TechnologyResearcher
resolution stuck with rpi 4 [UBUNTU]
Wed Jun 24, 2020 6:53 am
I seem to be having an issue with the rpi4 to be stuck at same resolution 597x448 4:3.
I have searched google and this forum with sope very usefull solution for this issue but at this point not everything is working.
so i got rpi 4 4GB
os: ubuntu 20.04 headless -> installed gnome-desktop
first issue was having no ui at all so i configured hdmi in usercfg.txt file at /boot/firmware -> working now
for the resolution i have set my hdmi_mode and group and i also found you have a seperate flag for 4k with rpi which is also set.
resolution is still the same.
hdmi is in the gdmi 0 port my tv is 4k resolution so i guess i'll can set the output to 4k aswell
full config now:
hdmi_safe=1
hdmi_force_hotplug=1
hdmi_group=1
hdmi_mode=97
hdmi_enable_4kp60=1
config_hdmi_boost=9
kazin08
Re: resolution stuck with rpi 4 [UBUNTU]
Tue Jun 30, 2020 1:01 am
Rpi4 has 2 video output, so you have to specify from where you want to use, so try this:
in my case i use 1080p and :0 select de HDMI-0
hdmi_safe:0=1
hdmi_group:0=2
hdmi_mode:0=82
And see if you have this parameter in usercfg.txt/config.txt:
dtoverlay=vc4-fkms-v3d
Regards
PiUser10
Tue Jun 30, 2020 7:09 am
As well as the dtoverlay line you may also need to add the line
disable_overscan=1
to remove the black borders and get access to the full screen resolution.
waveform80
Thu Jul 02, 2020 2:09 pm
As kazin08 has noted, dtoverlay=vc4-fkms-v3d is very important for anyone wanting to attempt running a desktop on Ubuntu. Without this, most desktop environments will have trouble driving the display (or at the very least will be unreliable).
Author of / contributor to a few pi related things (picamera, Sense HAT emulator, gpio-zero, piwheels, etc.), and currently a software engineer at Canonical responsible for Ubuntu Server and Core on the Raspberry Pi.
Return to “Ubuntu”
