controller that detects Fn+F10 and powers off using a GPIO (hopefully one not connected to the GPIO port in order not to interfere with user projects). Powering on could be done by the keyboard controller lowering GPIO3 (pin 5) for a short while when it detects F10.karrika wrote: ↑Fri Nov 06, 2020 3:35 pmSo the encoder has nothing to do with power on/off.
I wonder if someone who already has a Pi 400 could run
sudo showkey -k
On my laptop Fn + F10 returns "keycode 190" which is also "microphone on/off"
What I want to know is...
Could one use the Pi 400 as a regular keyboard to a PC or whatever?
Probably, if the USB-C power socket is the same as on a 4B in the sense that it can function as a USB device. But same issue as with a 4B of getting enough power into the socket while connected to a USB host device.
ive been doing a lot of usb gadget testing on my pi4, and while the power led is basically off permanently (stuck below the trigger level), it seems to run "fine"
but i'm not actually mounting the SD card (it runs from an initrd), so there is nothing i could corrupt, it looses all state at shutdown, by design
I should probably note, for the benefit of those reading this thread who have come here relatively recently, that I am probably an outlier in use of Pis, and that in more than one way. So remarks about my own setup (multiple KVM switches, bunches of Pi, and all) should not be taken as a typical of how most Pi owners are set up.
you may also want to look into software like synergyW. H. Heydt wrote: ↑Fri Nov 06, 2020 7:32 pmI should probably note, for the benefit of those reading this thread who have come here relatively recently, that I am probably an outlier in use of Pis, and that in more than one way. So remarks about my own setup (multiple KVM switches, bunches of Pi, and all) should not be taken as a typical of how most Pi owners are set up.
with that, you can trivially manage a dozen systems from a single keyboard/mouse, as long as each one has its own monitor
I expect the latency would be irritating to first decode the USB keyboard inside the Pi 400 and then use the results to emulate another keyboard as a gadget through the USB C connector. On the other hand, it could make for the ultimate in programmable keyboards. Who's going to try it first?
you could already try it with an rpi4, just read any keyboard (including usb) input via /dev/console or running the app on the console, and then HID gadget it back to another pcejolson wrote: ↑Fri Nov 06, 2020 7:38 pmI expect the latency would be irritating to first decode the USB keyboard inside the Pi 400 and then use the results to emulate another keyboard as a gadget through the USB C connector. On the other hand, it could make for the ultimate programmable keyboard. Who's going to try it first?
Keyboards are polled over USB at no more than 1ms intervals (typically 8ms). This means - if you write your code sensibly - that the ~8ms poll time for the downstream keyboard is added to the <=1ms latency for the upstream "keyboard" so no more than 9ms lag. Barely perceptible.ejolson wrote: ↑Fri Nov 06, 2020 7:38 pmI expect the latency would be irritating to first decode the USB keyboard inside the Pi 400 and then use the results to emulate another keyboard as a gadget through the USB C connector. On the other hand, it could make for the ultimate in programmable keyboards. Who's going to try it first?
Using a whole computer as a hosted keyboard seems like overkill, though...
Rockets are loud.
https://astro-pi.org
Yes it would be.
The plan would be to have use of the Pi in the keyboard and whatever other machine it is is connected to, as a keyboard, at the same time. Hopefully saving keyboard clutter on the desk.
Just use Barrier.
