Pi905User
Argon One Fan Hat Script For Ubuntu 20.10?
Sun Nov 22, 2020 2:52 am
I am looking for a version of the Argon One Fan Hat script that controls the speed of the fan that will run on Ubuntu 20.10. Does anyone know of one please? If so where?
I did found a version of this script that is suppose to run on Ubuntu 20.04. Short of me trying it does anyone know if this would work on Ubuntu 20.10?
Thank you in advance for any help.
DarkElvenAngel
Re: Argon One Fan Hat Script For Ubuntu 20.10?
Sun Nov 22, 2020 4:45 am
I have a replacements for the stock Python script you can find my project here https://gitlab.com/DarkElvenAngel/argononed.
I haven't tested the installer on Ubuntu 20.10 but it should work.
If you want to give it a try and let me know how it goes for you that would be awesome.
Also I have a thread for the project here viewtopic.php?f=29&t=275713
Pi905User
Sun Nov 22, 2020 5:50 am
Thank you for the suggestion!
Unfortunately I am new to the Pi ecosystem and Linux so if you could give me instructions on how to install the daemon I would really like to give it a try.
Please be sure to include how to remove/uninstall the daemon too.
DarkElvenAngel
Sun Nov 22, 2020 1:54 pm
Sure no problem, you need to open the terminal and then try this command.
git clone --depth=1 https://gitlab.com/DarkElvenAngel/argononed.git
what this will do is copy the project to your computer. Then you need to switch to where project is copied.
cd argononed
then you just need to run
./configure && make all && sudo make install
This will compile everything and try to install it. To uninstall the command would be
make uninstall
So long as you have git installed you'll be able to get the project, then from there when you run configure it checks that you have everything you need installed.
If you see an error post it here. If you are missing packages or git then you can try this command.
sudo apt-get update && sudo apt-get install git build-essential
lijoseph
Authorised Reseller
Authorised Reseller
Mon Nov 23, 2020 1:20 am
the new argon one install script should work for both Raspberry Pi OS and Ubuntu 20.10
curl https://download.argon40.com/argon1.sh | bash
Pi905User
Tue Nov 24, 2020 9:54 pm
Thank you for the update! How do you know the script will work please, did Argon say so or did someone test it?
DarkElvenAngel
Wed Nov 25, 2020 12:49 am
I haven't tried the argon one scripts. I do know my project will run on Ubuntu it's the installer that no one has confirmed. Everything is in place so it should.
What ever method you prefer to try you should post back what the results are.
Pi905User
Wed Nov 25, 2020 4:13 am
This evening I loaded Ubuntu Mate 20.10 onto my Pi's SSD and booted it. I downloaded the ArgonOne script, ran it on Ubuntu Mate, and it worked fine! In conclusion the official ArgonOne fan script does work in Ubuntu. Thank you all for your help.
Return to “Ubuntu”
