Which distro do you have on your Pi?
Hey guys. Which distro do you have or which distro do you recommend?
Re: Which distro do you have on your Pi?
Which Pi and what is your main priorities for use?
E8 85 A2 40 C9 40 81 94 40 81 95 40 89 84 89 96 A3
Still NF Shirls
Still NF Shirls
Raspberry Pi OS of course. https://www.raspberrypi.org/downloads/
Why would anyone want to use anything else?
Because the packages in Raspberry Pi OS tend to be seriously outdated, to the point where newer versions are a real improvement.Heater wrote: ↑Tue Sep 15, 2020 11:46 amRaspberry Pi OS of course. https://www.raspberrypi.org/downloads/
This coming from someone who grudgingly uses Raspberry Pi OS (32 bit) nevertheless because otherwise it IS clearly the best option.
they want 64bit OS but not beta.Heater wrote: ↑Tue Sep 15, 2020 11:46 amRaspberry Pi OS of course. https://www.raspberrypi.org/downloads/
Hence my reply to the OP, what is your main priorities?
Still NF Shirls
Still NF Shirls
This is one of those: If you have to ask, then just go with the flow (i.e., Raspbian).
Basically, Raspbian is the "Windows" of the Pi world - it is what everybody uses unless they have a really good reason to use something else. And I say this as someone who has "strayed off the path" a few times, trying out other OSes, and then realizing it just isn't worth the pain. I always come back.
Anyway, if you want bleeding edge, try Arch. I ran that for a while, and it was cool always having the absolute latest of everything - I was amazed at how they do it - but eventually ended up concluding that it was just too weird for any serious use.
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Loves Linux; loves to dance.
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Not "outdated".pagenotfound wrote: ↑Tue Sep 15, 2020 12:05 pmBecause the packages in Raspberry Pi OS tend to be seriously outdated, to the point where newer versions are a real improvement.
Rather "in their prime". Tried, tested, stable. Just what you want in an operating system.
When I want new versions of anything I just install it on my stable OS base.
As far as I can tell all 64bit OS are "beta" on the Pi. The video core and whatever is still "beta" and everybody depends on that.
Most of the rest of Pi OS 64 is directly from 64 bit Debian. Which makes me think it's a lot less beta than other distros.
However all the Pi Hardware tweaks and optimizations live in Raspberry Pi OS... Easier to install that and then just add whatever package you desperately need to be leading or bleeding edge. After more than 20 years with Linux, leading and bleeding edge has somewhat lost its allure. Been there, done that, quite like "it just works".pagenotfound wrote: ↑Tue Sep 15, 2020 12:05 pmBecause the packages in Raspberry Pi OS tend to be seriously outdated, to the point where newer versions are a real improvement.Heater wrote: ↑Tue Sep 15, 2020 11:46 amRaspberry Pi OS of course. https://www.raspberrypi.org/downloads/
Personally I tend to run Lite plus the window manager of my choice since I don't particularly like LXDE, and run MATE on all my other Linux desktops.
In your idealized imagination of what happens a Debian perhaps.Heater wrote: ↑Tue Sep 15, 2020 12:45 pmNot "outdated".pagenotfound wrote: ↑Tue Sep 15, 2020 12:05 pmBecause the packages in Raspberry Pi OS tend to be seriously outdated, to the point where newer versions are a real improvement.
In reality, I even have programs that introduced bugs and regressions during the switch to Buster. Like, the frequent crashes type of bugs. And Debian stable doesn't do bug fixes unless they are security related...
And then there are browsers, which for years haven't even tried to reach any state of maturity, favoring high speed development instead. "Tried, tested, stable" is for losers only. Sadly, in the long run you have to go with that because websites rely on the speed increases or stop working for you at all, you miss out on new features and - again - don't even get old bugs fixed.
As for installing newer versions yourself, this very forum is plastered with warnings against that. I've done it myself on a few occasions and maybe 70% of the time it worked without introducing new problems but that route is certainly not for everyone.
(Don't remind me of the time when I had to compile dozens of dependencies and dependencies of dependencies of the development version of Gimp on the previous version of Raspbian)
As I said, I use Raspberry Pi OS nevertheless and you gave some of the reasons. If you and Heater would be kind enough to explain your universal, easy and safe way to install newer packages on top of that, this thread would deserve to become sticky, IMO.bjtheone wrote: ↑Tue Sep 15, 2020 12:57 pmHowever all the Pi Hardware tweaks and optimizations live in Raspberry Pi OS... Easier to install that and then just add whatever package you desperately need to be leading or bleeding edge. After more than 20 years with Linux, leading and bleeding edge has somewhat lost its allure. Been there, done that, quite like "it just works".pagenotfound wrote: ↑Tue Sep 15, 2020 12:05 pmBecause the packages in Raspberry Pi OS tend to be seriously outdated, to the point where newer versions are a real improvement.Heater wrote: ↑Tue Sep 15, 2020 11:46 amRaspberry Pi OS of course. https://www.raspberrypi.org/downloads/
Download source code, install dependencies, follow build instructions.pagenotfound wrote: ↑Tue Sep 15, 2020 1:34 pmAs I said, I use Raspberry Pi OS nevertheless and you gave some of the reasons. If you and Heater would be kind enough to explain your universal, easy and safe way to install newer packages on top of that, this thread would deserve to become sticky, IMO.bjtheone wrote: ↑Tue Sep 15, 2020 12:57 pmHowever all the Pi Hardware tweaks and optimizations live in Raspberry Pi OS... Easier to install that and then just add whatever package you desperately need to be leading or bleeding edge. After more than 20 years with Linux, leading and bleeding edge has somewhat lost its allure. Been there, done that, quite like "it just works".pagenotfound wrote: ↑Tue Sep 15, 2020 12:05 pm
I just did that with VSCode, a not inconsiderable software package. It worked.
YMMV.
I always put the latest version of Python and GCC on each new Raspberry Pi OS install.
Everything else works well enough.
Python is trivial (the usual ./configue && make && sudo make install).
GCC takes some time to build (unattended), but the Pi4 handles it easily.
Pi4 8GB (Raspberry Pi OS 64-bit), Pi4 4GB, Pi4 2GB, Pi1 Rev 1 256MB, Pi Zero
I know. Even done it, although it's often easier said than done. It's the YMMV part that worries me.
So I have to make a copy of the card and then go through all the hassle. Becomes tedious for me real quick. I guess I'm not the kind of person who enjoys tinkering by itself. Typing apt upgrade and then doing what I actually want to work on is so much nicer.
I've always wondered whether, given the resources that you have now from the very beginning, you would have based Raspian on Ubuntu or something.
Yeah, some stuff is surprisingly easy and fast. The ones I want the most, not so much. There was a time when you needed to be a Hogwarts graduate to compile Firefox and I'm not sure it's gotten any easier since the last time I checked.jahboater wrote: ↑Tue Sep 15, 2020 2:00 pmI always put the latest version of Python and GCC on each new Raspberry Pi OS install.
Well, they always based on some nice things:you would have based Raspian on Ubuntu or something.
Fedora can have brillant ideas, though they are not that user friendly
UBU linux is based on .... Debian . Why should they add extra noise?
BTW: methodical testing is very long and tedious... If one is lazy, (I am lazy: I only have dlib and opencv compiled, which is slow -takes maybe a night- and simple -and gives me opencv 4.4 this week: debian one is 3.x, IIRC) one can read good books and wait til it is perfectly stable.
GCC takes around 3.5 hours, but who cares - just start it building and go off to do something else!pagenotfound wrote: ↑Tue Sep 15, 2020 2:31 pmYeah, some stuff is surprisingly easy and fast. The ones I want the most, not so much. There was a time when you needed to be a Hogwarts graduate to compile Firefox and I'm not sure it's gotten any easier since the last time I checked.
In the past, on older Pi models, you left it overnight and had to mess with extra swap, but its quicker now.
So what is stable that you need updating that you actually need? Because I do dev work all the time and rarely need to update anything. The VSCode thing was a notable exception.pagenotfound wrote: ↑Tue Sep 15, 2020 2:23 pmI know. Even done it, although it's often easier said than done. It's the YMMV part that worries me.
I beg to differ. After working as a professional programmer for 40 years, I place a very high value on stable systems. As a result, I exclusively run RPiOS on my Pis. I recommend that anyone who doesn't have a specific need that is not met by RPiOS *and* has the requisite skills to be do all of their own system administration work should do so as well. That applies even more strongly to anyone new to Pis.
You might want to read the context again. I was being sarcastic and even somewhat bitter referring to the attitude of the Mozilla/Firefox and Chrome people these days. And I've made it clear that I'm already following your recommendation.W. H. Heydt wrote: ↑Tue Sep 15, 2020 3:12 pmI beg to differ. After working as a professional programmer for 40 years, I place a very high value on stable systems. As a result, I exclusively run RPiOS on my Pis. I recommend that anyone who doesn't have a specific need that is not met by RPiOS *and* has the requisite skills to be do all of their own system administration work should do so as well. That applies even more strongly to anyone new to Pis.
- davidcoton
- Contact: Website
Once again a question asked and critical information deliberately withheld, so you don't get the "best" answer. The recommendation clearly depends on the answer to wildfire's question.RaspiFanBoy wrote: ↑Tue Sep 15, 2020 11:42 amRaspberry pi 4 8gb ram. But only say which os do you have or which do you recommend
Followed by a neat hijack by pagenotfound....
I agree with WHH. Every development project I was involved with decided early on whether it was "bleeding edge" requiring extra pain and effort to make it work, or a bit more conservative to gain stability and reduce underlying bugs. Both approaches (and the range in between) are valid, depending on customer/marketing/technology decisions made in a context that includes more than the Engineering team.pagenotfound wrote:You might want to read the context again. I was being sarcastic and even somewhat bitter referring to the attitude of the Mozilla/Firefox and Chrome people these days. And I've made it clear that I'm already following your recommendation.W. H. Heydt wrote: ↑Tue Sep 15, 2020 3:12 pmI beg to differ. After working as a professional programmer for 40 years, I place a very high value on stable systems. As a result, I exclusively run RPiOS on my Pis. I recommend that anyone who doesn't have a specific need that is not met by RPiOS *and* has the requisite skills to be do all of their own system administration work should do so as well. That applies even more strongly to anyone new to Pis.
BTW, sarcasm doesn't show well on paper, it often relies on tone of voice and is not universally recognised. If you must use it, flag it more clearly.
An old Finnish friend of mine was fond of saying "You get what you order". I was never quite sure what it was supposed to mean exactly, suspecting it was some kind of Finnish idiom rendered in broken English. Except that it usually came after I started complaining because whatever I was trying to do had all gone horribly wrong.
There are many operating systems available for the Pi. Just select one, based on whatever criteria you may have. Just remember "You get what you order".
have:
rpi 4 4gb
running:
raspberry os 64bit on dual screens
recommend:
raspberry os 32bit
thoughts:
both raspberry os versions have there quirks, if your new & inexperienced 32bit version is where your going to find the most help as it's what most will be using. 64bit still has a few gotchas being a beta release.
rpi 4 4gb
running:
recommend:
raspberry os 32bit
thoughts:
