Lxw2015
run ubuntu on RPI4, could not login
Mon Sep 28, 2020 10:07 pm
flash this image to a SD card
https://ubuntu.com/download/raspberry-p ... m64+raspi4
insert SD card to RPI4. boots up. asking for login.
follow the instruction on that download page.
Login to your Pi
When prompted to log in, use “ubuntu” for the username and the password. You will be asked to change this default password after you log in.
You are now running the Ubuntu Server on your Raspberry Pi.
I changed PW to password.
enter. it asked for login. username: ubuntu. password: password.
login incorrect.
what I did wrong?
this is simple instruction. I really could not find my mistake.
please help
thanks
LXW
davidcoton
Re: run ubuntu on RPI4, could not login
Mon Sep 28, 2020 10:13 pm
Login to your Pi
login incorrect.
what I did wrong?
please help
thanks
LXW
Lxw2015
Mon Sep 28, 2020 10:35 pm
Hi, David,
did you answer anything?
kerry_s
Mon Sep 28, 2020 10:38 pm
Login to your Pi
login incorrect.
what I did wrong?
please help
thanks
LXW
ubuntu boot takes a long time. wait till it fully stops.
you need to be wired or it won't accept passwords.
type ubuntu 3 times then the new password twice.
Mon Sep 28, 2020 10:50 pm
Good grief what does any of that mean?
Are you saying that one cannot login to ones own computer unless it is internet connected (wired)?
If that is even remotely true, which I doubt, that is enough reason to delete Ubuntu immediately.
And what is all that crap about typing user name and password so many times?
I don't believe a word of it.
Lxw2015
Mon Sep 28, 2020 10:56 pm
no matter how many times I tried. not work. and it should not work in that way.
if I enter password as ubuntu. it ask me change password again. seems the password never got changed.
:roll:
kerry_s
Mon Sep 28, 2020 10:59 pm
it just needs to be wired at first setup, you know so it can phone home, let them know there's a new user. :lol:
yes, at first setup it asks for ubuntu 3 times, read it, don't just assume.
it's a cloud server out of the box, with out a connection to the net it's well you know.
Lxw2015
Mon Sep 28, 2020 11:04 pm
Heater,
I agree with you. what he said not make sense. I do have monitor and keyboard connected. I don't think internet connection is needed for me to login. if that is the case, the ubuntu web should states that. I wonder why no one asked my question before. I missed any thing?!
:oops: :(
kerry_s
Mon Sep 28, 2020 11:36 pm
Heater,
:oops: :(
i told them it was dumb, just like i told them there needs to be a simple way to setup wifi if you can't wire in, i had to get 50 feet of ethernet cable just to play around with ubuntu, now i have powerline ethernet so distance is no longer a issue for me, but it was in the past.
it's a server they assume users use it wired, at first boot it tries to connect to there cloud for a ssh key. ....
you can go over there & voice your opinion, file a bug, let them know we would like a desktop version, etc....
davidcoton
Mon Sep 28, 2020 11:38 pm
Hi, David,
Sorry, no. Posted in error -- the problem I thought I saw disappeared when I re-read you post :?
kerry_s
Tue Sep 29, 2020 12:03 am
the download for ubuntu just completed, i'll give it a spin see if anything has changed, see ya in a bit. :D
kerry_s
Tue Sep 29, 2020 12:45 am
yeap, just like i remember. it's still a turd.
first boot is still long, have to wait till after the ssh key message, than hit enter.
login ubuntu
password ubuntu
current password ubuntu
new password
retype password
yeap, 3x ubuntu
then you have to wait cause unattended upgrades is running, so you can't do nothing, it won't even let you shutdown till it's finished.
then you can run update, 76 packages.
now I'm trying to get ubuntu-desktop installed, she's a'goin.
be back when i get to desktop.
kerry_s
Tue Sep 29, 2020 1:23 am
that took forever, i should have done ubuntu-desktop-minimal
it crashed on me after the welcome setup.
i have a message popping up that there's a problem.
it's slow, the display is the wrong size & there are no other options.
no wired connection, no bluetooth.
sound worked after selecting analog.
can't do full screenshots cause there to big to attache.
alright that's it it does work. :lol:
Screenshot from 2020-09-28 15-21-31.png (96.73 KiB) Viewed 588 times
Screenshot from 2020-09-28 15-20-58.png (83.34 KiB) Viewed 588 times
Lxw2015
Tue Sep 29, 2020 3:05 pm
there is no new password retype thing.
I connect wired internet. make no difference. could ubuntu posted wrong instruction???? so weird!!!
I will give up. stupid ubuntu server!
kerry_s
Tue Sep 29, 2020 7:10 pm
like i said you have to wait till you see the ssh message, it will say ubuntu login before it's finished booting. not till after it gets the ssh hosts key will it actually work.
i still think it's dumb to have a login in at all, it should just boot & ask for a new password.
running unattended-upgrade as soon as you log in is also stupid, it locks the user out, who most likely will run updates anyways to begin installing & setup of the system.
anyways, like i said, there still doing stupid things.
i put ubuntu on a laptop, even there i had to fix it. it use to just work out of the box.
pasman1
Tue Sep 29, 2020 7:27 pm
I installed ubuntu server on pi4 - all works.
Read installation instructions again.
RPi4-4GB Multiboot RaspOS 32/5.10, RaspOS 64/5.4Bootloader: 2020-09-03, VL805: 000138a1
Lxw2015
Tue Sep 29, 2020 10:22 pm
What! you did? what I missed. how did you passed login? instruction is straight forward. read again, no new found.
Lxw2015
Sun Oct 11, 2020 5:11 pm
My bad! did not read carefully. the instruction is right. foolish my self.
Return to “Ubuntu”
