Frank the german
Workspace switcher
Mon Jun 14, 2021 12:32 am
I just tried to add a workspace switcher to the panel. Then i suddenly noticed that i couldn't maximize/minimize/drag or click off. i removed it from the panel and rebooted. Ok it was removed but i still can't do any of the above... Could somebody please tell me where i went wrong? ANY help would be much appreciated...
GlowInTheDark
Re: Workspace switcher
Mon Jun 14, 2021 12:52 am
What is a workspace switcher?
Poster of inconvenient truths.
Linux zealot and proud of it.
Frank the german
Mon Jun 14, 2021 12:55 am
...where i can literally have different workspaces on the screen ie internet on one then open files on the next etc... The only difference is that it is called Desktop pager on Rpi
kerry_s
Mon Jun 14, 2021 12:58 am
menu> preferences> appearance> default tab, medium, then reboot.
Frank the german
Mon Jun 14, 2021 1:03 am
Yes that worked. Thank you. On a different note is there anything i need to be aware of when adding the Desktop pager?
kerry_s
Mon Jun 14, 2021 1:29 am
add the desktop pager, then right click it on the panel, set the number of desktops & close.
that should be all it takes, the last time i used it. there's a manual way to increase desktops by editing a file.
lxde & openbox settings are not compatible with raspberry os. only use the appearance in preferences, it wasn't built to really tweak unless you know what your doing.
Frank the german
Mon Jun 14, 2021 1:53 am
If I install for example a Mate desktop (my preferred version from my Linux laptop) then I wouldn't have this problem? Me thinks, this can be changed...
scruss
Mon Jun 14, 2021 2:25 am
If you install an alternative desktop, there's a fair chance that the regular raspberrypi-uimods (or some similar name) updates will revert it.
Pronouns: he/him
kerry_s
Mon Jun 14, 2021 2:28 am
:lol:
you need to come over to the darkside & be free.
select editions at the top.
https://manjaro.org/download/#raspberry-pi-4
mate:
https://manjaro.org/downloads/arm/raspb ... pi-4-mate/
i use a custom sway install on my rpi400, it's tweaked so i can use the mouse more instead of it being more keyboard oriented. i like to lean back in my chair. :D
Frank the german
Mon Jun 14, 2021 8:11 am
OK, how do I avoid a change in desktop being thrown out again?
Frank the german
Mon Jun 14, 2021 8:15 am
:lol:
mate:
Sounds intriguing. How solid is it though? I need something that pretty much works out of the box as I'm planning to use my Pi for work (!). I do a lot of text research and sourcing and need something that can give me a few workspaces at a time without crashing...
kerry_s
Mon Jun 14, 2021 11:32 am
don't have a spare sd card/usb? you should also have something for backups.
i keep several installs of different setups, just shutdown & swap.
for example:
i've booted my manjaro i3 install & i'm seeing how close i can get it to look like my sway install.
right now i'm in tabbed mode, my eyes are bad today(high sugar level), so i'm running at 1280x720, not really good for tiling.
Frank the german
Mon Jun 14, 2021 11:52 am
for example:
I keep seeing this recommendation about a spare SD card a backups. Are they generally a bit tricky? Is it better to run of a usb drive/SSD? I'm currently only practising on my Pi but can see a lot of really good uses for it. In case the Desktop pager doesn't work out how would it be with a double screen? Is there scope for this?
kerry_s
Mon Jun 14, 2021 12:16 pm
sorry, was busy writing scripts for my system monitors.
i been getting back to sd cards cause, there's just to much clutter/wires hanging out the back.
i use all 3 types, this i3 install is currently running from a usb 3 flash drive.
just use what you got.
double screen, sorry only have a single screen.
manjaro mate should be fine with dual screens.
Frank the german
Mon Jun 14, 2021 12:20 pm
Looks like i need to do a bit more homework regarding this. Plenty of good ideas though. Thank you
Frank the german
Fri Jun 18, 2021 6:47 pm
Sorry for being a pain but could this be made to work?
https://www.synaptics.com/products/disp ... ads/ubuntu
kerry_s
Fri Jun 18, 2021 8:44 pm
are you using ubuntu?
https://ubuntu.com/download/raspberry-pi
Frank the german
Fri Jun 18, 2021 8:58 pm
I keep forgetting that there is a Ubuntu download for the Pi. How stable is this yet? And also how fast is it? If i remember right Ubuntu is quite big on memory...
kerry_s
Sat Jun 19, 2021 3:35 am
you got to try it for yourself, we all think of "fast" differently.
stability, it's on par with other os's.
gnome has come a ways, it's around 600mb at boot & 1.3gb running a browser, but the new gnome caches a lot more for speed, if you look in the system monitor it will show you how much is actually cache.
electronicstoday
Sat Jul 17, 2021 1:54 am
Something to switch workspaces. Yeah, sorry for being unable to resist... :P
Return to “Raspberry Pi 400”
