lornova
Raspberry Pi 400 replacement motherboard
Fri May 07, 2021 4:41 pm
My Pi 400 has some electrical problem: I connected an FTDI-USB module to the GND, TXD and RXD pins of the GPIO of the Pi 400, and the CP2102 chip smoked and desoldered itself from the FTDI-USB module PCB. I tried another module and it burned, too.
The Raspberry boots and seems to work, with the exception of the UART (I haven't tested other GPIO pins).
It is possible to order just a replacement mainboard for the Raspberry Pi 400? Even if the price is almost the same as the full system, I'd like to savage the keyboard/case/heatsink to avoid a bit of e-waste...
ejolson
Re: Raspberry Pi 400 replacement motherboard
Fri May 07, 2021 4:47 pm
I accidentally connected the 5V output of an FTDI-USB module to the TXD pin of the GPIO of the Pi 400... The CP2102 chip smoked and desoldered itself from the FTDI-USB module PCB..
The Raspberry Pi 400 kinda survived: it boots and so far seems to work, with the exception of the UART (I haven't tested other GPIO pins).
Since the Pi 400 is a consumer device (not a component like the others), it should be repairable. It's price, like a toaster, may be too cheap to fall under any proposed or enforced legislation.
Once in a while someone posts on this forum that they broke the keyboard but not the Pi inside. Maybe some sort of swap to create a single working Pi 400 could be performed next time this happens.
Where I live a rather huge two compressor refrigerator was just sent to the dump because one of the compressors ran out of gas or something. When stuff like that happens, worrying about the Pi is like trying to solve a drought by foregoing a glass of water at the restaurant.
lornova
Mon May 10, 2021 4:02 pm
Just a little update: my initial thought, that I misconnected the FTDI module, was wrong because... I cut the 3V3 and the 5V pins from the FTDI module, just to avoid that kind of mistake! In fact, it is the Raspberry Pi 400 that is outputting 5V from the GPIO pins :shock:
Pi 400 Broken GPIO.jpg (152.02 KiB) Viewed 1173 times
Mon May 10, 2021 4:59 pm
Well, you've got that board plugged in to your Pi the wrong way round, so you're actually testing between Pin 2 (5V) and Pin 33 (GPIO 13).
I could be wrong. See next post.
Unreadable squiggle
aBUGSworstnightmare
Mon May 10, 2021 7:25 pm
there are GPIO expansion boards out in the field which rotate the Pi400 GPIO by 180deg -> HAT would face away from the Pi. Also got fouled by such a boads picture once (viewtopic.php?f=140&t=309654) and need to say that I stop answering questions related to them. Too much confusion .. And too much risk for unexperienced folks to blow their Pi400 --> wont take that risk!
Let me repeat what I've said in a similiar thread: in case you want to use HATs the simplest solution is by this https://shop.pimoroni.com/products/spar ... rry-pi-400
Note: I'm not related to sparkfun nor pimoroni! This PCB is simply more easy to use for starters as the GPIO position is same as with every other RPi, hence all 'tutorials' starters may follow are valid.
Last edited by aBUGSworstnightmare on Wed May 12, 2021 5:03 am, edited 4 times in total.
Mon May 10, 2021 8:07 pm
there are GPIO expansion boards out in the field which rotate the Pi400 GPIO by 180deg -> HAT would face away from the Pi. Also bot fouled by such a boads pic again and need to say that I stop a swering questions related to them. Too much confusion .. And too much risk for unexperienced folks to blow their Pi400 --> wont take that risk!
Yes, you could be right. The tracks on that board do look like they could be switching the directions. I'll retract my earlier comment.
Unreadable squiggle
Gavinmc42
Tue May 11, 2021 11:21 am
Isn't that one of the two 5V pins in the normal Pi header?
Is that plugged in upside down?
No idea, just took the rubber cap off mine for the first time, some molded labels hard to read.
Page 20 of the Beginners Guide helps, might try looking again in daylight.
I'm dancing on Rainbows.
drgeoff
Tue May 11, 2021 6:06 pm
Something not right somewhere. If the red multimeter lead is really on a ground point then the meter is showing 5 Volts negative.
cleverca22
Tue May 11, 2021 6:09 pm
yeah, now i'm even more confused!
where did that board come from?
is the meter wired up correctly?
mahjongg
Sat May 15, 2021 3:00 pm
If you look at the back side of the PI400, you can clearly see that PIN-1 is labeled with text in the plastic case near the GPIO header.
Gavinmc42
Sat May 15, 2021 10:58 pm
Not so clear for old eye without a bight light.
Looks like that connector is plugged in reversed if those two red 5V pins are on the right hand side.
HermannSW
Sun May 16, 2021 12:43 am
Take your Pi400 , keeping front on desk and back high.
Then the GPIO layout is identical to all PIs.
Not sure what you mean with reversed.
https://stamm-wilbrandt.de/2wheel_balancing_robot
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/en/Raspberry_camera.html
Gavinmc42
Sun May 16, 2021 1:09 am
The colour codes on the PCB.
Two red 5V and one orange 3.3V pins are on the right side of the board looking from the front of the Pi 400.
Sun May 16, 2021 5:16 am
The board doesn't appear to be a simple extender. It looks like it turns the connections around so that if you plug a HAT in to it it will be with the connector side toward the Pi 400 and the rest of the HAT away from it.
Unreadable squiggle
Gavinmc42
Sun May 16, 2021 5:28 am
Yep, those tracks don't go straight across.
No idea how 5V show up on those pins.
If that does switch around then the Red probe would be on GND pin 39 and black probe on pin 8 - GPIO 18/TX.
The multimeter would then display -5V?
Where does that PCB come from?
Return to “Raspberry Pi 400”
