Page 4 of 6
Re: New Ubuntu Mate arm64 RaspberryPi 4 image
Posted: Sun Aug 09, 2020 1:41 pm
by loboris
BobbeNa wrote: ↑Fri Aug 07, 2020 11:02 pm
...I want to try to fix the sound anytime I shutdown or reboot as you can see in the picture there's two sounds for output available. It defaults to the top one, but there's no sound unless you go in and reset it to the second one. Can you please tell me how to make it permanently use the second one and disregard the first one.
This is a generic Ubuntu (and not only Ubuntu) issue, which can be solved in a number of ways.
Look, for example, at
How do you set a default audio output device in Ubuntu 18.04? for one of the solutions.
You can also try to simply
disable the audio channel you are not using under
Sound preferences/Hardware.
Posted: Sun Aug 09, 2020 1:53 pm
by dror_israel
eeprom update image has nothing to to with the operating system. It just updates the RPi4 eeprom. You don't need to do it if your RPi4 eeprom was already programmed with the latest firmware.
I don't think it works for me...
I get [end kernel] panic - not syncing : No working init found. Try passing init=option to kernel.
Posted: Sun Aug 09, 2020 2:19 pm
by loboris
dror_israel wrote: ↑Sun Aug 09, 2020 1:53 pm
I can only repeat:
eeprom update image has only
one purpose, to
update the RPi4 eeprom and contains no operating system, so kernel panic is
expected.
Use the
image from the
1st post to flash the
Ubuntu Mate operating system to the usb ssd, hd, sd...
Posted: Sun Aug 09, 2020 2:32 pm
by dror_israel
this is what I get.
- Untitled-1.jpg (76.55 KiB) Viewed 793 times
Posted: Sun Aug 09, 2020 3:00 pm
by loboris
dror_israel wrote: ↑Sun Aug 09, 2020 2:32 pm
this is what I get...
So, you have the eeprom not supporting USB boot.
Do the following steps:
- Download eeprom update image
- Flash this image to the SDCard (any >= 1GB will do) with Raspberry Pi Imager or other image flashing program
- Insert SDCard into the microSD card slot of your RPi4 and power on
- RPi4 eeprom will be updated and RPi rebooted, as there is no OS on SDCard, only kernel will be started and halted with kernel panic, this is expected
- Power off your RPi4 and remove SDCard
- Power on you RPi without SD card or any USB storage attached to test if the eeprom was updated, you should get something like this:
- piboot.jpg (190.69 KiB) Viewed 783 times
After that you can
flash raspi_ubuntu_focal_arm64_btrfs.img.xz directly to USB SSD, USB HD or SDCard in USB reader,
connect the USB device to RPi4 USB3 port and
boot.
Posted: Sun Aug 09, 2020 3:12 pm
by dave2000
I'm having trouble getting sound to work via HDMI. Under Sound Preferences -> Hardware, I see two devices listed (both "Built-In Audio" with the choice of stereo/multichannel/mono output) but no HDMI. Any suggestions would be appreciated.
Posted: Sun Aug 09, 2020 3:23 pm
by loboris
dave2000 wrote: ↑Sun Aug 09, 2020 3:12 pm
One of them is HDMI output the other is Headphones, try to select either the 1st or the 2nd one under
Sound Preferences -> Output, to determine which one is HDMI.
Note that it may take 1-2 seconds (depending on your monitor) for HDMI sound to be switched on...
Posted: Sun Aug 09, 2020 4:42 pm
by dave2000
loboris wrote: ↑Sun Aug 09, 2020 3:23 pm
Great, thanks. Simply switched to the second device and HDMI sound is working.
Posted: Sun Aug 09, 2020 7:08 pm
by dror_israel
After that you can flash raspi_ubuntu_focal_arm64_btrfs.img.xz directly to USB SSD, USB HD or SDCard in USB reader, connect the USB device to RPi4 USB3 port and boot
Thanks.
I managed to boot the img from the usb drive.
If I will use the image from ubuntu site will it work as well?
I have trouble installing minecraft, any idea how to do that?
Posted: Mon Aug 10, 2020 5:57 am
by lvramanan
loboris wrote: ↑Wed Aug 05, 2020 11:55 am
Anyway, try with
quirks, other than that I don't know what to suggest.
BTW, the ssd and partitions are always detected, even if UAS is not working properly, reading small chunks of data still works without errors.
For example
sudo dd if=/dev/sda of=/dev/null bs=10k count=10000 iflag=direct status=progress will always finish without errors.
According to
this your ssd supports uas.
I'm having the exact same issue as @Khurram.
- boot_error.jpg (43.07 KiB) Viewed 623 times
I'm using a old
G.Skill 60GB SATA SSD attached to a
SATA-USB controller.
My Device ID is from lsusb and it seems to support uas.
Bus 005 Device 005: ID 174c:55aa ASMedia Technology Inc. Name: ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 1: Dev 5, If 0, Class=Mass Storage, Driver=uas, 480M
I added the quirks in cmdline.txt. But still no luck.
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=df5dfe13-02 rootfstype=btrfs rootflags=subvol=raspi_ubuntu elevator=deadline rootwait usbhid.mousepoll=0 usb-storage.quirks=174c:55aa:u
I've been able to boot the Raspberry Pi OS with the same device. Any idea what could be the issue ? Thanks in advance.
Posted: Mon Aug 10, 2020 2:39 pm
by loboris
lvramanan wrote: ↑Mon Aug 10, 2020 5:57 am
I'm using a old
There should be no difference between RaspberryPi OS and this Ubuntu image related to USB drivers, as the usb drivers are provided by the kernel which is the same.
You can try to boot from USB2, if it boots, then the problem is with uas, and it should work on USB3 with quirks...
Have you been able to boot the Raspberry Pi OS (arm64) with kernel 5.4 from your SSD attached to USB3 port?
This is USB2 port!
480M should be
5000M.
Posted: Mon Aug 10, 2020 3:09 pm
by lvramanan
loboris wrote: ↑Mon Aug 10, 2020 2:39 pm
This is USB2 port!
480M should be
5000M.
No luck with USB 2 either. I connected the SATA to USB controller on my PC's USB port to check the device ID and other info hence you see it as USB2. My bad I should've mentioned it clearly.
No I've not yet tried Raspberry Pi OS (arm64) with kernel 5.4. I tried with the 32 bit Raspberry Pi OS Desktop version, having kernel version 4.19 released on 2020-05-27. Let me try with the version you've suggested.
Posted: Mon Aug 10, 2020 4:11 pm
by lvramanan
lvramanan wrote: ↑Mon Aug 10, 2020 3:09 pm
Quick update: Tried installing the 64 bit version of Raspberry Pi OS with kernel 5.4.42-v8+ and it boots up and loads just fine. I can see the desktop and use Chrome and other stuff.
Dumb question, could the USB drivers be copied manually to your Ubuntu mate image will that work by any chance ?
Thanks in advance and appreciate your inputs
Posted: Wed Aug 12, 2020 11:34 am
by dwpzn
Whomever you are, thank you.
No issues for me deploying and as others confirm much better than the standard one.
Posted: Wed Aug 12, 2020 3:05 pm
by senpaidev
Installed this on my Rpi 4B 4GB with a Samsung Evo plus 64GB card last Saturday and it is honestly the best 3rd Party OS I've had on my raspberry pi yet. I have tried Ubuntu 20.04 Official and MATE official images as before and the end results for both were disastrous. This has been the most straightforward deployment for me, second only to Raspbian or Raspberry Pi OS. I have been able to port of almost my entire setup from Raspbian which runs on docker, other than some key management issues. One thing I miss the most is the ability to use VNC as easily as Raspbian or something, but it is something that I can live without for now as due to the lockdown I am not leaving my house anyways. But yes, it is a feature I am looking forward to in the future.
Thank you very much for this image, hopefully the official images pick up some of the changes you have made and use them. Is there any solution available for getting RDP or VNC to work on the same session? I kinda need it to monitor some tasks or quickly modify some scripts and rest, without having to bother with vim or nano.
Posted: Wed Aug 12, 2020 3:15 pm
by RetiredMike
I bought a 128 gb micro sd and installed the Ubuntu Mate img file per instructions given here ( dd command line no less). It works perfect, and nice 64 bit o.s. with full desk top programs and usage. It was far easier to get the printer (Brother HL3075) going than on Raspbain. The audio switching was not obvious, perhaps that needs more "center stage" for most of us. The choices looked generic, 3 choices for me all looked identical. I went through choices one at a time until my TV on the 2nd HDMI port sprang to life with audio. Audio on the Raspbian is not reliable, and settings don't "keep".
With Mate, It performs very well so job WELL DONE to all involved in porting Mate Ubuntu to the Pi 4. I have had it less than a week. (the 8gig model) I am happy with this tiny computer. Excellent hobby project and great potential for those. To all the crew involved with the Mate porting, excellent job.
Me: Retired circuit board designer and EET. First computer was IMSAI 8080 in 1978. (built from kit). Excellent!
Posted: Wed Aug 12, 2020 3:38 pm
by loboris
senpaidev wrote: ↑Wed Aug 12, 2020 3:05 pm
You can look at
this post, I think
x2go is far better solution.
This repy also has some info about attaching to the running session.
If you only need to look at some files or edit them, you can start
ssh session with
-X option. Then you can start
pluma or other graphical editor (in fact you can start any X program), no need to edit with vim or nano...
BTW, RDP or VNC should work on this image the same way they work on any Ubuntu instalation (on any architecture), with the same issues..
Posted: Wed Aug 12, 2020 3:58 pm
by loboris
RetiredMike wrote: ↑Wed Aug 12, 2020 3:15 pm
My first computer was built in 1976 (
with RCA1802 microprocessor).
- vintage-70s-netronics-elf-ii-computer.jpg (149.25 KiB) Viewed 430 times
256
bytes of RAM, later I've added
4 KB of RAM (a board ~4 x the size of the RPi board) and added a FORTH interpreter.
Couple of years later I've designed and built an 8086 computer (all boards designed and produced at home) with my own OS...
The good old days.
Posted: Sat Aug 15, 2020 6:11 pm
by aronwp
Does this support dual monitors? I can't get it to work on both displays using a pi4 8gb. Raspbian and mate both work without issues while this image does not detect the second display. The second display is rainbow color.
Side note for anyone that has issues booting from USB even after the eprom update make sure you try another enclosure or usb stick. I couldn't boot from usb from the inateck enclosure and multiple Samsung pro's but it booted fine from a cheap micro sd to USB adapter.
Posted: Mon Aug 17, 2020 8:42 am
by NicknDi
loboris wrote: ↑Sun Jul 19, 2020 5:56 pm
NicknDi wrote: ↑Sun Jul 19, 2020 5:46 pm
How do updates work?
My repository is already added, you don't need to do anything.
For updates and other software instalation I would recommend the included
Synaptic package manager, it is simpler than working with
apt from command line.
I recently got a message saying updates were available, so clicked to go ahead, but then got another message saying there wasn't enough space in the boot partition. I'm running from a 500gb ssd so I took that to my main desktop to use gparted to resize the boot partition. For the first time ever (I've always found gparted extremely reliable), something went wrong in the process and the boot partition has become corrupted.
Question 1: Is the size of the boot partition determined within the installation image? I don't recall doing anything re partitions - I just flashed the image as far as I recall. So does there need to be a tweak to the boot partition size to accommodate later updates?
Question 2: From where does that "updates are available" (not necessarily the exact wording) originate? Should I have ignored it?
Question 3: To save me starting again from scratch, having the RPi4 nicely set up now, is there a way I can reflash just the boot partition and leave the rootfs partition intact? If so, what would be the easiest or safest way of doing that?
Once again, thanks, loboris, for this great software project!
Posted: Mon Aug 17, 2020 9:33 am
by loboris
NicknDi wrote: ↑Mon Aug 17, 2020 8:42 am
This was already explained (
here).
The message originates from
update manager which checks for updates in regular intervals (I think it is set to 1 week, you can change it or disable).
Do the first update using
after that there will be no more errors when upgrading from update manager...
Posted: Mon Aug 17, 2020 9:40 am
by loboris
aronwp wrote: ↑Sat Aug 15, 2020 6:11 pm
There should be no reason why dual monitor would not work.
I think I have tested it, but I'm not using it regularry. I'll check it again...
Posted: Mon Aug 17, 2020 9:53 am
by NicknDi
loboris wrote: ↑Mon Aug 17, 2020 9:33 am
here).
Thank you! I'm kicking myself I hadn't properly taken in that earlier post you've pointed me to.
Is there a way to re-flash just the boot partition, or will I have to start again from scratch?
Posted: Mon Aug 17, 2020 10:19 am
by loboris
NicknDi wrote: ↑Mon Aug 17, 2020 9:53 am
Why would you want to change boot partition? You can access files on it (read, write delete...).
If you want to change the boot partition size, you can do that with
gparted, but you must first boot from a different drive.
To increase the boot partition size, first resize (shrink) the rootfs partition, then move it to free some space for boot partition. then expand the boot partiton.
Moving the rootfs partition will take some time as all data must be rewritten...
You can also
backup/restore your system to your PC using
rsync:
Mount boot & rootfs partition from your RPi sdcard/USB on your PC, then execute:
sudo rsync -r -t -p -o -g -x --delete-after -l -H -D --numeric-ids -s -W -S --inplace -h -h --info=name0 --info=progress2 <boot_partiton_mount>/ <boot_backup folder>/
sudo rsync -r -t -p -o -g -x --delete-after -l -H -D --numeric-ids -s -W -S --inplace -h -h --info=name0 --info=progress2 <rootfs_partiton_mount>/ <rootfs_backup folder>/
sudo sync
Unmount your RPi sdcard/USB and
reformat as you want (you can also add the swap partition), mount the boot&rootfs again and restore:
sudo rsync -r -t -p -o -g -x --delete-after -l -H -D --numeric-ids -s -W -S --inplace -h -h --info=name0 --info=progress2 <boot_backup folder>/ <boot_partiton_mount>/
sudo rsync -r -t -p -o -g -x --delete-after -l -H -D --numeric-ids -s -W -S --inplace -h -h --info=name0 --info=progress2 <rootfs_backup folder>/ <rootfs_partiton_mount>/
sudo sync
You will also need to change the partitions IDs (and rootfs filesystem type, if changed) in cmdline.txt and fstab.
Posted: Mon Aug 17, 2020 11:30 am
by NicknDi
loboris wrote: ↑Mon Aug 17, 2020 10:19 am
You possibly missed the intro to my earlier post: after successfully resizing the rootfs partition, something went wrong when I then tried to resize the boot partition (not realising I didn't need to, having not absorbed the info you've re-pointed me to) and the boot partition is now corrupted as something went wrong in the gparted resizing process. I got a warning from gparted and the RPi no longer boots successfully from the ssd; it gets part of the way then stops with various error messages.
I'm interested, out of a desire to learn, as to whether and how one could reflash just the boot partition from an .img file, but I now realise it's little trouble to simply back up the home folder from the rootfs partition, reflash the entire drive and then restore the home folder. Process underway.
Thanks, though, for the additional guidance re backing up, which is helpful to me and others no doubt.
