loboris
Re: New Ubuntu Mate arm64 RaspberryPi 4 image
Mon Aug 17, 2020 11:41 am
NicknDi wrote:
Mon Aug 17, 2020 11:30 am
You possibly missed the intro to my earlier post: after successfully resizing the rootfs partition, something went wrong when I then tried to resize the boot partition (not realising I didn't need to, having not absorbed the info you've re-pointed me to) and the boot partition is now corrupted as something went wrong in the gparted resizing process. I got a warning from gparted and the RPi no longer boots successfully from the ssd; it gets part of the way then stops with various error messages.
You can simply format the boot partition (the simplest way is using gparted), then restore the files to it.
The backup of the boot partition content is available in /opt/boot_<kernel_ver> directory (written when the kernel was installed).
The cmdline.txt & config.txt are not there, you must restore them from elsewhere...
You can easily mount the image file, for example with Mate Disk Image Mounter, and copy the needed files...
NicknDi
Mon Aug 17, 2020 12:38 pm
Thank you very much. That's the info I was after.
luffingsails
Thu Aug 20, 2020 6:42 pm
loboris wrote:
Wed Aug 05, 2020 8:30 am
Khurram wrote:
Tue Aug 04, 2020 7:21 pm
It does not work on my Pi 4 4 GB. It resizes the filesystem, reboots and gets stuck. Please see the screenshot. I updated the eeprom to Jul 16 2020 beforehand.
Did you flashed the ssd directly from image ?
Does the image boots from sdcard inserted into usb reader ?
Does your ssd adapter controller support UAS ?
Some USB-SATA controllers works perfectly fine on PC, but do not work on RPi4, like this one I have:
ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp. JMS567 SATA 6Gb/s bridge
If the last is the case, add to the end of cmdline.txt:
 usb-storage.quirks=152d:0578:u
Replace the USB ID with yours, if needed.
Just FYI, I was trying to install this OS onto a Kingston 240G A400 SATA 3 drive (links below). I did have to modify the cmdline.txt file using this quirk. Otherwise, it would not boot. Thanks a ton to the OP for putting together. It's a lot of effort and I love the benefit.
Cable: https://www.amazon.com/gp/product/B07S9 ... UTF8&psc=1
Drive: https://www.amazon.com/gp/product/B01N5 ... UTF8&psc=1
mrg9999
Re: New Ubuntu Mate arm64 RaspberryPi 4 image (minimal and server images also available)
Thu Aug 20, 2020 7:10 pm
I'm also having trouble with this.
Triied on rpi 4 4gb/8gb both have eeprom mod for usb boot. cables and ssd UASP both work fine for other OS. I tried adding the
3rd reboot I get a kernel panic. Do I need to change anything. I tried usb storage quirks as reported for these drives (not previously needed)
2020-08-20 - rpi 4 panic.jpg (246.68 KiB) Viewed 680 times
Is there some step I'm missing?
Mr.G
kingo71
Thu Aug 20, 2020 8:11 pm
Same error here, tried a USB3 stick and worked fine. Only with the SSD doesn't work but the same SSD works with Raspberry OS.
Something to change in the Kernel?
zjawa
Thu Aug 20, 2020 8:25 pm
I have a problem with WiFi. The system detects the network, I enter the password, but after a while it tells me to enter the password again. It happens again and again. Once connected after a few times but only for a moment but internet was very unstable. I checked on 2 different wifi networks. Any suggestions? The lastest build...
loboris
Thu Aug 20, 2020 8:53 pm
[Same error here, tried a USB3 stick and worked fine. Only with the SSD doesn't work but the same SSD works with Raspberry OS.
The kernel is built from raspberrypi repository. I don't know if RaspberryOS's kernel is the same.
Is the SSD drive reported to use uas in RaspberrypiOS? Can you do some speed tests to confirm the uas is acctually used?
You will hardly notice any difference with or without uas (with quirks), unless transferring realy big files (100s of MB)...
I can't really trust RPi4 USB3 controller (and it's driver) to support UAS reliably, I think I'll always just disable it.
The same USB3->SATA controller which work without any issue (using uas) on 3 different PC motherboards (Intel amd64) and on an armhf board (Odroid-XU4) fails on RPi4 (using the same OS and kernel version). It must mean something (not good for RPi4).
loboris
Thu Aug 20, 2020 9:00 pm
Maybe you have a really bad WiFi signal or the RPi is in a metal enclosure?
Anyway, once connected, the credentials should be remembered and you should not be asked to enter them again...
mrg9999
Fri Aug 21, 2020 12:17 am
[SOLVED] {for me anyway]
installed to microsd booted fine
cloned the microsd to ssd using dd (sudo dd if=/dev/sda of=/dev/sdb bs=10M) shutdown and removed micro sd and booted fine from ssd
Is something with the resize going wrong maybe?
Mr.G
zjawa
Fri Aug 21, 2020 5:39 am
I thought maybe the signal is weak but it detects 3 bars. I have the Pi screwed to the monitor in a printed PLA housing. That's why I checked and turned ON the Hotspot on the phone and put it behind the monitor, right under the Pi. The same problem. I didn't have such a problem on the Raspberry Pi OS.
Edit: I did it. The problem was not with the WiFi. The date was set 5 days ahead. I couldn't change the date in the options, I had to do it through the terminal. Everything is fine now.
kingo71
Fri Aug 21, 2020 6:06 am
Great, I'll give it a try.
Thank you for sharing your solution.
rodeth37
Fri Aug 21, 2020 12:30 pm
Hi!
I cant manage to work dual screens on this OS. Any workarounds for this?
lvramanan
Fri Aug 21, 2020 3:08 pm
Perfect ! That solved the issue for me too. Appreciate for sharing the solution
BranLoux896
Fri Aug 21, 2020 5:15 pm
Hey loboris, do you have any directive on how to get audio to default to HDMI out? I've tried adjusting it in raspi-config as well as trying to mess with some settings with alsamixer and pulseaudio, but was unsuccessful. I can get the audio to work by adjusting the output in the GUI, but it reverts back to the 3.5mm headphone jack once I reboot.
arn9999
Fri Aug 21, 2020 7:58 pm
I can confirm that this solution worked for me too - just an addition to anyone who doesn't know commands very well, make sure to run lsblk in terminal to get your specific drive names - don't rely on them being named sda/sdb etc - cause they may not be, at least they weren't for me. After that, run the sudo dd command below and it should then be bootable - as I was also getting the same error every time without doing it like this. Thanks for your solution post!!
rodeth37
Fri Aug 21, 2020 11:04 pm
Anyone here tried connecting 2 monitors? The OS only recognizing one monitor and the other one is just a rainbow square showing. May I know if dual screen is supported on this OS or if there are workarounds to fix the issue?
akash17
Sat Aug 22, 2020 4:45 am
getting a panic error and no go... should the drive be formated with btrfs? If so, how... not finding clear info on the process.
loboris
Sat Aug 22, 2020 4:03 pm
It's not an issue.
Just check your /boot/config.txt. If you have max_framebuffers=1, change it to max_framebuffers=2 and you can use two monitors.
kingo71
Sat Aug 22, 2020 4:04 pm
For who is interested in have realVNC working on this distro, here is how to do it:
Since we will install the 32bit version, first of all we need to add the armhf architechture to our package manager.
sudo dpkg --add-architecture armhf
sudo apt update
1 .Donwload and install the deb package for raspberry from https://www.realvnc.com/en/connect/down ... spberrypi/
2. copy the following lib files from the Pi4 firmware repository https://github.com/raspberrypi/firmware ... opt/vc/lib
libbcm_host.so
libvcos.so
libmmal.so
libmmal_core.so
libmmal_components.so
libmmal_util.so
libmmal_vc_client.so
libchiq_arm.so
libvcsm.so
libcontainers.so
to the folder:
/usr/lib
3. type the following on a terminal window to have vnc server starting at every boot:
sudo systemctl enable vncserver-x11-serviced.service
That's it.
Hope this can be useful to someone.
Angelo.
loboris
Sat Aug 22, 2020 4:08 pm
Could you give more information about what have you done? Are you tring to boot from sdcard or usb disk?
The process couldn't be simpler, just write the image to the sdcard.
thatchunkylad198966
Sat Aug 22, 2020 4:48 pm
loboris wrote:
Mon Aug 03, 2020 1:07 pm
thatchunkylad198966 wrote:
Mon Aug 03, 2020 11:33 am
So... this isn't stable at all.
I flashed to an old sdcard, ran "raspi-config" and checked "boot" from USB. it booted, restarted itself to resize then gave a kernel panic and doesn't go any further.
I'm done. thanks for your effort.
Sorry, but according to this thread you are not willing to listen what others recommend to try.
Booting from USB on RPi4 has absolutely nothing to do with the OS installed. It is function of pre-boot configuration and discussed all over this forum.
I'm not stupid, I know how USB-BOOT works.
I ran your image, flashed an SSD, copied over the elf and dat files; ran raspi-config and checked USB-BOOT. it reboots, resizes... try and reboot again and I get a kernel panic like others in this thread.
Again, your image isn't stable but thanks for the effort. (:
One man's trash is another man's treasure! :) Pi's I have; Pi Zero, Pi Zero W, Pi 2 x2, Pi 3 x2, Pi 4 4GB x2.
loboris
Sat Aug 22, 2020 4:54 pm
I think it is very stable.
You don't need to copy any elf or dat files or run raspi-config, where have you heard of that...
thatchunkylad198966
Sat Aug 22, 2020 5:22 pm
What you think and what it actually is are two different things.
Multiple users in this thread having a kernel panic with your image so suggests to me it isn't stable.
lvramanan
Sun Aug 23, 2020 4:19 am
And solutions have been provided for the Kernel panic as well. Please check the previous threads on the solution.
KAB1
Sun Aug 23, 2020 4:39 am
Thanks for this. Took a couple of tries but eventually worked. Originally I had the RPi 4 4GB in a pimoroni case with the pimoroni fan shim and had absolutely no luck at all. I had used the RPi Imager onto an SD card. Would not boot either from the SD card slot or the USB with SD card reader.
I then swapped then Pi into an Argon One case. used Balena Etcher on an SD card and inserted the card reader into the USB3 port. Suddenly everything worked. I then inserted the SD card into the slot. This also worked.
I then used Balena Etcher to image a 64GB Sandisk flash drive. This also works.
I had downloaded two images from different sources. This may have been the problem, or it could have been the imaging software. Used Win 10 to do this.
I have also booted an RPi4 8GB from the flash drive.
There is no need to copy any dat or elf files.
Previous attempts to install Unbuntu flavours since the eeprom update have resulted in error messages popping up. The errors say nothing other than 'A problem occurred'. Doesn't stop the boot or affect the usage but it is annoying. I have seen no such error using this image.
Well done.
Return to “Ubuntu”
