whaletosh
PI 400 USB-C power cable pulls out very easily
Thu Apr 15, 2021 1:12 pm
I recently purchased PI 400 kit. I am really pleased with the product, except that the USB-C power plug is very easy to pull out. If I move the computer even just a fraction of an inch, I risk having the computer lose power. Sometimes the plug will come completely out. I am using the PI power supply that came with the kit. Is this something I am just going to have to live with?
epoch1970
Re: PI 400 USB-C power cable pulls out very easily
Thu Apr 15, 2021 3:43 pm
Unless you ask for a replacement, I guess so.
whaletosh
Thu Apr 15, 2021 7:51 pm
Do I do that with the retailer?
epoch1970
Thu Apr 15, 2021 7:58 pm
Correct. The faster you return the product the less trouble. If your retailer has an internet site, the procedure to return a product is certainly explained there.
alphanumeric
Fri Apr 16, 2021 11:21 am
IMHO that is definitely a defect with the Pi 400 or the power supply. Mine stays firmly attached. Do you have another power supply to test with? Or a Pi 4B to test that power supply with? It's probably the Pi 400 but if its the power supply it may be an easier deal to get another one versus another Pi 400.
whaletosh
Fri Apr 16, 2021 12:12 pm
I don't have a another power supply. I can use the cable for my tablet to check the jack for fit.
The_Handy_Andy
Sun Apr 18, 2021 10:17 pm
I'm running my Pi400 off a powerbank and the USB C plug / socket is a good fit. Now I've just tried the plug on the official PSU and that is also a good fit, although for where I am using my Pi400 the cable isn't long enough to reach a mains socket (one of the reasons why I'm using a powerbank). So the one question I would ask is how close is your mains socket (is there much 'give' in the cable)?
If the connection is excessively loose then I would contact the supplier as they are your first point of contact.
aBUGSworstnightmare
Mon Apr 19, 2021 6:20 am
any USB-C cable is fine for testing the fit of the socket. No need to power the Pi400 for such simple test.
whaletosh
Mon Apr 19, 2021 1:57 pm
I tried USB-C cable from my tablet, tight fit. Plugged in the PI power supply again, tight fit. I am guessing that there was small piece of flashing or something else that was preventing the power supply connector from seating correctly. The tablet cable must have dislodged whatever was there. This is a weird problem which is now resolved. Thanks everybody.
aBUGSworstnightmare
Mon Apr 19, 2021 4:39 pm
that was an easy one!
alphanumeric
Mon Apr 19, 2021 5:23 pm
Probably a little piece of packing material or something that finally fell out? Anyway, nice to hear its all sorted. Enjoy.
Return to “Raspberry Pi 400”
